26700-400
26700-400
    AVENTOOLS(艾文)
    MICRO DGTL 15X~270X 534X W/LIGHT
26700-400 数据手册
Cyclops Digital Microscope Products  Aven's Complete Product Line : Microscopy and Inspection : Digital Microscopes : Cyclops Digital Microscope Cyclops Digital Microscope • Product # 26700-400  Rating: Product # : 26700-400 Overview : Cyclops digital microscope with built in HDMI and USB outputs. 15x-270x magnification in HDMI mode on a 21.5" HD monitor and maximum of 534x magnification in USB mode. 4x (included) and 10x (optional) interchangeable objective lenses. 30 LEDs with brightness control provides illumination to meet a variety of application needs. Heavy duty metal stand, remote and cables included. Unit comes standard with 4x objective lens. Description Features Specs Video Cyclops Digital Microscope Image Sensor 1/4” Color CMOS Effective Pixels 5M Signal Output HDMI and USB Video Format AVI Frames Per Second 30fps Magnification See Magnification Tables Gain Control Automatic Snap Shot Mode Hardware & Software controls White Balance Manual and Automatic Power Source DC 5V/2A input; Cable length 180cm O/S Windows 7 & 8 Power Consumption 110mA (AVG) LED Lighting 30 White LEDs with brightness & sector control Dimensions 106 x 152mm Weight 0.70lb | 310g Cyclops Digital Microscope 4x Objective lens HDMI cable | USB 2.0 cable Power adaptor | Metal stand White balance card | Calibration scale Software CD | IR remote Package Contents Magnification Tables Object Lens 4x on 21.5” screen (this data is only for reference) Sensor Position 1 2 3 4 5 6 7 8 Distance (cm) 21.8 18.1 11.1 8.02 6.37 5.25 4.46 3.91 F,S FOV (mm) 26.2 21.9 13.3 9.52 7.49 6.15 5.18 4.52 C FOV (mm) 19.4 16.2 9.80 7.04 5.54 4.55 3.83 3.34 F Magnification (X) 13 16 27 37 47 58 69 79 S Magnification (X) 17 21 35 49 62 77 91 105 C Magnification (X) 23 28 48 66 84 104 124 142   Sensor Position 9 10 11 12 13 14 15 Distance (cm) 3.49 3.13 2.85 2.62 2.44 2.26 2.13   F,S FOV (mm) 3.99 3.56 3.22 2.94 2.71 2.50 2.34   C FOV (mm) 2.95 2.63 2.38 2.18 2.01 1.85 1.73   F Magnification (X) 89 100 111 121 132 143 152   S Magnification (X) 118 133 147 161 175 190 202   C Magnification (X) 160 180 199 217 237 257 273   Object Lens 10x on 21.5” screen (this data is only for reference) Sensor Position 1 2 3 4 5 6 7 8 Distance (mm) 9.85 9.35 9.00 8.65 8.35 8.10 7.88 7.66 F,S FOV (mm) 1.41 1.31 1.22 1.14 1.07 1.01 0.96 0.91 C FOV (mm) 1.04 0.97 0.90 0.84 0.79 0.75 0.71 0.67 F Magnification (X) 253 273 293 313 334 354 372 393 S Magnification (X) 337 363 390 417 445 471 495 523 C Magnification (X) 455 491 527 563 601 637 669 707 Sensor Position 9 10 11 12 13 14 15   Distance (mm) 7.46 7.28 7.10 6.96 6.84 6.74 6.64   F,S FOV (mm) 0.87 0.83 0.79 0.76 0.73 0.70 0.67   C FOV (mm) 0.64 0.61 0.58 0.56 0.54 0.52 0.50   F Magnification (X) 411 431 452 470 490 511 534   S Magnification (X) 547 574 602 626 653 681 711   C Magnification (X) 739 775 813 846 882 919 961   Video Ratio 4/3F: Formats the image to fit a 4:3 screen size (1440*1080) by proportionally reducing the input image to fit the screen. 16/9S: Formats the image to fit a 16:9 screen size (1920*1080) by scaling the input image width and trimming the height to fit the screen. The magnification will also increase. 16/9C: Formats the image to fit a 16:9 screen size (1920*1080) by cropping the input image (1920*1080) from input image 5M (2595*1944). The FOV becomes smaller and magnification becomes higher. http://www.aveninc.com/avens-complete-product-line/microscopy-and-inspection/digital-microscopes/cyclops-digital-microscope/cyclops-digital-microscope-1[9/5/2014 11:34:46 AM]
26700-400 价格&库存
很抱歉,暂时无法提供与“26700-400”相匹配的价格&库存,您可以联系我们找货
