MXC6255XC
MXC6255XC
    MEMSIC(美新)
    SMD6
    ACCELEROMETER 2G I2C 6SMD
MXC6255XC 数据手册
Powerful Sensing Solutions for a Better Life Ultra Low Cost ACCELEROMETER Chip Scale Packaged Digital Thermal Orientation Sensing Accelerometer MXC6255XC MXC6255XC – Ultra Low Cost Accelerometer © 2010 MEMSIC, Inc. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its One Technology Drive, Suite 325 Andover, MA 01810, USA use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by Tel: +1 978 738 0900 Fax: +1 978 738 0196 implication or otherwise under any patent or patent rights of MEMSIC. Information presented in this document is the property of www.memsic.com MEMSIC, Inc., is considered proprietary, and is not to be reproduced without the specific written permission of MEMSIC, Inc. Rev.E(5/26/2014) Formal release date: 5/29/2014 Page 1 of 14 Ultra Low Cost ACCELEROMETER Powerful Sensing Solutions for a Better Life MXC6255XC: Fully Integrated Thermal Accelerometer Features General Description  Fully Integrated Thermal Accelerometer The MEMSIC Digital Thermal Orientation Sensor is the world's first fully-integrated  X/Y Axis, 8 bit, Acceleration A/D Output (± 2g) orientation sensor also with chip scale package. Its operation is based on our  Chip Scale Package (1.18x1.705x0.955mm) patented MEMS-thermal technology and is built using a standard 0.18um CMOS  4-position Orientation Detection process. DTOS contains no moving parts (such as a ball) and thus eliminates  Shake Detection with Interrupt field-reliability and repeatability issues associated with competitive products. It also  Programmable Shake Threshold eliminates the "click" sounds typically heard in ball based orientation sensors. Shock  Shake Direction Detection survival is greater than 50,000g. DTOS detects four orientations, shake and shake 2  I C Interface direction. In addition, it provides X/Y axis acceleration signals with very low 0g offset.  Power Down Mode An I C interface is used to communicate with this device and an interrupt pin (INT) is  Shock Survival Greater than 50,000 g provided for shake and orientation. The DTOS also has a power down enabled  Operating Supply Voltage from 2.5V to 5.5V with through the I C interface. 2 2 1.8V compatible IO  Produces no Mechanical Sounds ("click") Functional Block Diagram Applications  Consumer: Cell Phones Digital Still Cameras (DSC) Digital Video Cameras (DVC) LCD TV Toys MP3, MP4 Players  Household Safety: Fan Heaters Figure 1 Halogen Lamps Iron The MXC6255XC is packaged in a hermetically sealed, wafer level chip scale Cooling Fans package (WLCSP, 1.18 mm x 1.705 mm x 0.955mm) , the product is RoHS compatible and operates over -20~70℃ temperature range. MXC6255XC – Ultra Low Cost Accelerometer © 2010 MEMSIC, Inc. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its One Technology Drive, Suite 325 Andover, MA 01810, USA use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by Tel: +1 978 738 0900 Fax: +1 978 738 0196 implication or otherwise under any patent or patent rights of MEMSIC. Information presented in this document is the property of www.memsic.com MEMSIC, Inc., is considered proprietary, and is not to be reproduced without the specific written permission of MEMSIC, Inc. Rev.E(5/26/2014) Formal release date: 5/29/2014 Page 2 of 14 Ultra Low Cost ACCELEROMETER Powerful Sensing Solutions for a Better Life MXC6255XC: Fully Integrated Thermal Accelerometer Pin Description: CSP Package Pin Name Description 1 I2C SCL This pin is the serial clock line for the I2C interface. Since the MXC6255XC only operates as a slave device, this pin is always an input. 2 NC During normal operation, this pin must be left floating. 3 GND This is the ground pin for the MXC6255XC. 4 INT This pin is the MXC6255XC interrupt output. The logic level on this pin reflects the state of the INT bit in the STATUS register. INT is set when the orientation differs from the last orientation read by the processor, or a shake event is detected. INT is cleared upon reading of the STATUS register. Figure 2 2 5 This pin is the serial data line for the I2C interface. It is an I/O pin that functions as an input during a write, and an I C SDA Top View (small circle indicate pin 1) output during a read from the MXC6255XC. 6 VDD This is the power supply input. The DC voltage should be between 2.5 and 5.5 volts. Absolute Maximum Ratings* Supply Voltage (VDD) ………………...