KX022-1020-PR
KX022-1020-PR
    KIONIX(Kionix传感器)
    VFLGA12
    ACCELEROMETER 2-8G I2C/SPI 12LGA
KX022-1020-PR 数据手册
e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Product Description The KX022 is a tri-axis ±2g, ±4g or ±8g silicon micromachined accelerometer with integrated 256 byte buffer, orientation, tap/double tap, and activity detecting algorithms. The sense element is fabricated using Kionix’s proprietary plasma micromachining process technology. Acceleration sensing is based on the principle of a differential capacitance arising from acceleration-induced motion of the sense element, which further utilizes common mode cancellation to decrease errors from process variation, temperature, and environmental stress. The sense element is hermetically sealed at the wafer level by bonding a second silicon lid wafer to the device using a glass frit. A separate ASIC device packaged with the sense element provides signal conditioning, and intelligent user-programmable application algorithms. The accelerometer is delivered in a 2 x 2 x 0.9 mm LGA plastic package operating from a 1.71 – 3.6V DC supply. Voltage regulators are used to maintain constant internal operating voltages over the range of input supply voltages. This results in stable operating characteristics over the range of input supply voltages and virtually undetectable ratiometric error. I2C or SPI digital protocol is used to communicate with the chip to configure and check for updates to the orientation, Directional TapTM detection and activity monitoring algorithms. Features 2 x 2 x 0.9 mm LGA User-selectable g Range and Output Data Rate User-selectable low power or high resolution mode Digital High-Pass Filter Outputs Embedded FIFO/FILO buffer Low Power Consumption with FlexSet™ Performance Optimization Internal voltage regulator Enhanced integrated Directional Tap/Double-TapTM, and Device-orientation Algorithms User-configurable wake-up function Digital I2C up to 3.4MHz Digital SPI up to 10MHz Lead-free Solderability Excellent Temperature Performance High Shock Survivability Factory Programmed Offset and Sensitivity Self-test Function N ot R                 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 1 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Table of Contents PRODUCT DESCRIPTION ....................................................................................................................................................................1 FEATURES .........................................................................................................................................................................................1 TABLE OF CONTENTS .........................................................................................................................................................................2 FUNCTIONAL DIAGRAM ....................................................................................................................................................................6 PRODUCT SPECIFICATIONS................................................................................................................................................................7 R MECHANICAL ............................................................................................................................................................................................ 7 ELECTRICAL ............................................................................................................................................................................................... 8 Start Up Time Profile ........................................................................................................................................................................ 9 Current Profile .................................................................................................................................................................................. 9 Power-On Procedure....................................................................................................................................................................... 10 ENVIRONMENTAL ..................................................................................................................................................................................... 11 TERMINOLOGY ........................................................................................................................................................................................ 12 g ...................................................................................................................................................................................................... 12 Sensitivity........................................................................................................................................................................................ 12 Zero-g offset ................................................................................................................................................................................... 12 Self-test ........................................................................................................................................................................................... 12 FUNCTIONALITY ....................................................................................................................................................................................... 13 Sense element................................................................................................................................................................................. 13 ASIC interface ................................................................................................................................................................................. 13 Factory calibration .......................................................................................................................................................................... 13 APPLICATION SCHEMATIC .......................................................................................................................................................................... 14 PIN DESCRIPTIONS ................................................................................................................................................................................... 14 TEST SPECIFICATIONS ................................................................................................................................................................................ 15 PACKAGE DIMENSIONS AND ORIENTATION.................................................................................................................................................... 16 Dimensions ..................................................................................................................................................................................... 16 Orientation ..................................................................................................................................................................................... 17 ot DIGITAL INTERFACE ......................................................................................................................................................................... 19 N I2C SERIAL INTERFACE ............................................................................................................................................................................... 19 I2C Operation .................................................................................................................................................................................. 20 Writing to 8-bit Register ................................................................................................................................................................. 21 Reading from 8-bit Register ............................................................................................................................................................ 21 Data Transfer Sequences ................................................................................................................................................................ 22 HS-mode ......................................................................................................................................................................................... 23 I2C Timing Diagram ......................................................................................................................................................................... 24 SPI COMMUNICATIONS............................................................................................................................................................................. 25 4-Wire SPI Interface ........................................................................................................................................................................ 25 4-Wire SPI Timing Diagram ............................................................................................................................................................ 26 4-Wire Read and Write Registers ................................................................................................................................................... 27 3-Wire SPI Interface ........................................................................................................................................................................ 28 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 2 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 3-Wire SPI Timing Diagram ............................................................................................................................................................ 29 3-Wire Read and Write Registers ................................................................................................................................................... 30 EMBEDDED REGISTERS.................................................................................................................................................................... 31 N ot R ACCELEROMETER OUTPUTS........................................................................................................................................................................ 32 XHP_L .................................................................................................................................................................................................. 33 XHP_H ................................................................................................................................................................................................. 33 YHP_L .................................................................................................................................................................................................. 33 YHP_H ................................................................................................................................................................................................. 33 ZHP_L .................................................................................................................................................................................................. 34 ZHP_H ................................................................................................................................................................................................. 34 XOUT_L ............................................................................................................................................................................................... 34 XOUT_H ............................................................................................................................................................................................... 34 YOUT_L................................................................................................................................................................................................ 35 YOUT_H ............................................................................................................................................................................................... 35 ZOUT_L ................................................................................................................................................................................................ 35 ZOUT_H ............................................................................................................................................................................................... 35 COTR ................................................................................................................................................................................................... 36 WHO_AM_I ......................................................................................................................................................................................... 36 TSCP .................................................................................................................................................................................................... 36 TSPP .................................................................................................................................................................................................... 37 INS1 ..................................................................................................................................................................................................... 37 INS2 ..................................................................................................................................................................................................... 38 INS3 ..................................................................................................................................................................................................... 39 STATUS_REG ....................................................................................................................................................................................... 39 INT_REL ............................................................................................................................................................................................... 39 CNTL1 .................................................................................................................................................................................................. 40 CNTL2 .................................................................................................................................................................................................. 41 CNTL3 .................................................................................................................................................................................................. 42 ODCNTL ............................................................................................................................................................................................... 44 INC1..................................................................................................................................................................................................... 45 INC2..................................................................................................................................................................................................... 45 INC3..................................................................................................................................................................................................... 