CAB-14043
CAB-14043
    SPARKFUNELECTRONICS
    LIDAR-LITEACCESSORYCABLE
CAB-14043 数据手册
LIDAR‐Lite Accessory Cable DEV-14043 RoHS Description: This is the same accessory cable found in the LIDAR-Lite v3. The LIDAR-Lite Accessory Cable is terminated with a simple 6-pin JST at one end and a bare wire pigtail at the other. You can use this cable as a replacement to the one you are currently using, as a backup in case of damage, or if you just need a second one. The LIDAR-Lite Accessory Cable is 200mm (~7.8in) long with specific pin-outs found on the second page of the Operation & Technical Manual below. SparkFun Electronics ®
CAB-14043 价格&库存
很抱歉,暂时无法提供与“CAB-14043”相匹配的价格&库存,您可以联系我们找货