-0.5 V to +7.0V Storage Temperature ………………..-40C to +150C Acceleration ……………………………………..50,000 g Figure 3 Side View *Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; the functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Electrical Specifications1 Parameter (Units) Conditions Minimum Operating Voltage Range (V) Typical Maximum 2.5 2 VIO(I C interface)(V) 5.5 1.62 In power-up mode 1.8 VDD 1.2 Supply Current (mA) In power-down mode 2 Figure 4 Bottom View Turn-On Time (ms) 0.0004 0.001 300 500 Turn-off Time (ms) 0.5 -20 Operating Temperature Range (℃) +70 3 VDD Rise Time (ms) 10 Notes: 1 All specifications are at 3V and room temperature unless otherwise noted. 2 Time to obtain valid data after existing power-down mode. 3 Maximum allowable power supply rise time from 0.25V to 2.5V (minimum). Slower VDD rise time may cause erroneous data retrieval from OTP memory at power-up. Sensor Characteristics1 Parameter (Units) Conditions Minimum Typical Measurement Range (g) X/Y Axis Alignment Error (°) X/Y Axis ± 1.0 Sensitivity Error (%) X/Y Axis ± 5.0 Sensitivity (LSB/g) X/Y Axis 64 Sensitivity Drift Over Temperature (%) Delta from 25 ℃ (-20 ℃ - 70 ℃) ± 15 Zero g Offset Bias Level (mg) X/Y Axis (25 ℃) ± 50 Zero g Offset Temperature coefficient (mg/℃) X/Y Axis (-20 ℃ - 70 ℃) 0.6 Maximum ± 2.0 3dB Signal Bandwidth (Hz) ± 2.0 10 Notes: 1 All specifications are at 3V and room temperature unless otherwise noted. MXC6255XC – Ultra Low Cost Accelerometer © 2010 MEMSIC, Inc. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its One Technology Drive, Suite 325 Andover, MA 01810, USA use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by Tel: +1 978 738 0900 Fax: +1 978 738 0196 implication or otherwise under any patent or patent rights of MEMSIC. Information presented in this document is the property of www.memsic.com MEMSIC, Inc., is considered proprietary, and is not to be reproduced without the specific written permission of MEMSIC, Inc. Rev.E(5/26/2014) Formal release date: 5/29/2014 Page 3 of 14 Ultra Low Cost ACCELEROMETER Powerful Sensing Solutions for a Better Life MXC6255XC: Fully Integrated Thermal Accelerometer Symbol Parameter (Units) Minimum VIH High Level Input Voltage (Volts) VIL Low Level Input Voltage (Volts) VHYS Hysteresis of Schmitt Trigger Input (Volts) 0.1 IIL Input Leakage, All Inputs (uA) -10 VOH High Level Output Voltage (Volts) VOL Low Level Output Voltage (Volts) Typical Maximum 0.7*VIO 0.3*VIO 10 0.8*VIO 0.2*VIO Digital Switching Characteristics tSU;S Sr tSU;P P tBF S Digital Parameters top tf S tHD;S tlow tHD;D tr tSU;D thigh Symbol Parameter (Units) Minimum (ms)1 Typical Maximum top Operating Valid Time 20 fSCL SCK Clock Frequency (kHz) tr Rise Time (us) 0.3 tf Fall Time (us) 0.3 tlow SCL Low Time (us) 1.3 thigh SCL High Time (us) 0.6 tHD;D Data Hold Time (us) 0 tSU;D Data Set-Up Time (us) 0.1 tSU;S Start Set-Up Time (us) 0.6 tHD;S Start Hold Time (us) 0.6 tSU;P Stop Set-Up Time (us) 0.6 tBF Bus Free Time Between Start and Stop (us) 1.3 0 400 0.9 SCL SDA VDD Note: 1. Master is recommended not to talk with the device within 20mS after power up .2. It is not recommended to keep both SCL and SDA signals low for over 10ms. Figure 5 MXC6255XC – Ultra Low Cost Accelerometer © 2010 MEMSIC, Inc. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its One Technology Drive, Suite 325 Andover, MA 01810, USA use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by Tel: +1 978 738 0900 Fax: +1 978 738 0196 implication or otherwise under any patent or patent rights of MEMSIC. Information presented in this document is the property of www.memsic.com MEMSIC, Inc., is considered proprietary, and is not to be reproduced without the specific written permission of MEMSIC, Inc. Rev.E(5/26/2014) Formal release date: 5/29/2014 Page 4 of 14 Ultra Low Cost ACCELEROMETER Powerful Sensing Solutions for a Better Life MXC6255XC: Fully Integrated Thermal Accelerometer Circuit Schematics Note:  R1 and R2 are pull-up resistors, the value can be determined by customer according to the requirement of the host device, the recommendation value is 2.7KOhm.  