46 INC4..................................................................................................................................................................................................... 46 INC5..................................................................................................................................................................................................... 47 INC6..................................................................................................................................................................................................... 47 TILT_TIMER ......................................................................................................................................................................................... 48 WUFC .................................................................................................................................................................................................. 48 TDTRC .................................................................................................................................................................................................. 48 TDTC .................................................................................................................................................................................................... 49 TTH ...................................................................................................................................................................................................... 49 TTL ....................................................................................................................................................................................................... 50 FTD ...................................................................................................................................................................................................... 50 STD ...................................................................................................................................................................................................... 50 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 3 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 TLT ....................................................................................................................................................................................................... 51 TWS ..................................................................................................................................................................................................... 51 ATH...................................................................................................................................................................................................... 52 TILT_ANGLE_LL ................................................................................................................................................................................... 52 TILT_ANGLE_HL ................................................................................................................................................................................... 52 HYST_SET ............................................................................................................................................................................................ 53 LP_CNTL .............................................................................................................................................................................................. 53 BUF_CNTL1 ......................................................................................................................................................................................... 54 BUF_CNTL2 ......................................................................................................................................................................................... 55 BUF_STATUS_1 ................................................................................................................................................................................... 56 BUF_STATUS_2 ................................................................................................................................................................................... 56 BUF_CLEAR.......................................................................................................................................................................................... 56 BUF_READ ........................................................................................................................................................................................... 57 SELF_TEST ........................................................................................................................................................................................... 57 EMBEDDED APPLICATIONS ............................................................................................................................................................. 58 ot R ORIENTATION DETECTION FEATURE ............................................................................................................................................................. 58 Hysteresis........................................................................................................................................................................................ 58 Device Orientation Angle (aka Tilt Angle)....................................................................................................................................... 59 Tilt Timer......................................................................................................................................................................................... 60 MOTION INTERRUPT FEATURE DESCRIPTION ................................................................................................................................................. 61 DIRECTIONAL TAP DETECTION FEATURE DESCRIPTION ..................................................................................................................................... 63 Performance Index.......................................................................................................................................................................... 63 Single Tap Detection ....................................................................................................................................................................... 64 Double Tap Detection ..................................................................................................................................................................... 65 SAMPLE BUFFER FEATURE DESCRIPTION ....................................................................................................................................................... 66 FIFO Mode ...................................................................................................................................................................................... 66 Stream Mode .................................................................................................................................................................................. 66 Trigger Mode .................................................................................................................................................................................. 67 FILO Mode ...................................................................................................................................................................................... 67 Buffer Operation ............................................................................................................................................................................. 67 REVISION HISTORY .......................................................................................................................................................................... 73 N NOTICE............................................................................................................................................................................................ 75 PRECAUTION ON USING KIONIX PRODUCTS.................................................................................................................................................. 75 PRECAUTION FOR MOUNTING / CIRCUIT BOARD DESIGN .................................................................................................................................. 76 PRECAUTIONS REGARDING APPLICATION EXAMPLES AND EXTERNAL CIRCUITS ..................................................................................................... 76 PRECAUTION FOR ELECTROSTATIC ............................................................................................................................................................... 76 PRECAUTION FOR STORAGE / TRANSPORTATION ............................................................................................................................................ 76 PRECAUTION FOR PRODUCT LABEL .............................................................................................................................................................. 77 PRECAUTION FOR DISPOSITION ................................................................................................................................................................... 77 PRECAUTION FOR FOREIGN EXCHANGE AND FOREIGN TRADE ACT ...................................................................................................................... 77 PRECAUTION REGARDING INTELLECTUAL PROPERTY RIGHTS ............................................................................................................................. 77 OTHER PRECAUTION ................................................................................................................................................................................. 77 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 4 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 N ot R GENERAL PRECAUTION.............................................................................................................................................................................. 77 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 5 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Functional Diagram X Accel Y Accel Z Accel R Power ADC Amplifier nCS SDO SDA SCL ADDR TRIG INT1 INT2 N ot VDD GND IO_VDD Digital 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 6 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications Product Specifications Mechanical (Specifications are for operation at VDD = 2.5V and T = RT = 25°C unless stated otherwise) Units Min Typical Max Operating Temperature Range Parameters °C -40 - 85 Zero-g Offset mg ±25 ±90 mg/°C 0.2 Zero-g Offset Variation from RT over Temp. GSEL1=0, GSEL0=0 (± 2g) Sensitivity1 GSEL1=0, GSEL0=1 (± 4g) counts/g GSEL1=1, GSEL0=0 (± 8g) GSEL1=0, GSEL0=0 (± 2g) Sensitivity (Buffer 8-bit mode)1,2 GSEL1=0, GSEL0=1 (± 4g) counts/g GSEL1=1, GSEL0=0 (± 8g) Sensitivity Variation from RT over Temp. Positive Self-Test Output change on Activation5 Mechanical Resonance (-3dB)3 Non-Linearity 15401 16384 17367 7700 8192 8684 3850 4096 4342 60 64 68 30 32 34 15 16 17 %/°C g 0.01 0.35 0.5 Hz 3500 (xy) 1800 (z) % of FS 0.6 % 2 Noise (RMS at 50Hz with low-pass filter = ODR/9)4 mg 0.75 R Cross Axis Sensitivity Table 1: Mechanical Specifications N ot Notes: 0.65 Resolution and acceleration ranges are user selectable via I2C or SPI. Sensitivity is proportional to BRES in BUF_CNTL2. Resonance as defined by the dampened mechanical sensor. Noise varies with Output Data Rate (ODR) and Current Consumption settings. Contact Kionix Engineering for additional details on FlexSet™ Performance Optimization. 5. Requires changing of STPOL bit in INC1 register to 1 prior to performing self-test. 1. 2. 3. 4. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 7 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications Electrical (Specifications are for operation at VDD = 2.5V and T = 25°C unless stated otherwise) Parameters Units Min Typical Supply Voltage (VDD) Operating V 1.71 2.5 I/O Pads Supply Voltage (IO_VDD) V 1.7 High Resolution Mode (RES = 1) Low Power Mode1 (RES = 0) Current Consumption Max 3.6 VDD 145 A 10 Standby 0.9 Output Low Voltage (IO_VDD < 2V)2 V - - 0.2 * IO_VDD Output Low Voltage (IO_VDD ≥ 2V)2 V - - 0.4 Output High Voltage V 0.8 * IO_VDD - - Input Low Voltage V - - 0.2 * IO_VDD Input High Voltage V 0.8 * IO_VDD - - Input Pull-down Current A Start Up Time3 ms Power Up Time4 ms 0 2.0 650 10 I2C Communication Rate MHz 3.4 SPI Communication Rate MHz 10 Output Data Rate (ODR)5 Bandwidth (-3dB)6 RES = 0 RES = 1 Hz 0.781 50 Hz 800 Hz ODR/2 1600 Table 2: Electrical Specifications N ot R Notes: 1. Current varies with Output Data Rate (ODR) as shown the chart below, and with Noise level settings. Contact Kionix Engineering for additional details on FlexSet™ Performance Optimization. 2. For I2C communication, this assumes a minimum 1.5K pull-up resistor on SCL and SDA pins. 3. Startup time is from PC1 set to valid outputs. Time varies with Output Data Rate (ODR); see chart below 4. Power up time is from VDD valid to device boot completion. 5. User selectable through I2C or SPI. 6. User selectable and dependent on ODR and RES. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 8 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications Start Up Time Profile KX022 Start Up Time (ms) 100.0 Start Up Time (ms) KX022 Start Up Time ODR Time (Hz) (ms) 1600 3.0 800 3.0 400 4.4 200 7.0 100 12 50 22 25 40 12.5 81 81 40 22 12 10.0 7.0 4.4 3 3.0 1.0 1 10 100 1000 10000 ODR (Hz) Current Profile Representative Current (µA) 16x Averaging Filter (default) R 1000.0 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com 146 146 146 100.0 Current (µA) 43 21 13 10.0 5 2.2 1.8 2.0 7 3.0 RES = 0 RES = 1 when ODR ≥ 400Hz 10000 1000 100 10 1 1.0 0.1 N ot Representative Current Profile ODR (Hz) RES Current (µA) 0 Standby 0.9 0.781 0 1.8 1.563 0 2.0 3.125 0 2.2 6.25 0 3.0 12.5 0 5 25 0 7 50 0 13 100 0 21 200 0 43 400 1 146 800 1 146 1600 1 146 Accelerometer ODR (Hz) © 2016 Kionix – All Rights Reserved Page 9 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Power-On Procedure Proper functioning of power-on reset (POR) is dependent on the specific VDD, VDDLow, TVDD (rise time), and TVDD_Off profile of individual applications. It is recommended to minimize VDDLow, and TVDD, and maximize TVDD_Off. It is also advised that the VDD ramp up time TVDD be monotonic. Note that the outputs will not be stable until VDD has reached its final value. To assure proper POR, the application should be evaluated over the customer specified range of VDD, VDDLow, TVDD, TVDD_Off and temperature as POR performance can vary depending on these parameters. N ot R Please refer to Technical Note TN014 KX022, KX023 Accelerometer Power-On Procedure for more information. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 10 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Environmental Parameters Units Min Typical Max Supply Voltage (VDD) Absolute Limits V -0.5 - 3.63 Operating Temperature Range °C -40 - 85 Storage Temperature Range °C -55 - 150 Mech. Shock (powered and unpowered) g - - 5000 for 0.5ms 10000 for 0.2ms ESD V - - 2000 HBM Table 3: Environmental Specifications Caution: ESD Sensitive and Mechanical Shock Sensitive Component, improper handling can cause permanent damage to the device. These products conform to RoHS Directive 2011/65/EU of the European Parliament and of the Council of the European Union that was issued June 8, 2011. Specifically, these products do not contain any non-exempted amounts of lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE) above the maximum concentration values (MCV) by weight in any of its homogenous materials. Homogenous materials are “of uniform composition throughout”. The MCV for lead, mercury, hexavalent chromium, PBB, and PBDE is 0.10%. The MCV for cadmium is 0.010%. N ot R Applicable Exemption: 7C-I - Electrical and electronic components containing lead in a glass or ceramic other than dielectric ceramic in capacitors (piezoelectronic devices) or in a glass or ceramic matrix compound. HF These products are also in conformance with REACH Regulation No 1907/2006 of the European Parliament and of the Council that was issued Dec. 30, 2011. They do not contain any Substances of Very High Concern (SVHC-161) as identified by the European Chemicals Agency as of 17 December 2014. This product is halogen-free per IEC 61249-2-21. Specifically, the materials used in this product contain a maximum total halogen content of 1500 ppm with less than 900-ppm bromine and less than 900-ppm chlorine. Soldering Soldering recommendations are available upon request or from www.kionix.com. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 11 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications Terminology g A unit of acceleration equal to the acceleration of gravity at the earth's surface. m 1g  9.8 2 s One thousandth of a g (0.0098 m/ s2) is referred to as 1 milli-g (1 mg). Sensitivity The sensitivity of an accelerometer is the change in output per unit of input acceleration at nominal VDD and temperature. The term is essentially the gain of the sensor expressed in counts per g (counts/g) or LSB’s per g (LSB/g). Occasionally, sensitivity is expressed as a resolution, i.e. milli-g per LSB (mg/LSB) or milli-g per count (mg/count). Sensitivity for a given axis is determined by measurements of the formula: Sensitivit y  Output @ 1g  Output @ 1g  2g The sensitivity tolerance describes the range of sensitivities that can be expected from a large population of sensors at room temperature and over life. When the temperature deviates from room temperature (25ºC), the sensitivity will vary by the amount shown in Table 1. R Zero-g offset N ot Zero-g offset or 0-g offset describes the actual output of the accelerometer when no acceleration is applied. Ideally, the output would always be in the middle of the dynamic range of the sensor (content of the OUTX, OUTY, OUTZ registers = 00h, expressed as a 2’s complement number). However, because of mismatches in the sensor, calibration errors, and mechanical stress, the output can deviate from 00h. This deviation from the ideal value is called 0-g offset. The zero-g offset tolerance describes the range of 0-g offsets of a population of sensors over the operating temperature range. Self-test Self-test allows a functional test of the sensor without applying a physical acceleration to it. When activated, an electrostatic force is applied to the sensor, simulating an input acceleration. The sensor outputs respond accordingly. If the output signals change within the amplitude specified Table 1, then the sensor is working properly and the parameters of the interface chip are within the defined specifications. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 12 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Functionality Sense element The sense element is fabricated using Kionix’s proprietary plasma micromachining process technology. This process technology allows Kionix to create mechanical silicon structures which are essentially mass-spring systems that move in the direction of the applied acceleration. Acceleration sensing is based on the principle of a differential capacitance arising from the acceleration-induced motion. Capacitive plates on the moving mass move relative to fixed capacitive plates anchored to the substrate. The sense element is hermetically sealed at the wafer level by bonding a second silicon lid wafer to the device using a glass frit. ASIC interface A separate ASIC device packaged with the sense element provides all of the signal conditioning and communication with the sensor. The complete measurement chain is composed by a low-noise capacitance to voltage amplifier which converts the differential capacitance of the MEMS sensor into an analog voltage that is sent through an analog-to-digital converter. The acceleration data may be accessed through the I2C digital communications provided by the ASIC. In addition, the ASIC contains all of the logic to allow the user to choose data rates, g-ranges, filter settings, and interrupt logic. Plus, there are two programmable state machines which allow the user to create unique embedded functions based on changes in acceleration. Factory calibration N ot R Kionix trims the offset and sensitivity of each accelerometer by adjusting gain (sensitivity) and 0-g offset trim codes stored in nonvolatile memory (OTP). Additionally, all functional register default values are also programmed into the nonvolatile memory. Every time the device is turned on or a software reset command is issued, the trimming parameters and default register values are downloaded into the volatile registers to be used during active operation. This allows the device to function without further calibration. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 13 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications Application Schematic SCL SDO/ADDR 1 SDI/SDA 11 10 nCS 2 9 GND IO_VDD 3 8 TRIG 4 C2 12 5 6 C1 7 VDD INT1 INT2 Pin Descriptions Name 1 SDO/ADDR 2 SDI/SDA 3 IO_VDD 4 TRIG 5 INT1 6 INT2 7 VDD 8 GND 9 GND 10 nCS Description Serial Data Out pin during 4 wire SPI communication and part of the device address during I2C communication. SPI Data input / I2C Serial Data The power supply input for the digital communication bus. Optionally decouple this pin to ground with a 0.1uF ceramic capacitor. Trigger pin for FIFO buffer control – Connect to GND when not using external trigger option R Pin Physical Interrupt 1. Leave floating if not used. Physical Interrupt 2. Leave floating if not used. N ot The power supply input. Decouple this pin to ground with a 0.1uF ceramic capacitor. 11 NC 12 SCLK/SCL Ground Ground SPI enable / I2C mode select. Connect to GND for SPI enabled, I2C communication disabled. Connect to IO_VDD for SPI disabled, I2C communication enabled. Do not leave floating. Not Internally Connected – Can be connected to VDD, IO_VDD, GND or leave floating SPI and I2C Serial Clock 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com Table 4: Pin Descriptions © 2016 Kionix – All Rights Reserved Page 14 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Test Specifications ! Special Characteristics: These characteristics have been identified as being critical to the customer. Every part is tested to verify its conformance to specification prior to shipment. Parameter Specification Test Conditions Zero-g Offset @ RT1 (2g range) 0 ± 1475 counts 25°C, VDD = 2.5 V Sensitivity @ RT1 (2g range) 16384 ± 983 counts/g 25°C, VDD = 2.5 V Table 5: Test Specifications 1 N ot R Room Temperature = 25°C 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 15 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Package Dimensions and Orientation N ot R Dimensions 2 x 2 x 0.9 mm LGA All dimensions and tolerances conform to ASME Y14.5M-1994 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 16 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications Orientation +X Pin 1 +Y +Z When device is accelerated in +X, +Y or +Z direction, the corresponding output will increase. Static X/Y/Z Output Response versus Orientation to Earth’s surface (1g): GSEL1=0, GSEL0=0 (± 2g) Position Diagram 16 8 16384 64 0 0 0 0 0 + 0 0 R Resolution (bits) X (counts) Y (counts) Z (counts) 1 N ot X-Polarity Y-Polarity Z-Polarity 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com 2 16 0 -16384 0 0 0 0 3 8 0 -64 0 16 -16384 0 0 4 8 -64 0 0 0 0 5 Top 6 Bottom Bottom Top 16 8 16 0 0 0 16384 64 0 0 0 16384 0 + 0 0 0 + 8 0 0 64 16 0 0 -16384 8 0 0 -64 0 0 - (1g) Earth’s Surface © 2016 Kionix – All Rights Reserved Page 17 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Static X/Y/Z Output Response versus Orientation to Earth’s surface (1g): GSEL1=0, GSEL0=1 (± 4g) Position 1 2 3 4 Diagram Resolution (bits) X (counts) Y (counts) Z (counts) X-Polarity Y-Polarity Z-Polarity 16 8 16 8 16 8 8192 32 0 0 -8192 -32 0 0 -8192 -32 0 0 0 0 0 0 0 0 0 + 0 0 0 0 0 0 16 0 8192 0 8 0 32 0 0 + 0 5 Top 6 Bottom Bottom Top 16 8 16 8 0 0 0 0 0 0 0 0 8192 32 -8192 -32 0 0 + 0 0 - (1g) Earth’s Surface Static X/Y/Z Output Response versus Orientation to Earth’s surface (1g): GSEL1=1, GSEL0=0 (± 8g) 1 2 3 4 R Position N ot Diagram Resolution (bits) X (counts) Y (counts) Z (counts) X-Polarity Y-Polarity Z-Polarity 16 8 16 8 16 8 4096 16 0 0 -4096 -16 0 0 -4096 -16 0 0 0 0 0 0 0 0 0 + 0 0 0 0 0 0 (1g) 16 0 4096 0 0 + 0 8 0 16 0 5 Top 6 Bottom Bottom Top 16 8 16 8 0 0 0 0 0 0 0 0 4096 16 -4096 -16 0 0 + 0 0 - Earth’s Surface 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 18 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Digital Interface The Kionix KX022 digital accelerometer has the ability to communicate via the I2C and SPI digital serial interface protocols. This allows for easy system integration by eliminating analog-to-digital converter requirements and by providing direct communication with system micro-controllers. The serial interface terms and descriptions as indicated in Table 6 below will be observed throughout this document. Term Transmitter Receiver Master Slave Description The device that transmits data to the bus. The device that receives data from the bus. The device that initiates a transfer, generates clock signals, and terminates a transfer. The device addressed by the Master. Table 6: Serial Interface Terminologies I2C Serial Interface As previously mentioned, the KX022 has the ability to communicate on an I2C bus. I2C is primarily used for synchronous serial communication between a Master device and one or more Slave devices. The Master, typically a micro controller, provides the serial clock signal and addresses Slave devices on the bus. The KX022 always operates as a Slave device during standard Master-Slave I2C operation. ot R I2C is a two-wire serial interface that contains a Serial Clock (SCL) line and a Serial Data (SDA) line. SCL is a serial clock that is provided by the Master, but can be held low by any Slave device, putting the Master into a wait condition. SDA is a bi-directional line used to transmit and receive data to and from the interface. Data is transmitted MSB (Most Significant Bit) first in 8-bit per byte format, and the number of bytes transmitted per transfer is unlimited. The I2C bus is considered free when both lines are high. N The I2C interface is compliant with high-speed mode, fast mode and standard mode I2C protocols. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 19 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 IO_VDD MCU KX022 SDA SCL ADDR KX022 SL SDA SCL ADDR GND Figure 1: Multiple KX022 I2C Connection I2C Address Address 7 bit Pad Address Address IO_VDD 1Fh 3Eh 0 0 1 1 1 1 1 0 IO_VDD 1Fh 3Fh 0 0 1 1 1 1 1 1 GND 1Eh 3Ch 0 0 1 1 1 1 0 0 GND 1Eh 3Dh 0 0 1 1 1 1 0 1 R Description I2C Wr I2C Rd I2C Wr I2C Rd ot I2C Operation N Transactions on the I2C bus begin after the Master transmits a start condition (S), which is defined as a highto-low transition on the data line while the SCL line is held high. The bus is considered busy after this condition. The next byte of data transmitted after the start condition contains the Slave Address (SAD) in the seven MSBs (Most Significant Bits), and the LSB (Least Significant Bit) tells whether the Master will be receiving data ‘1’ from the Slave or transmitting data ‘0’ to the Slave. When a Slave Address is sent, each device on the bus compares the seven MSBs with its internally stored address. If they match, the device considers itself addressed by the Master. The KX022’s Slave Address is comprised of a programmable part and a fixed part, which allows for connection of multiple KX022’s to the same I2C bus. The Slave Address associated with the KX022 is 001111X, where the programmable bit, X, is determined by the assignment of ADDR (pin 1) to GND or IO_VDD. Figure 1 above shows how two KX022’s would be implemented on an I2C bus. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 20 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 It is mandatory that receiving devices acknowledge (ACK) each transaction. Therefore, the transmitter must release the SDA line during this ACK pulse. The receiver then pulls the data line low so that it remains stable low during the high period of the ACK clock pulse. A receiver that has been addressed, whether it is Master or Slave, is obliged to generate an ACK after each byte of data has been received. To conclude a transaction, the Master must transmit a stop condition (P) by transitioning the SDA line from low to high while SCL is high. The I2C bus is now free. Note that if the KX022 is accessed through I2C protocol before the startup is finished a NACK signal is sent. Writing to 8-bit Register Upon power up, the Master must write to the KX022’s control registers to set its operational mode. Therefore, when writing to a control register on the I2C bus, as shown Sequence 1 on the following page, the following protocol must be observed: After a start condition, SAD+W transmission, and the KX022 ACK has been returned, an 8-bit Register Address (RA) command is transmitted by the Master. This command is telling the KX022 to which 8-bit register the Master will be writing the data. Since this is I2C mode, the MSB of the RA command should always be zero (0). The KX022 acknowledges the RA and the Master transmits the data to be stored in the 8-bit register. The KX022 acknowledges that it has received the data and the Master transmits a stop condition (P) to end the data transfer. The data sent to the KX022 is now stored in the appropriate register. The KX022 automatically increments the received RA commands and, therefore, multiple bytes of data can be written to sequential registers after each Slave ACK as shown in Sequence 2 on the following page. Note** If a STOP condition is sent on the least significant bit of write data or the following master acknowledge cycle, the last write operation is not guaranteed and it may alter the content of the affected registers. R Reading from 8-bit Register N ot When reading data from a KX022 8-bit register on the I2C bus, as shown in Sequence 3 on the next page, the following protocol must be observed: The Master first transmits a start condition (S) and the appropriate Slave Address (SAD) with the LSB set at ‘0’ to write. The KX022 acknowledges and the Master transmits the 8-bit RA of the register it wants to read. The KX022 again acknowledges, and the Master transmits a repeated start condition (Sr). After the repeated start condition, the Master addresses the KX022 with a ‘1’ in the LSB (SAD+R) to read from the previously selected register. The Slave then acknowledges and transmits the data from the requested register. The Master does not acknowledge (NACK) it received the transmitted data, but transmits a stop condition to end the data transfer. Note that the KX022 automatically increments through its sequential registers, allowing data to be read from multiple registers following a single SAD+R command as shown below in Sequence 4 on the following page. Reading data from a buffer read register is a special case because if register address (RA) is set to buffer read register (BUF_READ) in Sequence 4, the register autoincrement feature is automatically disabled. Instead, the Read Pointer will increment to the next data in the buffer, thus allowing reading multiple bytes of data from the buffer using a single SAD+R command. Note** Accelerometer’s output data should be read in a single transaction using the auto-increment feature to prevent output data from being updated prior to intended completion of the read transaction. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 21 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications Data Transfer Sequences The following information clearly illustrates the variety of data transfers that can occur on the I 2C bus and how the Master and Slave interact during these transfers. Table 7 defines the I2C terms used during the data transfers. Term S Sr SAD W R ACK NACK RA Data P Definition Start Condition Repeated Start Condition Slave Address Write Bit Read Bit Acknowledge Not Acknowledge Register Address Transmitted/Received Data Stop Condition Table 7: I2C Terms Sequence 1. The Master is writing one byte to the Slave. S SAD + W RA ACK R Master Slave DATA ACK P ACK Sequence 2. The Master is writing multiple bytes to the Slave. S SAD + W ot Master Slave RA ACK DATA ACK DATA ACK P ACK N Sequence 3. The Master is receiving one byte of data from the Slave. Master Slave S SAD + W RA ACK Sr SAD + R ACK NACK ACK P DATA Sequence 4. The Master is receiving multiple bytes of data from the Slave. Master Slave S SAD + W 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com RA ACK Sr ACK SAD + R ACK ACK DATA NACK DATA © 2016 Kionix – All Rights Reserved Page 22 of 77 P PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications HS-mode To enter the 3.4MHz high speed mode of communication, the device must receive the following sequence of conditions from the master: a Start condition followed by a Master code (00001XXX) and a Master Nonacknowledge. Once recognized, the device switches to HS-mode communication. Read/write data transfers then proceed as described in the sequences above. Devices return to the FS-mode after a STOP occurrence on the bus. Sequence 5. HS-mode data transfer of the Master writing multiple bytes to the Slave. Speed Master Slave S FS-mode M-code NACK Sr SAD + W ACK HS-mode RA ACK FS-mode DATA P ACK n bytes + ack. Sequence 6. HS-mode data transfer of the Master receiving multiple bytes of data from the Slave. Speed Master Slave Sr HS-mode SAD + W RA ACK ACK FS-mode HS-mode Sr SAD + R NACK ACK DATA ACK P DATA (n-1) bytes + ack. N ot R Speed Master Slave S FS-mode M-code NACK 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 23 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 I2C Timing Diagram Table 8: I2C Timing (Fast Mode) Description MIN MAX Units t0 t1 t2 t3 t4 t5 t6 t7 t8 t9 t10 t11 Note SDA low to SCL low transition (Start event) SDA low to first SCL rising edge SCL pulse width: high SCL pulse width: low SCL high before SDA falling edge (Start Repeated) SCL pulse width: high during a S/Sr/P event SCL high before SDA rising edge (Stop) SDA pulse width: high SDA valid to SCL rising edge SCL rising edge to SDA invalid SCL falling edge to SDA valid (when slave is transmitting) SCL falling edge to SDA invalid (when slave is transmitting) 50 100 100 100 50 100 50 25 50 50 0 2.5 100 - ns ns ns ns ns ns ns ns ns ns ns ns us R Number N ot Recommended I2C CLK 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 24 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 SPI Communications 4-Wire SPI Interface The KX022 also utilizes an integrated 4-Wire Serial Peripheral Interface (SPI) for digital communication. The SPI interface is primarily used for synchronous serial communication between one Master device and one or more Slave devices. The Master, typically a micro controller, provides the SPI clock signal (SCLK) and determines the state of Chip Select (nCS). The KX022 always operates as a Slave device during standard Master-Slave SPI operation. N ot R 4-wire SPI is a synchronous serial interface that uses two control and two data lines. With respect to the Master, the Serial Clock output (SCLK), the Data Output (SDI or MOSI) and the Data Input (SDO or MISO) are shared among the Slave devices. The Master generates an independent Chip Select (nCS) for each Slave device that goes low at the start of transmission and goes back high at the end. The Slave Data Output (SDO) line, remains in a high-impedance (hi-z) state when the device is not selected, so it does not interfere with any active devices. This allows multiple Slave devices to share a master SPI port as shown in Figure 2 below. Figure 2: 4-wire SPI Connections 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 25 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications 4-Wire SPI Timing Diagram t3 t nCS CLK SDI SDO t1 bit 7 bit 6 bit 1 5 bit 0 t2 t4 bit 7 5 bit 7 5 t5 t6 bit 6 bit 6 bit 1 5 bit 1 5 bit 0 bit 0 t7 Table 9: 4-Wire SPI Timing Description CLK pulse width: high CLK pulse width: low nCS low to first CLK rising edge nCS low after the final CLK rising edge SDI valid to CLK rising edge CLK rising edge to SDI invalid CLK falling edge to SDO valid MIN MAX 40 40 20 30 10 10 35 Units ns ns ns ns ns ns ns N ot R Number t1 t2 t3 t4 t5 t6 t7 Notes 1. t7 is only present during reads. 2. Timings are for VDD of 1.8V to 3.6V with 1K pull-up resistor and maximum 20pF load capacitor on SDO. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 26 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications 4-Wire Read and Write Registers The registers embedded in the KX022 have 8-bit addresses. Upon power up, the Master must write to the accelerometer’s control registers to set its operational mode. On the falling edge of nCS, a 2-byte command is written to the appropriate control register. The first byte initiates the write to the appropriate register, and is followed by the user-defined, data byte. The MSB (Most Significant Bit) of the register address byte will indicate “0” when writing to the register and “1” when reading from the register. This operation occurs over 16 clock cycles. All commands are sent MSB first. The host must return nCS high for at least one clock cycle before the next data request. However, when data is being read from a buffer read register (BUF_READ), the nCS signal can remain low until the buffer is read. Figure 3 below shows the timing diagram for carrying out an 8-bit register write operation. Write Address First 8 bits Second 8 bits Last 8 bits CLK SDI SDO A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 D7 D6 D5 D2 D1 D0 HI-Z HI-Z CS Figure 3: Timing Diagram for 8-Bit Register Write Operation N ot R In order to read an 8-bit register, an 8-bit register address must be written to the accelerometer to initiate the read. The MSB of this register address byte will indicate “0” when writing to the register and “1” when reading from the register. Upon receiving the address, the accelerometer returns the 8-bit data stored in the addressed register. This operation also occurs over 16 clock cycles. All returned data is sent MSB first, and the host must return nCS high for at least one clock cycle before the next data request. Figure 4 shows the timing diagram for an 8-bit register read operation. Read Address First 8 bits Second 8 bits Last 8 bits CLK SDI SDO A7 A6 A5 A4 A3 A2 A1 A0 HI-Z D7 D6 D5 D4 D3 D2 D1 D0 D7 D6 D5 D3 D2 D1 D0 HI-Z CS 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com Figure 4: Timing Diagram for 8-Bit Register Read Operation © 2016 Kionix – All Rights Reserved Page 27 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 3-Wire SPI Interface Figure 5: 3-wire SPI Connections N ot R The KX022 also utilizes an integrated 3-Wire Serial Peripheral Interface (SPI) for digital communication. 3-wire SPI is a synchronous serial interface that uses two control lines and one data line. With respect to the Master, the Serial Clock output (SCLK), the Data Output/Input (SDI) are shared among the Slave devices. The Master generates an independent Chip Select (nCS) for each Slave device that goes low at the start of transmission and goes back high at the end. This allows multiple Slave devices to share a master SPI port as shown in Figure 5 below. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 28 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications 3-Wire SPI Timing Diagram t3 nCS CLK SDI t1 bit 7 bit 6 t5 bit 1 5 t2 t4 bit 0 bit 7 t7 t6 bit 1 5 bit 0 MIN 40 40 20 20 10 10 - MAX 35 t8 Table 10: 3-Wire SPI Timing Number t1 t2 t3 t4 t5 t6 t7 t8 Description CLK pulse width: high CLK pulse width: low nCS low to first CLK rising edge nCS low after the final CLK falling edge SDI valid to CLK rising edge CLK rising edge to SDI input invalid CLK extra clock cycle rising edge to SDI output becomes CLK fallingvalid edge to SDI output becomes valid Units ns ns ns ns ns ns ns ns N ot R Notes 1. t7 and t8 are only present during reads. 2. Timings are for VDD of 1.8V to 3.6V with 1K pull-up resistor and maximum 20pF load capacitor on SDI. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 29 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications 3-Wire Read and Write Registers The registers embedded in the KX022 have 8-bit addresses. Upon power up, the Master must write to the accelerometer’s control registers to set its operational mode. On the falling edge of nCS, a 2-byte command is written to the appropriate control register. The first byte initiates the write to the appropriate register, and is followed by the user-defined, data byte. The MSB (Most Significant Bit) of the register address byte will indicate “0” when writing to the register and “1” when reading from the register. A read operation occurs over 17 clock cycles and a write operation occurs over 16 clock cycles. All commands are sent MSB first. The host must return nCS high for at least one clock cycle before the next data request. However, when data is being read from a buffer read register (BUF_READ), the nCS signal can remain low until the buffer is read. Figure 6 below shows the timing diagram for carrying out an 8-bit register write operation. SCLK SDI A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 (MSB) (MSB) CS Figure 6: Timing Diagram for 8-Bit Register Write Operation N ot R In order to read an 8-bit register, an 8-bit register address must be written to the accelerometer to initiate the read. The MSB of this register address byte will indicate “0” when writing to the register and “1” when reading from the register. Upon receiving the address, the accelerometer returns the 8-bit data stored in the addressed register. For 3-wire read operations, one extra clock cycle between the address byte and the data output byte is required. Therefore, this operation occurs over 17 clock cycles. All returned data is sent MSB first, and the host must return nCS high for at least one clock cycle before the next data request. Figure 7 shows the timing diagram for an 8-bit register read operation. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com SCLK SDI D7 D6 D5 D4 D3 D2 D1 D0 HI-Z A7 A6 A5 A4 A3 A2 A1 A0 (MSB) (MSB) CS Figure 7: Timing Diagram for 8-Bit Register Read Operation © 2016 Kionix – All Rights Reserved Page 30 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications Embedded Registers The KX022 has 57 embedded 8-bit registers that are accessible by the user. This section contains the addresses for all embedded registers and also describes bit functions of each register. Table 11 below provides a listing of the accessible 8-bit registers and their addresses. N ot R Address 00h 01h 02h 03h 04h 05h 06h 07h 08h 09h 0Ah 0Bh 0Ch 0Dh 0Eh 0Fh 10h 11h 12h 13h 14h 15h 16h 17h 18h 19h 1Ah 1Bh 1Ch 1Dh 1Eh 1Fh 20h Register Name XHPL XHPH YHPL YHPH ZHPL ZHPH XOUTL XOUTH YOUTL YOUTH ZOUTL ZOUTH COTR Kionix Reserved Kionix Reserved Who_AM_I TSCP TSPP INS1 INS2 INS3 STAT Kionix Reserved INT_REL CNTL1* CNTL2* CNTL3* ODCNTL* INC1* INC2* INC3* INC4* INC5* R/W R R R R R R R R R R R R R R/W R R R R R R R R/W R/W R/W R/W R/W R/W R/W R/W R/W Address 21h 22h 23h 24h 25h 26h 27h 28h 29h 2Ah 2Bh 2Ch 2Dh 2Eh 2Fh 30h 31h 32h 33h 34h 35h 36h 37h 38h 39h 3Ah 3Bh 3Ch 3Dh 3Eh 3Fh 60h Register Name INC6* TILT_TIMER* WUFC* TDTRC* TDTC* TTH* TTL* FTD* STD* TLT* TWS* Kionix Reserved Kionix Reserved Kionix Reserved Kionix Reserved ATH* Kionix Reserved TILT_ANGLE_LL* TILT_ANGLE_HL* HYST_SET* LP_CNTL* Kionix Reserved Kionix Reserved Kionix Reserved Kionix Reserved BUF_CNTL1* BUF_CNTL2* BUF_STATUS_1 BUF_STATUS_2 BUF_CLEAR BUF_READ SELF_TEST R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R R W R W * Note: - When changing the contents of these registers, the PC1 bit in CNTL1 must first be set to “0”. - Reserved registers should not be written. Table 11: Register Map 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 31 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Register Descriptions Accelerometer Outputs These registers contain up to 16-bits of valid acceleration data for each axis. Depending on the setting of the RES bit in CNTL1, the user may choose to read only the 8 MSB thus reading an effective 8-bit resolution. When BRES = 0 in BUF_CNTL2 the 8 MSB is the only data recorded in the buffer. The data is updated every user-defined ODR period, is protected from overwrite during each read, and can be converted from digital counts to acceleration (g) per 12 below. The register acceleration output binary data is represented in 2’s complement format. For example, if N = 16 bits, then the Counts range is from -32768 to 32767, and if N = 8 bits, then the Counts range is from -128 to 127. Equivalent Counts in decimal Range = ±2g Range = ±4g Range = ±8g 0111 1111 1111 1111 32767 +1.99994g +3.99988g +7.99976g 0111 1111 1111 1110 32766 +1.99988g +3.99976g +7.99951g … … … … … 0000 0000 0001 1 +0.00006g +0.00012g +0.00024g 0000 0000 0000 0 0.000g 0.0000g 0.0000g 1111 1111 1111 1111 -1 -0.00006g -0.00012g -0.00024g … … … … … 1000 0000 0000 0001 -32767 -1.99994g -3.99988g -7.99976g 1000 0000 0000 0000 -32768 -2.00000g -4.00000g -8.00000g Equivalent Counts in decimal Range = ±2g Range = ±4g Range = ±8g 0111 1111 127 +1.9844g +3.9688g +7.9375g 0111 1110 126 +1.9688g +3.9375g +7.8750g … … … … … 0000 0001 1 +0.0156g +0.0313g +0.0625g 0000 0000 0 0.0000g 0.0000g 0.0000g 1111 1111 -1 -0.0156g -0.0313g -0.0625g … … … … … 1000 0001 -127 -1.9844g -3.9688g -7.9375g 1000 0000 -128 -2.000g -4.000g -8.000g R 16-bit Register Data (2’s complement) N ot 8-bit Register Data (2’s complement) Table 12: Acceleration (g) Calculation 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 32 of 77 XHP_L e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 X-axis high pass filter accelerometer output least significant byte. Data is updated at the ODR frequency determined by OWUF in CNTL3. R XHPD7 Bit7 XHP_H R XHPD6 Bit6 R XHPD5 Bit5 R XHPD4 Bit4 R XHPD3 Bit3 R XHPD2 Bit2 R R XHPD1 XHPD0 Bit1 Bit0 2 I C Address: 0x00h X-axis high pass filter accelerometer output most significant byte. Data is updated at the ODR frequency determined by OWUF in CNTL3. R XHPD15 Bit7 YHP_L R XHPD14 Bit6 R XHPD13 Bit5 R XHPD12 Bit4 R XHPD11 Bit3 R XHPD10 Bit2 R R XHPD9 XHPD8 Bit1 Bit0 I2C Address: 0x01h Y-axis high pass filter accelerometer output least significant byte. Data is updated at the ODR frequency determined by OWUF in CNTL3. R YHPD6 Bit6 R YHPD5 Bit5 R YHPD4 Bit4 R YHPD3 Bit3 R YHPD2 Bit2 R R YHPD7 Bit7 YHP_H R R YHPD1 YHPD0 Bit1 Bit0 I2C Address: 0x02h ot Y-axis high pass filter accelerometer output most significant byte. Data is updated at the ODR frequency determined by OWUF in CNTL3. N R YHPD15 Bit7 R YHPD14 Bit6 R YHPD13 Bit5 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com R YHPD12 Bit4 R YHPD11 Bit3 R YHPD10 Bit2 R R YHPD9 YHPD8 Bit1 Bit0 I2C Address: 0x03h © 2016 Kionix – All Rights Reserved Page 33 of 77 ZHP_L e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Z-axis high pass filter accelerometer output least significant byte. Data is updated at the ODR frequency determined by OWUF in CNTL3 R ZHPD7 Bit7 ZHP_H R ZHPD6 Bit6 R ZHPD5 Bit5 R ZHPD4 Bit4 R ZHPD3 Bit3 R ZHPD2 Bit2 R R ZHPD1 ZHPD0 Bit1 Bit0 2 I C Address: 0x04h Z-axis high pass filter accelerometer output most significant byte. Data is updated at the ODR frequency determined by OWUF in CNTL3. R ZHPD15 Bit7 XOUT_L R ZHPD14 Bit6 R ZHPD13 Bit5 R ZHPD12 Bit4 R ZHPD11 Bit3 R ZHPD10 Bit2 R R ZHPD9 ZHPD8 Bit1 Bit0 I2C Address: 0x05h X-axis accelerometer output least significant byte. Data is updated at the ODR frequency determined by OSA in ODCNTL. R XOUTD6 Bit6 R XOUTD5 Bit5 R R XOUTD7 Bit7 R XOUTD3 Bit3 R R R XOUTD2 XOUTD1 XOUTD0 Bit2 Bit1 Bit0 I2C Address: 0x06h ot XOUT_H R XOUTD4 Bit4 N X-axis accelerometer output most significant byte. Data is updated at the ODR frequency determined by OSA in ODCNTL. R R R R R R R R XOUTD15 XOUTD14 XOUTD13 XOUTD12 XOUTD11 XOUTD10 XOUTD9 XOUTD8 Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 I2C Address: 0x07h 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 34 