26800B-384
26800B-384
    AVENTOOLS(艾文)
    Microscope, Stereo Zoom (Binocular) 6.7x ~ 50x LED
26800B-384 数据手册
Note: 0.5x Auxiliary Lens cannot be used on this SPZ series body with stand P, PF, T and TL SPZ-50 Stereo Zoom Microscope on Stand P with Diffuse Axial LED Illuminator Super Sharp 3D Images without Hot Spots and Glare SPZ-50 Stereo Zoom Microscope on Stand P with Diffuse Axial LED Illuminator The ideal scope configuration with the Diffuse Axial LED Illuminator for viewing highly specular and shiny surfaces offering flat, even, shadow free illumination across the entire surface, without hot spots and glare. The SPZ-50 offers best in class zoom ratio, crisp clear 3D images, 6.7x to 50x continuous zoom (max 200x with optional lenses) and wide field of view using standard 10x eyepieces. The eyepieces provide a constant working distance of 45mm/1.77” for comfortable viewing. Ideal for the inspection of small parts, the SPZ is mounted on a Pole stand with focus mount. All of which helps to make this system ideal for virtually any investigative or inspection application. BODY TYPE Binocular, 360 rotatable, 45 inclined eyepiece tube EYEPIECES Two 10x(FN23) eyepieces supplied with microscope body. Optional 15x(FN15) and 20x(FN11.4) available to extend magnification range MAGNIFICATION 6.7x to 50x, Max 180x with 20x eyepieces WORKING DISTANCE INTERPUPILLARY DISTANCE 52mm(2.05”) to 75mm (2.95”) DIOPTER ADJUSTMENT +5.6D-7.2D on both eyepieces OPTICAL SYSTEM Aven microscopes reflect the clear differences of Japanese-engineered instruments designed and manufactured to industry-leading standards. High-grade optical glass and a straight light path provide maximum clarity and undistorted viewing. Greenough ZOOM RATIO 7.46:1 STAND TYPE Pole Stand with Focus Mount BASE DIMENSIONS/WEIGHT Features POLE/TRACK HEIGHT • Total Magnification of 6.7X to 50X at 45mm/1.77” working distance, Max 200X with 20X eyepieces. • Optional equipment 15X and 20X eyepieces available. • Diffuse Axial LED Illuminator mounts to the objective of the Microscope to eliminate hots spots and glare. • Mounted to a pole type stand with focus mount, the most lightweight and compact option, provides a small footprint where bench space is limited. • Stand comes with rack & pinion focus mount SCW-PA with coarse and fine focus knobs. sales@aveninc.com 45mm (1.77”) 220mm x 284mm x 15mm/8.66”x11.18”x 0.59” 13.61 kg/30lbs 250mm/9.84” FOCUS MOUNT Course and fine focus ILLUMINATION Diffuse Axial LED Illuminator ACCESSORIES INCLUDED Dust Cover (Rubber Eye Guards),Tension Control Pin OPTIONAL ACCESSORIES 15x and 20x Eyepieces, Protective Lens Cover WEIGHT 36.3 lbs PACKAGE CONTENTS SPZ-50 Body (SPZ-50); Pole Stand with Focus Mount (26800B-511); Diffuse Axial LED Illuminator (26200B-220). Part # Description 26800B-384 SPZ-50 Stereo Zoom Microscope on Stand P with Diffuse Axial LED Illuminator aveninc.com 734.973.0099
26800B-384 价格&库存
很抱歉,暂时无法提供与“26800B-384”相匹配的价格&库存,您可以联系我们找货