INT does not need any pull-up/pull-down resistor  If INT is not used, keep it disconnected (don't pull up or pull down)  Leave NC pin as no connection. Figure 6 MXC6255XC – Ultra Low Cost Accelerometer © 2010 MEMSIC, Inc. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its One Technology Drive, Suite 325 Andover, MA 01810, USA use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by Tel: +1 978 738 0900 Fax: +1 978 738 0196 implication or otherwise under any patent or patent rights of MEMSIC. Information presented in this document is the property of www.memsic.com MEMSIC, Inc., is considered proprietary, and is not to be reproduced without the specific written permission of MEMSIC, Inc. Rev.E(5/26/2014) Formal release date: 5/29/2014 Page 5 of 14 Ultra Low Cost ACCELEROMETER Powerful Sensing Solutions for a Better Life MXC6255XC: Fully Integrated Thermal Accelerometer Landing Pattern Note:  The device should be put into the center area of the PCB, edge area is not recommended.  The device routing should be symmetric.  Solder mask define on PCB is preferred.  The recommended opening size of soldering area of PCB is 250um.  The stencil opening size is recommended in Figure 8.  The thickness of the stencil can be 0.08mm~0.1mm Figure 7 Figure 8 MXC6255XC – Ultra Low Cost Accelerometer © 2010 MEMSIC, Inc. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its One Technology Drive, Suite 325 Andover, MA 01810, USA use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by Tel: +1 978 738 0900 Fax: +1 978 738 0196 implication or otherwise under any patent or patent rights of MEMSIC. Information presented in this document is the property of www.memsic.com MEMSIC, Inc., is considered proprietary, and is not to be reproduced without the specific written permission of MEMSIC, Inc. Rev.E(5/26/2014) Formal release date: 5/29/2014 Page 6 of 14 Powerful Sensing Solutions for a Better Life Ultra Low Cost ACCELEROMETER MXC6255XC: Fully Integrated Thermal Accelerometer Note: Reflow Profile  Reflow is limited to two cycles.  If a second reflow cycle is implemented, it should be applied only after device has cooled down to 25℃ (room temperature)  Figure 9 is the reflow profile for Pb free process  Follow solder paste supplier’s recommendations for the best SMT quality. Figure 9 Reflow Profile Note: Manual Soldering Low Temperature Glass  When soldering manually or repairing via soldering iron/heat gun for a Chip Scale packaged device, the time must be limited to less than 10 seconds and the temperature must not exceed 280℃.  Avoid bending the PCB after the sensor assembly. Figure 10 Chip Scale Package MXC6255XC – Ultra Low Cost Accelerometer © 2010 MEMSIC, Inc. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its One Technology Drive, Suite 325 Andover, MA 01810, USA use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by Tel: +1 978 738 0900 Fax: +1 978 738 0196 implication or otherwise under any patent or patent rights of MEMSIC. Information presented in this document is the property of www.memsic.com MEMSIC, Inc., is considered proprietary, and is not to be reproduced without the specific written permission of MEMSIC, Inc. Rev.E(5/26/2014) Formal release date: 5/29/2014 Page 7 of 14 Ultra Low Cost ACCELEROMETER Powerful Sensing Solutions for a Better Life MXC6255XC: Fully Integrated Thermal Accelerometer Orientation (Bottom View) State Bits OR [1,0] 01 Orientation/Shake Characteristics Output state response to orientation If the sensor is rotated past the 45 degree threshold, the orientation bits will change only after the sensor stays in the same orientation quadrant for a defined period of time. If the sensor crosses back before this time period, the orientation bits remain unchanged. This is to