of 77 YOUT_L e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Y-axis accelerometer output least significant byte. Data is updated at the ODR frequency determined by OSA in ODCNTL. R YOUTD7 Bit7 YOUT_H R YOUTD6 Bit6 R YOUTD5 Bit5 R YOUTD4 Bit4 R YOUTD3 Bit3 R R R YOUTD2 YOUTD1 YOUTD0 Bit2 Bit1 Bit0 2 I C Address: 0x08h Y-axis accelerometer output most significant byte. Data is updated at the ODR frequency determined by OSA in ODCNTL. R R R R R R R R YOUTD15 YOUTD14 YOUTD13 YOUTD12 YOUTD11 YOUTD10 YOUTD9 YOUTD8 Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 I2C Address: 0x09h ZOUT_L Z-axis accelerometer output least significant byte. Data is updated at the ODR frequency determined by OSA in ODCNTL. R ZOUTD6 Bit6 R ZOUTD5 Bit5 R R ZOUTD7 Bit7 ZOUT_H R ZOUTD4 Bit4 R ZOUTD3 Bit3 R R R ZOUTD2 ZOUTD1 ZOUTD0 Bit2 Bit1 Bit0 I2C Address: 0x0Ah ot Z-axis accelerometer output most significant byte. Data is updated at the ODR frequency determined by OSA in ODCNTL. N R R R R R R R R YOUTD15 YOUTD14 YOUTD13 YOUTD12 YOUTD11 YOUTD10 YOUTD9 YOUTD8 Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 I2C Address: 0x0Bh 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 35 of 77 COTR e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 This register can be used to verify proper integrated circuit functionality. It always has a byte value of 0x55h unless the COTC bit in CNTL2 is set. At that point this value is set to 0xAAh. The byte value is returned to 0x55h after reading this register and the COTC bit in CNTL2 is cleared. R DCSTR7 R DCSTR6 R DCSTR5 R DCSTR4 R DCSTR3 R DCSTR2 7 Bit6 Bit5 Bit4 Bit3 Bit2 WHO_AM_I R DCSTR1 R DCSTR0 Bit1 Bit0 I2C Address: 0x0Ch Reset Value 01010101 This register can be used for supplier recognition, as it can be factory written to a known byte value. The default value is 0x14h. R WIA6 Bit6 R WIA5 Bit5 R WIA4 Bit4 R WIA3 Bit3 R WIA2 Bit2 R R WIA1 WIA0 Bit1 Bit0 I2C Address: 0x0Fh Reset Value 00010100 R R WIA7 Bit7 Tilt Position Registers N ot These two registers report previous and current position data that is updated at the user-defined ODR frequency and is protected during register read. Table 13 describes the reported position for each bit value. TSCP R 0 Bit7 Current Tilt Position Register. R 0 Bit6 R LE Bit5 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com R RI Bit4 R DO Bit3 R UP Bit2 R R FD FU Bit1 Bit0 I2C Address: 0x10h Reset Value 00100000 © 2016 Kionix – All Rights Reserved Page 36 of 77 TSPP e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Previous Tilt Positon Register. R 0 Bit7 R 0 Bit6 R LE Bit5 R RI Bit4 R DO Bit3 Bit LE RI DO UP FD FU R UP Bit2 R R FD FU Bit1 Bit0 I2C Address: 0x11h Reset Value 00100000 Description Left State (X-) Right State (X+) Down State (Y-) Up State (Y+) Face-Down State (Z-) Face-Up State (Z+) Table 13: Tilt Position Interrupt Source Registers These three registers report interrupt state changes. This data is updated when a new interrupt event occurs and each application’s result is latched until the interrupt release register is read. INS1 R 0 Bit6 R TLE Bit5 N ot R 0 Bit7 R This register indicates the triggering axis when a tap/double tap interrupt occurs. Data is updated at the ODR settings determined by OTDT in CNTL3. R TRI Bit4 R TDO Bit3 Bit TLE TRI TDO TUP TFD TFU R TUP Bit2 R R TFD TFU Bit1 Bit0 I2C Address: 0x12h Description X Negative (X-) Reported X Positive (X+) Reported Y Negative (Y-) Reported Y Positive (Y+) Reported Z Negative (Z-) Reported Z Positive (Z+) Reported Table 14: Directional TapTM Reporting 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 37 of 77 INS2 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 This register tells which function caused an interrupt. R 0 Bit7 R BFI Bit6 R WMI Bit5 R DRDY Bit4 R TDTS1 Bit3 R TDTS0 Bit2 R R WUFS TPS Bit1 Bit0 I2C Address: 0x13h BFI – indicates buffer full interrupt. Automatically cleared when buffer is read. BFI = 0 – Buffer is not full BFI = 1 – Buffer is full WMI – Watermark interrupt, bit is set to one when FIFO has filled up to the value stored in the sample bits. This bit is automatically cleared when FIFO/FILO is read and the content returns to a value below the value stored in the sample bits. WMI = 0 – Buffer watermark has not been exceeded WMI = 1 – Buffer watermark has been exceeded DRDY – indicates that new acceleration data (0x06h to 0x0Bh) is available. This bit is cleared when acceleration data is read or the interrupt release register INT_REL is read. DRDY = 0 - new acceleration data not available DRDY = 1 - new acceleration data available N ot R TDTS(1,0) – status of tap/double tap, bit is released when interrupt release register INT_REL is read. TDTS1 TDTS0 Event 0 0 No Tap 0 1 Single Tap 1 0 Double Tap 1 1 Do not exist WUFS – Status of Wake up. This bit is cleared when the interrupt release register INT_REL is read. WUFS = 1 – Motion has activated the interrupt WUFS = 0 – No motion TPS – Tilt Position status. This bit is cleared when the interrupt release register INT_REL is read. TPS = 0 – Position not changed TPS = 1 – Position changed 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 38 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 INS3 This register reports the axis and direction of detected motion. R 0 Bit7 R 0 Bit6 R XNWU Bit5 R XPWU Bit4 R YNWU Bit3 Bit XNWU XPWU YNWU YPWU ZNWU ZPWU R YPWU Bit2 R R ZNWU ZPWU Bit1 Bit0 I2C Address: 0x14h Description X Negative (X-) Reported X Positive (X+) Reported Y Negative (Y-) Reported Y Positive (Y+) Reported Z Negative (Z-) Reported Z Positive (Z+) Reported Table 15: Motion DetectionTM Reporting STATUS_REG This register reports the status of the interrupt. R 0 Bit6 R 0 Bit5 R INT Bit4 R 0 Bit3 R 0 Bit2 R R 0 Bit7 R R 0 0 Bit1 Bit0 I2C Address: 0x15h N ot INT reports the combined (OR) interrupt information of all features. When BFI and WMI in INS2 are 0, the INT bit is released to 0 when INT_REL is read. If WMI or BFI is 1, INT bit remains at 1 until they are cleared by FIFO/FILO buffer read. 0 = no interrupt event 1 = interrupt event has occurred INT_REL R X Bit7 Latched interrupt source information (INS1, INS2, INS3 except WMI/BFI and INT when WMI/BFI is zero) is cleared and physical interrupt latched pin is changed to its inactive state when this register is read. Read value is dummy. R X Bit6 R X Bit5 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com R X Bit4 R X Bit3 R X Bit2 R R X X Bit1 Bit0 I2C Address: 0x17h © 2016 Kionix – All Rights Reserved Page 39 of 77 CNTL1 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Read/write control register that controls the main feature set. R/W PC1 Bit7 R/W RES Bit6 R/W DRDYE Bit5 R/W GSEL1 Bit4 R/W GSEL0 Bit3 R/W TDTE Bit2 R/W R/W WUFE TPE Bit1 Bit0 I2C Address: 0x18h Reset Value 00000000 PC1 controls the operating mode of the KX022. When in RES = 0, please allow 1.2/ODR delay time when transitioning from stand-by PC1 = 0 to operating mode PC1 = 1 to allow new settings to load. 0 = stand-by mode 1 = operating mode RES determines the performance mode of the KX022. The noise varies with ODR, RES and different LP_CNTL settings possibly reducing the effective resolution. Note that to change the value of this bit, the PC1 bit must first be set to “0”. 0 = low current. 1 = high resolution. Bandwidth (Hz) = ODR/2 DRDYE enables the reporting of the availability of new acceleration data as an interrupt. Note that to change the value of this bit, the PC1 bit must first be set to “0”. 0 = availability of new acceleration data is not reflected as an interrupt 1 = availability of new acceleration data is reflected as an interrupt N ot R GSEL1, GSEL0 selects the acceleration range of the accelerometer outputs per Table 16. Note that to change the value of this bit, the PC1 bit must first be set to “0”. GSEL1 GSEL0 0 0 0 1 1 0 Range ±2g ±4g ±8g Table 16: Selected Acceleration Range TDTE enables the Directional TapTM function that will detect single and double tap events. Note that to change the value of this bit, the PC1 bit must first be set to “0”. TDTE = 0 – disable TDTE = 1 - enable 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 40 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 WUFE enables the Wake Up (motion detect) function. 0= disabled, 1= enabled. Note that to change the value of this bit, the PC1 bit must first be set to “0”. 0 = Wake Up function disabled 1 = Wake Up function enabled TPE enables the Tilt Position function that will detect changes in device orientation. Note that to change the value of this bit, the PC1 bit must first be set to “0”. TPE = 0 – disable TPE = 1 – enable CNTL2 Read/write control register that provides more feature set control. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W SRST Bit7 R/W COTC Bit6 R/W LEM Bit5 R/W RIM Bit4 R/W DOM Bit3 R/W UPM Bit2 R/W R/W FDM FUM Bit1 Bit0 I2C Address: 0x19h Reset Value 00111111 SRST initiates software reset, which performs the RAM reboot routine. This bit will remain 1 until the RAM reboot routine is finished. SRST = 0 – no action SRST = 1 – start RAM reboot routine R COTC Command test control. DCST = 0 – no action DCST = 1 – sets COTR register to 0xAAh and when COTR is read, sets this bit to 0 and sets COTR to 0x55h N ot TLEM, TRIM, TDOM, TUPM, TFDM these bits control the tilt axis mask. Per Table 17, if a direction’s bit is set to one (1), tilt in that direction will generate an interrupt. If it is set to zero (0), tilt in that direction will not generate an interrupt. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. Bit TLEM TRIM TDOM TUPM TFDM TFUM Description X Negative (X-) X Positive (X+) Y Negative (Y-) Y Positive (Y+) Z Negative (Z-) Z Positive (Z+) Table 17: Tilt DirectionTM Axis Mask 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 41 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 CNTL3 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications Read/write control register that provides more feature set control. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W OTP1 Bit7 R/W OTP0 Bit6 R/W OTDT2 Bit5 R/W OTDT1 Bit4 R/W OTDT0 Bit3 R/W OWUF2 Bit2 R/W R/W OWUF1 OWUF0 Bit1 Bit0 I2C Address: 0x1Ah Reset Value 10011000 OTPA, OTPB sets the output data rate for the Tilt Position function per Table 18. The default Tilt Position ODR is 12.5Hz. OTP1 0 0 1 1 OTP0 0 1 0 1 Output Data Rate 1.563Hz 6.25Hz 12.5Hz 50Hz Table 18: Tilt Position Function Output Data Rate N ot R OTDTA, OTDTB sets the output data rate for the Directional TapTM function per Table 19. The default Directional TapTM ODR is 400Hz. OTDT2 OTDT1 OTDT0 Output Data Rate 0 0 0 50Hz 0 0 1 100Hz 0 1 0 200Hz 0 1 1 400Hz 1 0 0 12.5Hz 1 0 1 25Hz 1 1 0 800Hz 1 1 1 1600Hz Table 19: Directional TapTM Function Output Data Rate 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 42 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 OWUF2, OWUF1, OWUF0 sets the output data rate for the general motion detection function and the high-pass filtered outputs per Table 20. The default Motion Wake Up ODR is 0.781Hz. OWUF2 OWUF1 OWUF0 Output Data Rate 0 0 0 0.781Hz 0 0 1 1.563Hz 0 1 0 3.125Hz 0 1 1 6.250Hz 1 0 0 12.5Hz 1 0 1 25Hz 1 1 0 50Hz 1 1 1 100Hz N ot R Table 20: Motion Wake Up Function Output Data Rate 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 43 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 ODCNTL e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications This register is responsible for configuring ODR (output data rate) and filter settings. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W IIR_BYPASS Bit7 R/W LPRO Bit6 R/W R/W RESERVED RESERVED Bit5 Bit4 R/W OSA3 Bit3 R/W OSA2 Bit2 R/W R/W OSA1 OSA0 Bit1 Bit0 I2C Address: 0x1Bh Reset Value 00000010 IIR_BYPASS filter bypass mode IIR_BYPASS = 0 – filtering applied IIR_BYPASS = 1 – filter bypassed LPRO low-pass filter roll off control LPRO = 0 – filter corner frequency set to ODR/9 LPRO = 1 – filter corner frequency set to ODR/2 Reserved – The Reserved bits should remain at their Reset state to avoid unexpected behavior. N ot R OSA3, OSA2, OSA1, OSA0 acceleration output data rate. The default ODR is 50Hz. OSA3 OSA2 OSA1 OSA0 Output Data Rate 0 0 0 0 12.5Hz* 0 0 0 1 25Hz* 0 0 1 0 50Hz* 0 0 1 1 100Hz* 0 1 0 0 200Hz* 0 1 0 1 400Hz 0 1 1 0 800Hz 0 1 1 1 1600Hz 1 0 0 0 0.781Hz* 1 0 0 1 1.563Hz* 1 0 1 0 3.125Hz* 1 0 1 1 6.25Hz* Table 21: Accelerometer Output Data Rates (ODR) * Low power mode available, all other data rates will default to high resolution mode 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 44 of 77 INC1 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 This register controls the settings for the physical interrupt pin INT1. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W R/W Reserved Reserved Bit7 Bit6 R/W IEN1 Bit5 R/W IEA1 Bit4 R/W IEL1 Bit3 R/W R/W R/W Reserved STPOL SPI3E Bit2 Bit1 Bit0 I2C Address: 0x1Ch Reset Value 00010000 IEN enables/disables the physical interrupt pin IEN = 0 – physical interrupt pin is disabled IEN = 1 – physical interrupt pin is enabled IEA sets the polarity of the physical interrupt pin IEA = 0 – polarity of the physical interrupt pin is active low IEA = 1 – polarity of the physical interrupt pin is active high IEL sets the response of the physical interrupt pin IEL = 0 – the physical interrupt pin latches until it is cleared by reading INT_REL IEL = 1 – the physical interrupt pin will transmit one pulse with a period of 50 us STPOL sets the polarity of Self-Test STPOL = 0 – Negative STPOL = 1 – Positive R SPI3E sets the 3-wire SPI interface SPI3E = 0 – disabled SPI3E = 1 – enabled N ot Reserved – The Reserved bits should remain at their Reset state to avoid unexpected behavior. INC2 R/W 0 Bit7 This register controls which axis and direction of detected motion can cause an interrupt. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W 0 Bit6 R/W XNWUE Bit5 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com R/W XPWUE Bit4 R/W YNWUE Bit3 R/W YPWUE Bit2 R/W R/W ZNWUE ZPWUE Bit1 Bit0 2 I C Address: 0x1Dh Reset Value 00111111 © 2016 Kionix – All Rights Reserved Page 45 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 XNWU – x negative (x-): 0 = disabled, 1 = enabled XPWU – x positive (x+): 0 = disabled, 1 = enabled YNWU – y negative (y-): 0 = disabled, 1 = enabled YPWU – y positive (y+): 0 = disabled, 1 = enabled ZNWU – z negative (z-): 0 = disabled, 1 = enabled ZPWU – z positive (z+): 0 = disabled, 1 = enabled INC3 This register controls which axis and direction of tap/double tap can cause an interrupt. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W 0 Bit7 R/W 0 Bit6 R/W TLEM Bit5 R/W TRIM Bit4 R/W TDOM Bit3 R/W TUPM Bit2 R/W R/W TFDM TFUM Bit1 Bit0 I2C Address: 0x1Eh Reset Value 00111111 TLEM – x negative (x-): 0 = disabled, 1 = enabled TRIM – x positive (x+): 0 = disabled, 1 = enabled TDOM – y negative (y-): 0 = disabled, 1 = enabled TUPM – y positive (y+): 0 = disabled, 1 = enabled TFDM – z negative (z-): 0 = disabled, 1 = enabled TFUM – z positive (z+): 0 = disabled, 1 = enabled INC4 R/W BFI1 Bit6 N ot R/W 0 Bit7 R This register controls routing of an interrupt reporting to physical interrupt pin INT1. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W WMI1 Bit5 R/W DRDYI1 Bit4 R/W Reserved Bit3 R/W TDTI1 Bit2 R/W R/W WUFI1 TPI1 Bit1 Bit0 I2C Address: 0x1Fh Reset Value 00000000 BFI1 – Buffer full interrupt reported on physical interrupt pin INT1 WMI1 - Watermark interrupt reported on physical interrupt pin INT1 DRDYI1 – Data ready interrupt reported on physical interrupt pin INT1 TDTI1 - Tap/Double Tap interrupt reported on physical interrupt pin INT1 WUFI1 – Wake-Up (motion detect) interrupt reported on physical interrupt pin INT1 TPI1 – Tilt position interrupt reported on physical interrupt pin INT1 Reserved – The Reserved bits should remain at their Reset state to avoid unexpected behavior. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 46 of 77 INC5 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 This register controls the settings for the physical interrupt pin INT2. