26800B-535
26800B-535
    AVENTOOLS(艾文)
    BOOM STAND WITH MOUNTING POST
26800B-535 数据手册
Aven Inc. 4595 Platt Rd. Ann Arbor, MI 48108 Phone: 734.973.0099 Email: info@aventools.com • Web Address: www.aventools.com All Categories > Optical Inspection Tools > Microscope Accessories > Eyepiece Lenses and Rubber Eye Guards > Dual Arm Ball Bearing Boom Stands with Mounting Post > Item # 26800B-535 Item # 26800B-535, Standard Dual Arm Ball Bearing Boom Stand with Mounting Post larger image Features · Specifications Features z z z z z z z z Stability of the standard boom stand but with ultra smooth movement of a ball bearing slide Great for inspection applications where magnification adjustment and the ability to move across a specimen are important Heavy duty base: 11" x 10" x 1.25" (285 x 260 x 32 mm), 21 lb Main Vertical post: 15" (380 mm) long, Extension post: 9" (225 mm) long. OD 1 1/2" (37 mm) for a total post length of 24" Horizontal Post 22.5" (570 mm) long from end to end. Safety Clamp included Post with Tilt Feature for Focus Mount SCW-PA included Specifications Base 11 x 10 x 1.25 in 285 x 260 x 32 mm Vertical Post 15 in 380 mm Horizontal Post 22.5 in 570 mm Extension Post 9 in 225 mm Diameter 1 1/2 in 37 mm Length 24 in Base Weight 21 lb Weight 43 lb
26800B-535
在PDF文档中,物料型号为:TI LMR33630,器件简介为:一款同步降压DC/DC控制器,其主要特性包括可编程的开关频率、可编程的软启动和输出电压可调。
引脚分配为:1-VIN、2-EN/UVLO、3-GND、4-LX、5-FB、6-SW、7-VOS、8-Vout、9-RT/SS、10-INTV、11-PG/FLT、12-PG/FLT、13-RT/SS、14-Vin。
参数特性包括:输入电压范围为4.5V至60V,输出电压范围为0.6V至55V,连续输出电流可达3A。
功能详解为:支持多种反馈选项、可编程的开关频率和软启动功能。
应用信息为:适用于需要高效率、高密度电源转换的应用场景。
封装信息为:采用4mmx4mm的QFN封装。
26800B-535 价格&库存
很抱歉,暂时无法提供与“26800B-535”相匹配的价格&库存,您可以联系我们找货