prevent dithering of the 00 orientation state. Four user programmable hysteresis time periods are available : 160, 320, 640 and 1280ms. 11 10 Figure 13 Figure 12 Gravity Direction MXC6255XC can detect orientation changes with up to 60 degrees of off-axis tilt Shake Detection Shake and shake direction are orthogonal to screen orientation. An interrupt pin (INT) is set high and must be cleared by the MCU via the I2C interface. Four user programmable thresholds are available: 0.5g, 1g, 1.5g and 2g, and these can be applied either to the X-axis, Y-axis, or both axes. Figure 8 Figure 9 MXC6255XC – Ultra Low Cost Accelerometer © 2010 MEMSIC, Inc. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its One Technology Drive, Suite 325 Andover, MA 01810, USA use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by Tel: +1 978 738 0900 Fax: +1 978 738 0196 implication or otherwise under any patent or patent rights of MEMSIC. Information presented in this document is the property of www.memsic.com MEMSIC, Inc., is considered proprietary, and is not to be reproduced without the specific written permission of MEMSIC, Inc. Rev.E(5/26/2014) Formal release date: 5/29/2014 Page 8 of 14 Powerful Sensing Solutions for a Better Life Ultra Low Cost ACCELEROMETER MXC6255XC: Fully Integrated Thermal Accelerometer I2C Interface A slave mode I2C interface, capable of operating in standard or fast mode, is implemented on the MXC6255XC. The interface uses a serial data line (SDA) and a serial clock line (SCL) to achieve bi-directional communication between master and slave devices. A master (typically a microprocessor) initiates all data transfers to and from the device, and generates the SCL clock that synchronizes the data transfer. The SDA pin on the MXC6255XC operates both as an input and an open drain output. Since the MXC6255XC only operates as a slave device, the SCL pin is always an input. There are external pull-up resistors on the I2C bus lines. Devices that drive the I2C bus lines do so through open-drain n-channel driver transistors, creating a wired NOR type arrangement. Data on SDA is only allowed to change when SCL is low. A high to low transition on SDA when SCL is high is indicative of a START condition, whereas a low to high transition on SDA when SCL is high is indicative of a STOP condition. When the interface is not busy, both SCL and SDA are high. A data transmission is initiated by the master pulling SDA low while SCL is high, generating a START condition. The data transmission occurs serially in 8 bit bytes, with the MSB transmitted first. During each byte of transmitted data, the master will generate 9 clock pulses. The first 8 clock pulses are used to clock the data, the 9th clock pulse is for the acknowledge bit. After the 8 bits of data are clocked in, the transmitting device releases SDA, and the receiving device pulls it down so that it is stable low during the entire 9th clock pulse. By doing this, the receiving device "acknowledges" that it has received the transmitted byte. If the slave receiver does not generate an acknowledge, then the master device can generate a STOP condition and abort the transfer. If the master is the receiver in a data transfer, then it must signal the end of data to the slave by not generating an acknowledge on the last byte that was clocked out of the slave. The slave must release SDA to allow the master to generate a STOP or repeated START condition. The master initiates a data transfer by generating a START condition. After a data transmission is complete, the master may terminate the data transfer by generating a STOP condition. The bus is considered to be free again a certain time after the STOP condition. Alternatively, the master can keep the bus busy by generating a repeated START condition instead of a STOP condition. This repeated START condition is functionally identical to a START condition that follows a STOP. Each device that sits on the I2C bus has a unique 7 bit address. The first byte transmitted by the master following a START is used to address the slave device. The first 7 bits