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W R/W Reserved Reserved Bit7 Bit6 R/W IEN2 Bit5 R/W IEA2 Bit4 R/W IEL2 Bit3 R/W R/W R/W Reserved Reserved Reserved Bit2 Bit1 Bit0 I2C Address: 0x20h Reset Value 00010000 IEN2 enables/disables the physical interrupt pin IEN2 = 0 – physical interrupt pin is disabled IEN2 = 1 – physical interrupt pin is enabled IEA2 sets the polarity of the physical interrupt pin IEA2 = 0 – polarity of the physical interrupt pin is active low IEA2 = 1 – polarity of the physical interrupt pin is active high IEL2 sets the response of the physical interrupt pin IEL2 = 0 – the physical interrupt pin latches until it is cleared by reading INT_REL IEL2 = 1 – the physical interrupt pin will transmit one pulse with a period of 50 us Reserved – The Reserved bits should remain at their Reset state to avoid unexpected behavior. INC6 R This register controls routing of interrupt reporting to physical interrupt pin INT2. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W BFI2 Bit6 N ot R/W 0 Bit7 R/W WMI2 Bit5 R/W DRDYI2 Bit4 R/W Reserved Bit3 R/W TDTI2 Bit2 R/W R/W WUFI2 TPI2 Bit1 Bit0 I2C Address: 0x21h Reset Value 00000000 BFI2 – Buffer full interrupt reported on physical interrupt pin INT2 WMI2 - Watermark interrupt reported on physical interrupt pin INT2 DRDYI2 – Data ready interrupt reported on physical interrupt pin INT2 TDTI2 - Tap/Double Tap interrupt reported on physical interrupt pin INT2 WUFI2 – Wake-Up (motion detect) interrupt reported on physical interrupt pin INT2 TPI2 – Tilt position interrupt reported on physical interrupt pin INT2 Reserved – The Reserved bits should remain at their Reset state to avoid unexpected behavior. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 47 of 77 TILT_TIMER e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 This register is the initial count register for the tilt position state timer (0 to 255 counts). Every count is calculated as 1/ODR delay period, where the ODR is user-defined per Table 18. A new state must be valid as many measurement periods before the change is accepted. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W TSC7 Bit7 R/W TSC6 Bit6 WUFC R/W TSC5 Bit5 R/W TSC4 Bit4 R/W TSC3 Bit3 R/W TSC2 Bit2 R/W R/W TSC1 TSC0 Bit1 Bit0 I2C Address: 0x22h Reset Value 00000000 This register is the initial count register for the motion detection timer (0 to 255 counts). Every count is calculated as 1/ODR delay period, where the ODR is user-defined per Table 20. A new state must be valid as many measurement periods before the change is accepted. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W WUFC7 Bit7 TDTRC R/W WUFC6 Bit6 R/W WUFC5 Bit5 R/W WUFC4 Bit4 R/W WUFC3 Bit3 R/W WUFC2 Bit2 R/W R/W WUFC1 WUFC0 Bit1 Bit0 I2C Address: 0x23h Reset Value 00000000 R This register is responsible for enabling/disabling reporting of Tap/Double Tap. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W 0 Bit6 N ot R/W 0 Bit7 R/W 0 Bit5 R/W 0 Bit4 R/W 0 Bit3 R/W 0 Bit2 R/W R/W DTRE STRE Bit1 Bit0 I2C Address: 0x24h Reset Value 00000011 DTRE enables/disables the double tap interrupt DTRE = 0 – do not update/trigger interrupts on double tap events DTRE = 1 –update interrupts on double tap events STRE enables/disables single tap interrupt STRE = 0 – do not update/trigger interrupts on single tap events STRE = 1 –update interrupts on single tap events 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 48 of 77 TDTC e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 This register contains counter information for the detection of a double tap event. When the Directional TapTM ODR is 400Hz or less, every count is calculated as 1/ODR delay period. When the Directional TapTM ODR is 800Hz, every count is calculated as 2/ODR delay period. When the Directional TapTM ODR is 1600Hz, every count is calculated as 4/ODR delay period. The Directional TapTM ODR is userdefined per Table 19. The TDTC counts starts at the beginning of the fist tap and it represents the minimum time separation between the first tap and the second tap in a double tap event. More specifically, the second tap event must end outside of the TDTC. The Kionix recommended default value is 0.3 seconds (0x78h). Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W TDTC7 Bit7 TTH R/W TDTC6 Bit6 R/W TDTC5 Bit5 R/W TDTC4 Bit4 R/W TDTC3 Bit3 R/W TDTC2 Bit2 R/W R/W TDTC1 TDTC0 Bit1 Bit0 I2C Address: 0x25h Reset Value 01111000 R This register represents the 8-bit jerk high threshold to determine if a tap is detected. Though this is an 8-bit register, the register value is internally multiplied by two in order to set the high threshold. This multiplication results in a range of 0d to 510d with a resolution of two counts. The Performance Index (PI) is the jerk signal that is expected to be less than this threshold, but greater than the TTL threshold during single and double tap events. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. The Kionix recommended default value is 203 (0xCBh) and the Performance Index is calculated as: N ot X’ = X (current) – X (previous) Y’ = Y (current) – Y (previous) Z’ = Z (current) – Z (previous) R/W TTH7 Bit7 PI = |X’| + |Y’| + |Z’| Equation 1: Performance Index R/W TTH6 Bit6 R/W TTH5 Bit5 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com R/W TTH4 Bit4 R/W TTH3 Bit3 R/W TTH2 Bit2 R/W R/W TTH1 TTH0 Bit1 Bit0 I2C Address: 0x26h Reset Value 11001011 © 2016 Kionix – All Rights Reserved Page 49 of 77 TTL e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 This register represents the 8-bit (0d– 255d) jerk low threshold to determine if a tap is detected. The Performance Index (PI) is the jerk signal that is expected to be greater than this threshold and less than the TTH threshold during single and double tap events. The Kionix recommended default value is 26 (0x1Ah). Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W TTL7 Bit7 R/W TTL6 Bit6 FTD R/W TTL5 Bit5 R/W TTL4 Bit4 R/W TTL3 Bit3 R/W TTL2 Bit2 R/W R/W TTL1 TTL0 Bit1 Bit0 I2C Address: 0x27h Reset Value 00011010 This register contains counter information for the detection of any tap event. When the Directional TapTM ODR is 400Hz or less, every count is calculated as 1/ODR delay period. When the Directional TapTM ODR is 800Hz, every count is calculated as 2/ODR delay period. When the Directional TapTM ODR is 1600Hz, every count is calculated as 4/ODR delay period. The Directional TapTM ODR is userdefined per Table 19. In order to ensure that only tap events are detected, these time limits are used. A tap event must be above the performance index threshold for at least the low limit (FTDL0 – FTDL2) and no more than the high limit (FTDH0 – FTDH4). The Kionix recommended default value for the high limit is 0.05 seconds and for the low limit is 0.005 seconds (0xA2h). Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W FTDH3 Bit6 R/W FTDH2 Bit5 R/W FTDH1 Bit4 R/W FTDH0 Bit3 R/W FTDL2 Bit2 R/W R/W FTDL1 FTDL0 Bit1 Bit0 I2C Address: 0x28h Reset Value 10100010 ot R R/W FTDH4 Bit7 N STD This register contains counter information for the detection of a double tap event. When the Directional TapTM ODR is 400Hz or less, every count is calculated as 1/ODR delay period. When the Directional TapTM ODR is 800Hz, every count is calculated as 2/ODR delay period. When the Directional TapTM ODR is 1600Hz, every count is calculated as 4/ODR delay period. The Directional TapTM ODR is userdefined per Table 19. In order to ensure that only tap events are detected, this time limit is used. This register sets the total amount of time that the two taps in a double tap event can be above the PI threshold (TTL). The Kionix recommended default value for STD is 0.09 seconds (0x24h). Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 50 of 77 R/W STD7 Bit7 TLT e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 R/W STD6 Bit6 R/W STD5 Bit5 R/W STD4 Bit4 R/W STD3 Bit3 R/W STD2 Bit2 R/W R/W STD1 STD0 Bit1 Bit0 2 I C Address: 0x29h Reset Value 00100100 This register contains counter information for the detection of a tap event. When the Directional TapTM ODR is 400Hz or less, every count is calculated as 1/ODR delay period. When the Directional TapTM ODR is 800Hz, every count is calculated as 2/ODR delay period. When the Directional TapTM ODR is 1600Hz, every count is calculated as 4/ODR delay period. The Directional TapTM ODR is user-defined per Table 19. In order to ensure that only tap events are detected, this time limit is used. This register sets the total amount of time that the tap algorithm will count samples that are above the PI threshold (TTL) during a potential tap event. It is used during both single and double tap events. However, reporting of single taps on the physical interrupt pin INT1 or INT2 will occur at the end of the TWS. The Kionix recommended default value for TLT is 0.1 seconds (0x28h). Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. TWS R/W TLT6 Bit6 R/W TLT5 Bit5 R/W TLT4 Bit4 R/W TLT3 Bit3 R/W TLT2 Bit2 R/W R/W TLT1 TLT0 Bit1 Bit0 I2C Address: 0x2Ah Reset Value 00101000 R R/W TLT7 Bit7 N ot This register contains counter information for the detection of single and double taps. When the Directional TapTM ODR is 400Hz or less, every count is calculated as 1/ODR delay period. When the Directional TapTM ODR is 800Hz, every count is calculated as 2/ODR delay period. When the Directional TapTM ODR is 1600Hz, every count is calculated as 4/ODR delay period. The Directional TapTM ODR is user-defined per Table 19. It defines the time window for the entire tap event, single or double, to occur. Reporting of single taps on the physical interrupt pin INT1 or INT2 will occur at the end of this tap window. The Kionix recommended default value for TWS is 0.4 seconds (0xA0h). Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W TWS7 Bit7 R/W TWS6 Bit6 R/W TWS5 Bit5 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com R/W TWS4 Bit4 R/W TWS3 Bit3 R/W TWS2 Bit2 R/W R/W TWS1 TWS0 Bit1 Bit0 I2C Address: 0x2Bh Reset Value 10100000 © 2016 Kionix – All Rights Reserved Page 51 of 77 ATH e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 This register sets the threshold for wake-up (motion detect) interrupt is set. The KX022 will ship from the factory with this value set to correspond to a change in acceleration of 0.5g. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W ATH7 Bit7 R/W ATH6 Bit6 R/W ATH5 Bit5 R/W ATH4 Bit4 R/W ATH3 Bit3 R/W ATH2 Bit2 R/W R/W ATH1 ATH0 Bit1 Bit0 2 I C Address: 0x30h Reset Value 00001000 TILT_ANGLE_LL This register sets the low level threshold for tilt angle detection. The KX022 ships from the factory with tilt angle set to a low threshold of 22° from horizontal. A different default tilt angle can be requested from the factory. Note that the minimum suggested tilt angle is 10°. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W TA7 Bit7 R/W TA6 Bit6 R/W TA5 Bit5 R/W TA4 Bit4 R/W TA3 Bit3 R/W TA2 Bit2 R/W TA1 Bit1 R/W TA0 Bit0 Reset Value 00001100 I2C Address: 0x32h TILT_ANGLE_HL R/W HL6 Bit6 R/W HL5 Bit5 R/W HL4 Bit4 R/W HL3 Bit3 R/W HL2 Bit2 R/W HL1 Bit1 R/W HL0 Bit0 Reset Value 00101010 I2C Address: 0x33h N ot R/W HL7 Bit7 R This register sets the high level threshold for tilt angle detection. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 52 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 HYST_SET e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications This register sets the Hysteresis that is placed in between the Screen Rotation states. The KX022 ships from the factory with HYST_SET set to ±15° of hysteresis. A different default hysteresis can be requested from the factory. Note that when writing a new value to this register the current values of RES0 and RES1 must be preserved. These values are set at the factory and must not change. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W RES1 Bit7 R/W RES0 Bit6 LP_CNTL R/W HYST5 Bit5 R/W HYST4 Bit4 R/W HYST3 Bit3 R/W HYST2 Bit2 R/W R/W HYST1 HYST0 Bit1 Bit0 I2C Address: 0x34h Reset Value 00010100 Low Power Control sets the number of samples of accelerometer output to be averaged. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W Reserved Bit7 R/W AVC2 Bit6 R/W AVC1 Bit5 R/W AVC0 Bit4 R/W R/W R/W Reserved Reserved Reserved Bit3 Bit2 Bit1 R/W Reserved Bit0 Reset Value 01001011 I2C Address: 0x35h N ot R AVC – Averaging Filter Control, the default setting is 16 samples averaged 000 = No Averaging 001 = 2 Samples Averaged 010 = 4 Samples Averaged 011 = 8 Samples Averaged 100 = 16 Samples Averaged (default) 101 = 32 Samples Averaged 110 = 64 Samples Averaged 111 = 128 Samples Averaged Reserved – The Reserved bits should remain at their Reset state to avoid unexpected behavior. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 53 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 BUF_CNTL1 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications Read/write control register that controls the buffer sample threshold. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W Bit7 R/W R/W R/W R/W R/W R/W R/W SMP_TH6 SMP_TH5 SMP_TH4 SMP_TH3 SMP_TH2 SMP_TH1 SMP_TH0 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 I2C Address: 0x3Ah Reset Value 00000000 SMP_TH[6:0] Sample Threshold; determines the number of samples that will trigger a watermark interrupt or will be saved prior to a trigger event. When BUF_RES=1, the maximum number of samples is 41; when BUF_RES=0, the maximum number of samples is 84. Buffer Model Sample Function Bypass None FIFO Trigger FILO Table 22: Sample Threshold Operation by Buffer Mode N ot R Stream Specifies how many buffer sample are needed to trigger a watermark interrupt. Specifies how many buffer samples are needed to trigger a watermark interrupt. Specifies how many buffer samples before the trigger event are retained in the buffer. Specifies how many buffer samples are needed to trigger a watermark interrupt. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 54 of 77 BUF_CNTL2 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Read/write control register that controls sample buffer operation. Note that to properly change the value of this register, the PC1 bit in CNTL1 must first be set to “0”. R/W BUFE Bit7 R/W BRES Bit6 R/W BFIE Bit5 R/W 0 Bit4 R/W 0 Bit3 R/W 0 Bit2 R/W R/W BUF_M1 BUF_M0 Bit1 Bit0 I2C Address: 0x3Bh Reset Value 00000000 BUFE controls activation of the sample buffer. BUFE = 0 – sample buffer inactive BUFE = 1 – sample buffer active BRES determines the resolution of the acceleration data samples collected by the sample buffer. BUF_RES = 0 – 8-bit samples are accumulated in the buffer BUF_RES = 1 – 16-bit samples are accumulated in the buffer BFIE buffer full interrupt enable bit BFIE = 0 – buffer full interrupt disabled BFIE = 1 – buffer full interrupt updated in INS2 BUF_M1, BUF_M0 selects the operating mode of the sample buffer per Table 23. BUF_M0 R BUF_M1 0 FIFO 1 Stream 1 0 Trigger 1 1 FILO ot 0 0 N Mode 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com Description The buffer collects 84 sets of 8-bit low resolution values or 41 sets of 16-bit high resolution values and then stops collecting data, collecting new data only when the buffer is not full. The buffer holds the last 84 sets of 8-bit low resolution values or 41 sets of 16-bit high resolution values. Once the buffer is full, the oldest data is discarded to make room for newer data. When a trigger event occurs, the buffer holds the last data set of SMP_TH[6:0] samples before the trigger event and then continues to collect data until full. New data is collected only when the buffer is not full. The buffer holds the last 84 sets of 8-bit low resolution values or 41 sets of 16-bit high resolution values. Once the buffer is full, the oldest data is discarded to make room for newer data. Reading from the buffer in this mode will return the most recent data first. Table 23: Selected Buffer Mode © 2016 Kionix – All Rights Reserved Page 55 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 BUF_STATUS_1 This register reports the status of the sample buffer. R R R R R R R R SMP_LEV7 SMP_LEV6 SMP_LEV5 SMP_LEV4 SMP_LEV3 SMP_LEV2 SMP_LEV1 SMP_LEV0 Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 I2C Address: 0x3Ch SMP_LEV[7:0] Sample Level; reports the number of data bytes that have been stored in the sample buffer. When BUF_RES=1, this count will increase by 6 for each 3-axis sample in the buffer; when BUF_RES=0, the count will increase by 3 for each 3-axis sample. If this register reads 0, no data has been stored in the buffer. BUF_STATUS_2 This register reports the status of the sample buffer trigger function. R BUF_TRIG Bit7 R 0 Bit6 R 0 Bit5 R 0 Bit4 R 0 