26700-209
26700-209
    AVENTOOLS(艾文)
    MIGHTY SCOPE 5M 10X-200X
26700-209 数据手册
Aven Inc. 4595 Platt Rd. Ann Arbor, MI 48108 Phone: 734.973.0099 Email: info@aventools.com • Web Address:www.aventools.com Item # 26700-209, Mighty Scope Digital 5M - 10-200x Mighty Scope Digital 5M - 10-200x   Wide range of uses The Mighty Scope is great for science and engineering work, dermatology, detailed repair, assembly and quality control (i.e. electronics, mechanical, etc), hobbies &collecting (coin, stamp, watch, jewelry, etc.), law enforcement (counterfeit ID, crime lab, etc), entertainment and much more.   Features     •  Easy to use, 6-LED brightness controllable hand-held USB digital microscope.   •  Adjustable magnification from 10x–200x, all in one compact lens.   •  Adjustable magnification from 10x–200x, all in one compact lens.   •  Active Pixel Technology produces sharp images and accurate color reproduction.   •  Professional measurement software to capture pictures, record video, freeze images and compare live and existing pictures.   •  Software compare mode supports dual microscope image comparison mode.   •  Microtouch Shutter trigger allows for convenient image capture when in hand held mode or mounted on a stand.   •  Includes an adjustable metal stand.    Add to Cart and then select optional accessories  ·  SPECIFICATIONS ·  OPTIONS SPECIFICATIONS Image Sensor Effective Pixels (HxV)  1/4" Color CMOS  5.0M Signal Output  USB 2.0 Magnification  10x to 200x Gain Control  Auto Gain Control Snap Shot Mode  Hardware &Software Controllable White Balance  Automatic Power Source  5 VDC through USB port 5/7/2012 | Page 1 of 2 O/S  Windows XP, SP2 &Vista &7 Power Consumption  110 mA (AVG) LED Light Type  6 White LEDs Frame Rate Working Distance Weight  15 fps (2048 x 1536) 30 fps (1024x768) 30 fps (640x480)  At 10x, 112 mm At 20x, 42 mm At 30x, 19 mm At 40x, 8.5 mm  1.55 lb OPTIONS Stands  26700-210, Mighty Scope Boom Stand  26700-213, Cradle Stand  26700-212, Mighty Scope Flex Stand  5/7/2012 | Page 2 of 2
26700-209 价格&库存
很抱歉,暂时无法提供与“26700-209”相匹配的价格&库存,您可以联系我们找货