contain the address of the slave device, and the 8th bit is the R/W* bit (read = 1, write = 0; the asterisk indicates active low, and is used instead of a bar). If the transmitted address matches up to that of the MXC6255XC, then the MXC6255XC will acknowledge receipt of the address, and prepare to receive or send data. If the master is writing to the MXC6255XC, then the next byte that the MXC6255XC receives, following the address byte, is loaded into the address counter internal to the MXC6255XC. The contents of the address counter indicate which register on the MXC6255XC is being accessed. If the master now wants to write data to the MXC6255XC, it just continues to send 8-bit bytes. Each byte of data is latched into the register on the MXC6255XC that the address counter points to. The address counter is incremented after the transmission of each byte. If the master wants to read data from the MXC6255XC, it first needs to write the address of the register it wants to begin reading data from to the MXC6255XC address counter. It does this by generating a START, followed by the address byte containing the MXC6255XC address, with R/W* = 0. The next transmitted byte is then loaded into the MXC6255XC address counter. Then, the master repeats the START condition and re-transmits the MXC6255XC address, but this time with the R/W* bit set to 1. During the next transmission period, a byte of data from the MXC6255XC register that is addressed by the contents of the address counter will be transmitted from the MXC6255XC to the master. As in the case of the master writing to the MXC6255XC – Ultra Low Cost Accelerometer © 2010 MEMSIC, Inc. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its One Technology Drive, Suite 325 Andover, MA 01810, USA use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by Tel: +1 978 738 0900 Fax: +1 978 738 0196 implication or otherwise under any patent or patent rights of MEMSIC. Information presented in this document is the property of www.memsic.com MEMSIC, Inc., is considered proprietary, and is not to be reproduced without the specific written permission of MEMSIC, Inc. Rev.E(5/26/2014) Formal release date: 5/29/2014 Page 9 of 14 Ultra Low Cost ACCELEROMETER Powerful Sensing Solutions for a Better Life MXC6255XC: Fully Integrated Thermal Accelerometer MXC6255XC, the contents of the address counter will be incremented after the transmission of each byte. The protocol for multiple byte reads and writes between a master and a slave device is depicted in Figure 15 Figure 15 The I2C address for MXC6255XC is set as:15h MXC6255XC – Ultra Low Cost Accelerometer © 2010 MEMSIC, Inc. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its One Technology Drive, Suite 325 Andover, MA 01810, USA use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by Tel: +1 978 738 0900 Fax: +1 978 738 0196 implication or otherwise under any patent or patent rights of MEMSIC. Information presented in this document is the property of www.memsic.com MEMSIC, Inc., is considered proprietary, and is not to be reproduced without the specific written permission of MEMSIC, Inc. Rev.E(5/26/2014) Formal release date: 5/29/2014 Page 10 of 14 Ultra Low Cost ACCELEROMETER Powerful Sensing Solutions for a Better Life MXC6255XC: Fully Integrated Thermal Accelerometer User Register Summary Address Name Definition Access Default $00 XOUT 8-bit x-axis acceleration output read 00000000 $01 YOUT 8-bit y-axis acceleration output read 00000000 $02 STATUS orientation and shake status read 00000000 $04 DETECTION Power down, orientation and shake detection parameters write 00000000 $08 CHIP_ID Chip ID of MXC6255XC read xx000101 The registers available to the user on the MXC6255XC are summarized in the table above. Each register contains 8 bits. $00: XOUT – 8-bit x-axis acceleration output (read only) D7 D6 D5 D4 D3 D2 D1 D0 XOUT[7] XOUT[6] XOUT[5] XOUT[4] XOUT[3] XOUT[2] XOUT[1] XOUT[0] 8-bit x-axis acceleration output. Data in 2's complement format with range of -128 to +127. $01: YOUT – 8-bit y-axis acceleration output (read only) D7 D6 D5 D4 D3 