Bit3 R 0 Bit2 R R 0 0 Bit1 Bit0 I2C Address: 0x3Dh R BUF_TRIG reports the status of the buffer’s trigger function if this mode has been selected. When using trigger mode, a buffer read should only be performed after a trigger event. BUF_CLEAR ot Latched buffer status information and the entire sample buffer are cleared when any data is written to this register. N W X Bit7 W X Bit6 W X Bit5 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com W X Bit4 W X Bit3 W X Bit2 W W X X Bit1 Bit0 I2C Address: 0x3Eh © 2016 Kionix – All Rights Reserved Page 56 of 77 BUF_READ e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Buffer output register. R X Bit7 R X Bit6 R X Bit5 R X Bit4 R X Bit3 R X Bit2 R R X X Bit1 Bit0 I2C Address: 0x3Fh Note: new data is not being written to the buffer during the buffer read operation. Thus, care must be taken when reading from the buffer. If data loss is not desired, the buffer read operation should be completed within ODR clock cycle. SELF_TEST When 0xCA is written to this register, the MEMS self-test function is enabled. Electrostatic-actuation of the accelerometer, results in a DC shift of the X, Y and Z axis outputs. Writing 0x00 to this register will return the accelerometer to normal operation. **Note, this is a write-only register. Read back value from this register will always be 0x00. W 1 Bit6 W 0 Bit5 W 0 Bit4 W 1 Bit3 W 0 Bit2 W W 1 0 Bit1 Bit0 I2C Address: 0x60h Reset Value 00000000 N ot R W 1 Bit7 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 57 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications Embedded Applications Orientation Detection Feature The Orientation detection feature of the KX022 will report changes in face up, face down, ± vertical and ± horizontal orientation. This intelligent embedded algorithm considers very important factors that provide accurate orientation detection from low cost tri-axis accelerometers. Factors such as: hysteresis, device orientation angle and delay time are described below as these techniques are utilized inside the KX022 Hysteresis Orientation X Acceleration (g) Y Acceleration (g) 0°/360° -0.5 < ax < 0.5 ay > 0.866 90° ax > 0.866 -0.5 < ay < 0.5 180° -0.5 < ax < 0.5 ay < -0.866 270° ax < -0.866 -0.5 < ay < 0.5 Table 24: Acceleration at the four orientations with ± 15° of hysteresis N ot R A 45° tilt angle threshold seems like a good choice because it is halfway between 0° and 90°. However, a problem arises when the user holds the device near 45°. Slight vibrations, noise and inherent sensor error will cause the acceleration to go above and below the threshold rapidly and randomly, so the screen will quickly flip back and forth between the 0° and the 90° orientations. This problem is avoided in the KX022 by choosing a 30° threshold angle. With a 30° threshold, the screen will not rotate from 0° to 90° until the device is tilted to 60° (30° from 90°). To rotate back to 0°, the user must tilt back to 30°, thus avoiding the screen flipping problem. This example essentially applies ± 15° of hysteresis in between the four screen rotation states. Table 24 shows the acceleration limits implemented for  T =30°. The KX022 allows the user to change the amount of hysteresis in between the four screen rotation states. By simply writing to the HYST_SET register, the user can adjust the amount of hysteresis up to ± 45°. The plot in Figure 8 shows the typical amount of hysteresis applied for a given digital count value of HYST_SET. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 58 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 HYST_SET vs Hysteresis 50 45 Hysteresis (+/- degrees) 40 35 30 25 Hysteresis 20 15 10 5 0 0 5 10 15 20 25 30 HYST_SET Value (Counts) Figure 8: HYST_SET vs Hysteresis Device Orientation Angle (aka Tilt Angle) N ot R To ensure that horizontal and vertical device orientation changes are detected, even when it isn’t in the ideal vertical orientation – where the angle θ in Figure 9 is 90°, the KX022 considers device orientation angle in its algorithm. Angle  Figure 9: Device Orientation Angle As the angle in Figure 9 is decreased, the maximum gravitational acceleration on the X-axis or Y-axis will also decrease. Therefore, when the angle becomes small enough, the user will not be able to make the screen orientation change. When the device orientation angle approaches 0° (device is flat on a 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 59 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications desk or table), ax = ay = 0g, az = +1g, and there is no way to determine which way the screen should be oriented, the internal algorithm determines that the device is in either the face-up or face-down orientation, depending on the sign of the z-axis. The KX022 will only change the screen orientation when the orientation angle is above the factory-defaulted/user-defined threshold set in the TILT_ANGLE_LL register. Equation 2 can be used to determine what value to write to the TILT_ANGLE_LL register to set the device orientation angle. The value for TILT_ANGLE_HL is preset at the factory but can be adjusted in special cases (e.g. to reduce the effect of transient g-variation such as when device is being moved rather than just being rotated). TILT_ANGLE_LL (counts) = sin θ * (32 (counts/g)) Equation 2: Tilt Angle Threshold Tilt Timer The 8-bit register, TILT_TIMER can be used to qualify changes in orientation. The KX022 does this by incrementing a counter with a size that is specified by the value in TILT_TIMER for each set of acceleration samples to verify that a change to a new orientation state is maintained. A user defined output data rate (ODR) determines the time period for each sample. Equation 3 shows how to calculate the TILT_TIMER register value for a desired delay time. TILT_TIMER (counts) = Delay Time (sec) x ODR (Hz) N ot R Equation 3: Tilt Position Delay Time 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 60 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications Motion Interrupt Feature Description The Motion interrupt feature of the KX022 reports qualified changes in the high-pass filtered acceleration based on the Wake Up (ATH) threshold. If the high-pass filtered acceleration on any axis is greater than the user-defined wake up threshold (ATH), the device has transitioned from an inactive state to an active state. Equation 4 shows how to calculate the ATH register value for a desired wake up threshold. Note that this calculation varies based on the configured g-range of the part. ATH (counts) = Wake Up Threshold (g) x 16 (counts/g) Equation 4: Wake Up Threshold An 8-bit raw unsigned value represents a counter that permits the user to qualify each active/inactive state change. Note that each WUFC Timer count qualifies 1 (one) user-defined ODR period (OWUF). Equation 5 shows how to calculate the WUFC register value for a desired wake up delay time. WUFC (counts) = Wake Up Delay Time (sec) x OWUF (Hz) Equation 5: Wake Up Delay Time R The latched motion interrupt response algorithm works as following: while the part is in inactive state, the algorithm evaluates differential measurement between each new acceleration data point with the preceding one and evaluates it against the ATH threshold. When the differential measurement is greater than ATH threshold, the wakeup counter starts the count. Differential measurements are now calculated based on the difference between the current acceleration and the acceleration when the counter started. The part will report that motion has occurred at the end of the count assuming each differential measurement has remained above the threshold. If at any moment during the count the differential measurement falls below the threshold, the counter will stop the count and the part will remain in inactive state. N ot To illustrate how the algorithm works, consider the Figure 10 below that shows the latched response of the motion detection algorithm with WUF Timer (WUFC) set to 10 counts. Note how the difference between the acceleration sample marked in red and the one marked in green resulted in a differential measurements represented with orange bar being above the WUF threshold. At this point, the counter begins to count number of counts stored in WUFC register and the wakeup algorithm will evaluate the difference between each new acceleration measurement and the measurement marked in green that will remain a reference measurement for the duration of the counter count. At the end of the count, assuming all differential measurements were larger than WUF threshold, as is the case in the example showed in Figure 10, a motion event will be reported. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 61 of 77 Figure 10: Latched Motion Interrupt Response N ot R e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 62 of 77 PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications Directional Tap Detection Feature Description The Directional Tap Detection feature of the KX022 recognizes single and double tap inputs and reports the acceleration axis and direction that each tap occurred. Eight performance parameters, as well as a userselectable ODR are used to configure the KX022 for a desired tap detection response. Performance Index The Directional TapTM detection algorithm uses low and high thresholds to help determine when a tap event has occurred. A tap event is detected when the previously described jerk summation exceeds the low threshold (TTL) for more than the tap detection low limit, but less than the tap detection high limit as contained in FTD. Samples that exceed the high limit (TTH) will be ignored. Figure 11 shows an example of a single tap event meeting the performance index criteria. Calculated Performance Index PI 180 : Sampled Data 160 140 100 R jerk (counts) 120 ot 80 60 N 40 TTL 20 0 3.14 3.15 3.16 3.17 3.18 time(sec) 3.19 3.2 3.21 Figure 11: Jerk Summation vs Threshold 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 63 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Single Tap Detection The latency timer (TLT) sets the time period that a tap event will only be characterized as a single tap. A second tap has to occur outside of the latency timer. If a second tap occurs inside the latency time, it will be ignored as it occurred too quickly. The single tap will be reported at the end of the TWS. Figure 12 shows a single tap event meeting the PI, latency and window requirements. Calculated Performance Index 160 PI 140 TWS 120 jerk (counts) 100 TLT 80 60 R 40 ot TTL 20 N 0 2.1 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com 2.2 2.3 2.4 2.5 2.6 2.7 time(sec) 2.8 2.9 3 3.1 Figure 12: Single Directional TapTM Timing © 2016 Kionix – All Rights Reserved Page 64 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Double Tap Detection N ot R An event can be characterized as a double tap if the second tap crosses up the performance index (TTL) inside the TWS period and ends outside the TDTC. This means that the TDTC determines the minimum time separation that must exist between the two taps of a double tap event. Similar to the single tap, the first tap event must exceed the performance index for the time limit contained in FTD. Also, the duration when the first and second events combined exceed the performance index should not exceed STD. The double tap will be reported at the end of the second TLT. Figure 13 shows a double tap event meeting the PI, latency and window requirements. Figure 13: Double Directional TapTM Timing 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 65 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Sample Buffer Feature Description The sample buffer feature of the KX022 accumulates and outputs acceleration data based on how it is configured. There are 4 buffer modes available, and samples can be accumulated at either low (8-bit) or high (16-bit) resolution. Acceleration data is collected at the ODR specified by OSA[3:0] in the ODCNTL register. Each buffer mode accumulates data, reports data, and interacts with status indicators in a slightly different way. FIFO Mode Data Accumulation Sample collection stops when the buffer is full. Data Reporting Data is reported with the oldest byte of the oldest sample first (X_L or X based on resolution). Status Indicators A watermark interrupt occurs when the number of samples in the buffer reaches the Sample Threshold. The watermark interrupt stays active until the buffer contains less than this number of samples. This can be accomplished through clearing the buffer or explicitly reading greater than SMPX samples (calculated with Equation 6). BUF_RES=1: SMPX = SMP_LEV[7:0] / 6 – SMP_TH[6:0] Equation 6: Samples Above Sample Threshold ot R BUF_RES=0: SMPX = SMP_LEV[7:0] / 3 – SMP_TH[6:0] N Stream Mode Data Accumulation Sample collection continues when the buffer is full; older data is discarded to make room for newer data. Data Reporting Data is reported with the oldest sample first (uses FIFO read pointer). Status Indicators A watermark interrupt occurs when the number of samples in the buffer reaches the Sample Threshold. The watermark interrupt stays active until the buffer contains less than this number of samples. This can be accomplished through clearing the buffer or explicitly reading greater than SMPX samples (calculated with Equation 6). 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 66 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Trigger Mode Data Accumulation When a physical interrupt is caused by one of the digital engines, or when a logic high signal occurs on the TRIG pin, the trigger event is asserted and SMP_TH[6:0] samples prior to the event are retained. Sample collection continues until the buffer is full. Data Reporting Data is reported with the oldest sample first (uses FIFO read pointer). Status Indicators When a physical interrupt occurs and there are at least SMP_TH[6:0] samples in the buffer, BUF_TRIG in BUF_STATUS_2 is asserted. FILO Mode R Data Accumulation Sample collection continues when the buffer is full; older data is discarded to make room for newer data. Data Reporting Data is reported with the newest byte of the newest sample first (Z_H or Z based on resolution). Status Indicators A watermark interrupt occurs when the number of samples in the buffer reaches the Sample Threshold. The watermark interrupt stays active until the buffer contains less than this number of samples. This can be accomplished through clearing the buffer or explicitly reading greater than SMPX samples (calculated with Equation 6). N ot Buffer Operation The following diagrams illustrate the operation of the buffer conceptually. Actual physical implementation has been abstracted to offer a simplified explanation of how the different buffer modes operate. Figure 14 represents a high-resolution 3-axis sample within the buffer. Figure 15 - Figure 23 represent a 10-sample version of the buffer (for simplicity), with Sample Threshold set to 8. Regardless of the selected mode, the buffer fills sequentially, one byte at a time. It it important to keep in mind that new data is not being written to the buffer during the buffer read operation. Thus, care must be taken when reading from the buffer. If data loss is not desired, the buffer read operation should be completed within ODR clock cycle. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 67 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Figure 14 shows one 6-byte data sample. Note the location of the FILO read pointer versus that of the FIFO read pointer. buffer write pointer -- Index 0 1 2 3 4 5 6 Byte X_L X_H Y_L Y_H Z_L Z_H -- FIFO read pointer -- FILO read pointer Figure 14: One Buffer Sample R Regardless of the selected mode, the buffer fills sequentially, one sample at a time. Note in Figure 15 the location of the FILO read pointer versus that of the FIFO read pointer. The buffer write pointer shows where the next sample will be written to the buffer. N ot buffer write pointer → Index Sample 0 Data0 1 Data1 2 Data2 ← FIFO read pointer ← FILO read pointer 3 4 5 6 7 ← Sample Threshold 8 9 Figure 15: Buffer Filling 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 68 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 The buffer continues to fill sequentially until the Sample Threshold is reached. Note in Figure 16 the location of the FILO read pointer versus that of the FIFO read pointer. buffer write pointer → Index Sample 0 Data0 1 Data1 2 Data2 3 Data3 4 Data4 5 Data5 6 Data6 7 ← FIFO read pointer ← FILO read pointer ← Sample Threshold 8 9 Figure 16: Buffer Approaching Sample Threshold N ot R In FIFO, Stream, and FILO modes, a watermark interrupt is issued when the number of samples in the buffer reaches the Sample Threshold. In trigger mode, this is the point where the oldest data in the buffer is discarded to make room for newer data. buffer write pointer → Index 0 1 2 3 4 5 6 7 8 9 Sample Data0 Data1 Data2 Data3 Data4 Data5 Data6 Data7 ← FIFO read pointer ← Sample Threshold/FILO read pointer Figure 17: Buffer at Sample Threshold 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 69 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 In trigger mode, data is accumulated in the buffer sequentially until the Sample Threshold is reached. Once the Sample Threshold is reached, the oldest samples are discarded when new samples are collected. Note in Figure 18 how Data0 was thrown out to make room for Data8. Trigger write pointer → Index 0 1 2 3 4 5 6 7 8 9 Sample Data1 Data2 Data3 Data4 Data5 Data6 Data7 Data8 ← Trigger read pointer ← Sample Threshold Figure 18: Additional Data Prior to Trigger Event N ot R After a trigger event occurs, the buffer no longer discards the oldest samples, and instead begins accumulating samples sequentially until full. The buffer then stops collecting samples, as seen in Figure 19. This results in the buffer holding SMP_TH[6:0] samples prior to the trigger event, and SMPX samples after the trigger event. Index 0 1 2 3 4 5 6 Sample Data1 Data2 Data3 Data4 Data5 Data6 Data7 7 8 9 Data8 Data9 Data10 ← Trigger read pointer ← Sample Threshold Figure 19: Additional Data After Trigger Event 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 70 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 In FIFO, Stream, FILO, and Trigger (after a trigger event has occurred) modes, the buffer continues filling sequentially after the Sample Threshold is reached. Sample accumulation after the buffer is full depends on the selected operation mode. FIFO and Trigger modes stop accumulating samples when the buffer is full, and Stream and FILO modes begin discarding the oldest data when new samples are accumulated. Index Sample 0 Data0 1 2 3 4 5 6 7 8 9 Data1 Data2 Data3 Data4 Data5 Data6 Data7 Data8 Data9 ← FIFO read pointer ← Sample Threshold ← FILO read pointer Figure 20: Buffer Full N ot R After the buffer has been filled in FILO or Stream mode, the oldest samples are discarded when new samples are collected. Note in Figure 21 how Data0 was thrown out to make room for Data10. Index 0 1 2 3 4 5 6 Sample Data1 Data2 Data3 Data4 Data5 Data6 Data7 7 8 9 Data8 Data9 Data10 ← FIFO read pointer ← Sample Threshold ← FILO read pointer Figure 21: Buffer Full – Additional Sample Accumulation in Stream or FILO Mode 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 71 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 In FIFO, Stream, or Trigger mode, reading one sample from the buffer will remove the oldest sample and effectively shift the entire buffer contents up, as seen in Figure 22. buffer write pointer → Index Sample 0 Data1 1 Data2 2 Data3 3 Data4 4 Data5 5 Data6 6 Data7 7 Data8 8 Data9 ← FIFO read pointer ← Sample Threshold ← FILO read pointer 9 Figure 22: FIFO Read from Full Buffer N ot R In FILO mode, reading one sample from the buffer will remove the newest sample and leave the older samples untouched, as seen in Figure 23. buffer write pointer → Index 0 1 2 3 4 5 6 Sample Data0 Data1 Data2 Data3 Data4 Data5 Data6 7 Data7 8 9 Data8 ← FIFO read pointer ← Sample Threshold ← FILO read pointer Figure 23: FILO Read from Full Buffer 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 72 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Revision History 2.0 3.0 4.0 5.0 6.0 7.0 8.0 9.0 10.0 11.0 DATE 12-Sep-2013 02-Oct-2013 19-Nov-2013 03-Dec-2013 08-Jan-2014 16-Jan-2014 05-Sep-2014 16-Sep-2014 10-Oct-2014 08-Dec-2014 01-Apr-2015 09-Sep-2015 05-Apr-2016 N ot 12.0 DESCRIPTION Initial Release Added LP_CNTL Accelerometer Output Averaging Register, Updated Test Spec limits Table 5 and I2C timing Table 8 Added reference to FlexSet™ Performance Optimization, Updated reference to OSA in ODCNTL for XOUT_L register. Updated default values for TSPP, TSCP, ODCNTL Added Min and Max Self-Test limits to Table 1 Improved high resolution and low power mode descriptions, Corrected Test specification limits Table 5. Revised Package Dimensions. Revised Accelerometer Outputs table Updated Package Drawing Revised ODR settings and current profile Added Power-On procedure details. Updated Figure 1. Updated Motion Interrupt plot and feature. Updated Double-Tap Detection plot and description. Fixed factory value set for TILT_ANGLE_LL. Updated Table 12: Acceleration (g) Calculation Updated Current Profile plot and table Updated POR section Updated RoHS compliance. Added REACH compliance. Updated Reading from / Writing To KX023 8-bit Register section Updated I2C Timing diagram Updated I2C address table Added note to Writing to 8-bit Register I2C section Updated Wake Up Threshold equation Updated 3-Wire and 4-Wire Read and Write Registers Added Notice section Fixed References to SMPX eaquation calculations Added note in Reading from 8-bit Register section Changed VSS to GND reference in the I2C Address Table / Figure Updated R / W status for SELF_TEST, BUF_STATUS_1, 2, BUF_READ, BUF_CLEAR registers. Changed minimum operating voltage in Product Description to 1.71V (from 1.8V) Updated Pin Description Table Updated Block Diagram and product photo Updated Sample Buffer Feature description Updated Trigger Buffer description Fixed bit name (SMP>SMP_TH) in BUF_CNTL1 Fixed reference to CNTL1 from CTRL_REG1 Fixed COTC bit description in CNTL2 register Added “Positive” to the Self Test Spec in Mechanical Specifications Table Updated name for RES=1 mode in CNTL1 register Fixed register name from BUF_STATUS_REG2 to BUF_STATUS_2 in Trigger Mode Added note under mechanical spec to change STPOL bit to 1 for Positive Self Test Added note to avoid changing reserved bits from their reset value where applicable. Added note buffer write is blocked during buffer read operation. Updated Intelectual Property Section of the Notice R REVISION 1.0 1.1 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 73 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 N ot R "Kionix" is a registered trademark of Kionix, Inc. Products described herein are protected by patents issued or pending. No license is granted by implication or otherwise under any patent or other rights of Kionix. The information contained herein is believed to be accurate and reliable but is not guaranteed. Kionix does not assume responsibility for its use or distribution. Kionix also reserves the right to change product specifications or discontinue this product at any time without prior notice. This publication supersedes and replaces all information previously supplied. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 74 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Notice Precaution on using KIONIX Products 1. Our Products are designed and manufactured for application in ordinary electronic equipment (such as AV equipment, OA equipment, telecommunication equipment, home electronic appliances, amusement equipment, etc.). If you intend to use our Products in devices requiring extremely high reliability (such as medical equipment (Note 1), transport equipment, traffic equipment, aircraft/spacecraft, nuclear power controllers, fuel controllers, car equipment including car accessories, safety devices, etc.) and whose malfunction or failure may cause loss of human life, bodily injury or serious damage to property (“Specific Applications”), please consult with the KIONIX sales representative in advance. Unless otherwise agreed in writing by KIONIX in advance, KIONIX shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of any KIONIX’s Products for Specific Applications. (Note1) Medical Equipment Classification of the Specific Applications JAPAN USA EU CHINA CLASSⅢ CLASSⅡb CLASSⅢ CLASSⅢ CLASSⅣ CLASSⅢ N ot R 2. KIONIX designs and manufactures its Products subject to strict quality control system. However, semiconductor products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which a failure or malfunction of our Products may cause. The following are examples of safety measures: a) Installation of protection circuits or other protective devices to improve system safety b) Installation of redundant circuits to reduce the impact of single or multiple circuit failure 3. Our Products are designed and manufactured for use under standard conditions and not under any special or extraordinary environments or conditions, as exemplified below. Accordingly, KIONIX shall not be in any way responsible or liable for any damages, expenses or losses arising from the use of any KIONIX’s Products under any special or extraordinary environments or conditions. If you intend to use our Products under any special or extraordinary environments or conditions (as exemplified below), your independent verification and confirmation of product performance, reliability, etc., prior to use, must be necessary: a) Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents b) Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust c) Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 d) Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves e) Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items f) Sealing or coating our Products with resin or other coating materials g) Use of our Products without cleaning residue of flux (even if you use no-clean type fluxes, cleaning residue of flux is recommended); or Washing our Products by using water or water-soluble cleaning agents for cleaning residue after soldering h) Use of the Products in places subject to dew condensation 4. The Products are not subject to radiation-proof design. 5. Please verify and confirm characteristics of the final or mounted products in using the Products. 6. In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse. is applied, confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 75 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 power exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 7. De-rate Power Dissipation (Pd) depending on ambient temperature (Ta). When used in sealed area, confirm the actual ambient temperature. 8. Confirm that operation temperature is within the specified range described in the product specification. 9. KIONIX shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in this document. Precaution for Mounting / Circuit board design 1. When a highly active halogenous (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product performance and reliability. 2. In principle, the reflow soldering method must be used; if flow soldering method is preferred, please consult with the KIONIX representative in advance. For details, please refer to KIONIX Mounting specification. Precautions Regarding Application Examples and External Circuits 1. If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the characteristics of the Products and external components, including transient characteristics, as well as static characteristics. 2. You agree that application notes, reference designs, and associated data and information contained in this document are presented only as guidance for Products use. Therefore, in case you use such information, you are solely responsible for it and you must exercise your own independent verification and judgment in the use of such information contained in this document. KIONIX shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of such information. Precaution for Electrostatic ot R This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron, isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control). Precaution for Storage / Transportation N 1. Product performance and soldered connections may deteriorate if the Products are stored in the places where: a) the Products are exposed to sea winds or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 b) the temperature or humidity exceeds those recommended by KIONIX c) the Products are exposed to direct sunshine or condensation d) the Products are exposed to high Electrostatic 2. Even under KIONIX recommended storage condition, solderability of products out of recommended storage time period may be degraded. It is strongly recommended to confirm solderability before using Products of which storage time is exceeding the recommended storage time period. 3. Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads may occur due to excessive stress applied when dropping of a carton. 4. Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of which storage time is exceeding the recommended storage time period. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 76 of 77 e N co ew m m D es en ig de ns d fo r ± 2g / 4g / 8g Tri-axis Digital Accelerometer Specifications PART NUMBER: KX022-1020 Rev. 12.0 5-Apr-16 Precaution for Product Label QR code printed on KIONIX Products label is for KIONIX’s internal use only. Precaution for Disposition When disposing Products please dispose them properly using an authorized industry waste company. Precaution for Foreign Exchange and Foreign Trade act Since our Products might fall under controlled goods prescribed by the applicable foreign exchange and foreign trade act, please consult with KIONIX representative in case of export. Precaution Regarding Intellectual Property Rights 1. All information and data including but not limited to application example contained in this document is for reference only. KIONIX does not warrant that foregoing information or data will not infringe any intellectual property rights or any other rights of any third party regarding such information or data. 2. KIONIX shall not be in any way responsible or liable for infringement of any intellectual property rights or other damages arising from use of such information or data. 3. No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of KIONIX or any third parties with respect to the Products or the information contained in this document. Provided, however, that KIONIX will not assert its intellectual property rights or other rights against you or your customers to the extent necessary to manufacture or sell products containing the Products, subject to the terms and conditions herein. Other Precaution ot R 1. This document may not be reprinted or reproduced, in whole or in part, without prior written consent of KIONIX. 2. The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written consent of KIONIX. 3. In no event shall you use in any way whatsoever the Products and the related technical information contained in the Products or this document for any military purposes, including but not limited to, the development of massdestruction weapons. 4. The proper names of companies or products described in this document are trademarks or registered trademarks of KIONIX, its affiliated companies or third parties. General Precaution N 1. Before you use our Products, you are requested to carefully read this document and fully understand its contents. KIONIX shall not be in any way responsible or liable for failure, malfunction or accident arising from the use of any KIONIX’s Products against warning, caution or note contained in this document. 2. All information contained in this document is current as of the issuing date and subject to change without any prior notice. Before purchasing or using KIONIX’s Products, please confirm the latest information with a KIONIX sales representative. 3. The information contained in this document is provided on an “as is” basis and KIONIX does not warrant that all information contained in this document is accurate and/or error-free. KIONIX shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties resulting from inaccuracy or errors of or concerning such information. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax:607-257-1146 www.kionix.com - info@kionix.com © 2016 Kionix – All Rights Reserved Page 77 of 77
KX022-1020-PR 价格&库存
很抱歉,暂时无法提供与“KX022-1020-PR”相匹配的价格&库存,您可以联系我们找货