D2 D1 D0 YOUT[7] YOUT[6] YOUT[5] YOUT[4] YOUT[3] YOUT[2] YOUT[1] YOUT[0] 8-bit y-axis acceleration output. Data in 2's complement format with range of -128 to +127. $02: STATUS – orientation and shake status register (read only) D7 D6 D5 D4 D3 D2 D1 D0 INT SH[1] SH[0] TILT ORI[1] ORI[0] OR[1] OR[0] OR[1:0] is a 2-bit indication of the device orientation, according to the following scheme: OR[1:0] = 00 – device is vertical in upright orientation; 01 – device is rotated 90 degrees clockwise; 10– device is vertical in inverted orientation; 11 – device is rotated 90 degrees counterclockwise. The bits OR[1:0] are indicative of "long-term" orientation. The orientation is determined by measuring the signs of the quantities ax – ay, and ax + ay, as shown in Figure 13. The orientation measurement is ignored for any samples in which the magnitudes of ax and ay are both less than 3/8 g (for example, during a free-fall event). In order for a new value of OR[1:0] to be written to the STATUS register, a valid measurement of the new orientation must be measured a consecutive number of times determined by the setting of bits ORC[1:0] in the DETECTION register. This provides a low-pass filtering and hysteresis effect that keeps a display from flickering near orientation boundaries. ORI[1:0] is the instantaneous device orientation. It follows the same scheme as OR[1:0], except that it is updated every time a valid orientation measurement is made, not subject to the same low-pass filtering as OR[1:0]. TILT is an indication of whether there is enough acceleration signal strength to make a valid orientation measurement. If TILT = 0, the orientation measurement is valid, if TILT = 1, then the orientation measurement is invalid. TILT is updated every measurement cycle. MXC6255XC – Ultra Low Cost Accelerometer © 2010 MEMSIC, Inc. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its One Technology Drive, Suite 325 Andover, MA 01810, USA use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by Tel: +1 978 738 0900 Fax: +1 978 738 0196 implication or otherwise under any patent or patent rights of MEMSIC. Information presented in this document is the property of www.memsic.com MEMSIC, Inc., is considered proprietary, and is not to be reproduced without the specific written permission of MEMSIC, Inc. Rev.E(5/26/2014) Formal release date: 5/29/2014 Page 11 of 14 Ultra Low Cost ACCELEROMETER Powerful Sensing Solutions for a Better Life MXC6255XC: Fully Integrated Thermal Accelerometer SH[1:0] indicate whether a shake event has taken place, and if so, its direction. Shake can only be detected in a direction perpendicular to the vertical orientation of the device. When an acceleration perpendicular to the device orientation (ax for OR[1:0] = 01 or 11; ay for OR[1:0] = 00 or 10) is sensed that has a magnitude greater than the value set by bits SHTH[1:0] in the DETECTION register, then shake detection begins. For a shake event to be written to SH[1:0], the perpendicular acceleration must again exceed the magnitude set by SHTH[1:0] but with the opposite sign (if bit SHM = 0 in the DETECTION register), or just reverse its sign (if bit SHM = 1 in the DETECTION register). The above mentioned second acceleration events must occur within a certain amount of time, set by SHC[1:0] in the DETECTION register, of the original breaking of the threshold. If a shake is determined to have occurred, then the direction of the shake can be determined by the signs of the accelerations. The shake status is indicated as shown in the following table: SH[1] SH[0] Comment 0 0 no shake event 0 1 shake left 1 0 shake right 1 1 undefined INT is the interrupt bit. Setting this bit high will cause the INT pin to output a high level. The INT bit will be set whenever either (1) The orientation, as indicated by bits OR[1:0] changes, or (2) A shake event occurs. The microprocessor can then service the interrupt by reading the STATUS register. Once a shake event occurs, no new shake events will be recorded until the interrupt has been serviced, although the orientation bits will continue to be updated. The INT bit is cleared by reading the STATUS register. $04: DETECTION – orientation and shake detection parameters (write only) D7 D6 D5 D4 D3 D2 D1 D0 PD SHM SHTH[1] SHTH[0] SHC[1] SHC[0] ORC[1] ORC[0] PD = 1 powers down the MXC6255XC to a non-functional low power state with a maximum current drain of 1 uA. ORC[1:0] sets the orientation hysteresis time period, which is the time period of consecutive valid new instantaneous orientation measurements that must be made before a new orientation value is written into bits OR[1:0] in the STATUS register. The "long-term" orientation change is set by ORC[1:0] as follows: 00 – 160ms, 01 – 320ms, 10 – 640ms, 11 – 1280ms nominally. SHC[1:0] sets the shake events time window, which determines the time window allowed between the first shake event (perpendicular acceleration exceeding the threshold set by SHTH[1:0]) and the second shake event (acceleration breaking the threshold with opposite sign, SHM = 0, or just reversing sign, SHM = 1). The time window is set by SHC[1:0] as follows: 00 – 80ms, 01 – 160ms, 10 – 320ms, 11 – 640ms nominally. SHTH[1:0] sets the shake threshold that the perpendicular acceleration must exceed to trigger the first shake event. The settings for SHTH[1:0] are: 00 - 0.5 g, 01 – 1.0 g, 10 – 1.5 g, 11 – 2.0 g. SHM is the shake mode bit. If SHM = 0, then for a shake to be detected, and written to SH[1:0] in the STATUS register, the second shake event must break the threshold set by SHTH[1:0] with the opposite sign of the first shake event, within the time window set by SHC[1:0]. If SHM = 1, then the second shake event must just have the opposite sign of the first shake event within the time window set by SHC[1:0]. MXC6255XC – Ultra Low Cost Accelerometer © 2010 MEMSIC, Inc. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its One Technology Drive, Suite 325 Andover, MA 01810, USA use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by Tel: +1 978 738 0900 Fax: +1 978 738 0196 implication or otherwise under any patent or patent rights of MEMSIC. Information presented in this document is the property of www.memsic.com MEMSIC, Inc., is considered proprietary, and is not to be reproduced without the specific written permission of MEMSIC, Inc. Rev.E(5/26/2014) Formal release date: 5/29/2014 Page 12 of 14 Ultra Low Cost ACCELEROMETER Powerful Sensing Solutions for a Better Life MXC6255XC: Fully Integrated Thermal Accelerometer $08 (6LSB),: CHIP_ID – Chip ID of MXC6255XC (read only) D7 D6 D5 D4 D3 D2 D1 D0 ID[7] ID[6] ID[5] ID[4] ID[3] ID[2] ID[1] ID[0] x x 0 0 0 1 0 1 MXC6255XC – Ultra Low Cost Accelerometer © 2010 MEMSIC, Inc. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its One Technology Drive, Suite 325 Andover, MA 01810, USA use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by Tel: +1 978 738 0900 Fax: +1 978 738 0196 implication or otherwise under any patent or patent rights of MEMSIC. Information presented in this document is the property of www.memsic.com MEMSIC, Inc., is considered proprietary, and is not to be reproduced without the specific written permission of MEMSIC, Inc. Rev.E(5/26/2014) Formal release date: 5/29/2014 Page 13 of 14 Ultra Low Cost ACCELEROMETER Powerful Sensing Solutions for a Better Life MXC6255XC: Fully Integrated Thermal Accelerometer Package Drawing and Marking Illustration ` Figure 16 MXC6255XC – Ultra Low Cost Accelerometer © 2010 MEMSIC, Inc. Information furnished by MEMSIC is believed to be accurate and reliable. However, no responsibility is assumed by MEMSIC for its One Technology Drive, Suite 325 Andover, MA 01810, USA use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by Tel: +1 978 738 0900 Fax: +1 978 738 0196 implication or otherwise under any patent or patent rights of MEMSIC. Information presented in this document is the property of www.memsic.com MEMSIC, Inc., is considered proprietary, and is not to be reproduced without the specific written permission of MEMSIC, Inc. Rev.E(5/26/2014) Formal release date: 5/29/2014 Page 14 of 14
MXC6255XC 价格&库存
很抱歉,暂时无法提供与“MXC6255XC”相匹配的价格&库存,您可以联系我们找货
