SMDPMUSB413
SMDPMUSB413
    CHIPQUIK
    MICROSCOPE DIGITAL PEN USB
SMDPMUSB413 数据手册
SMDPMUSB413 Datasheet revision 1.0 www.chipquik.com 2.0 MegaPixel Handheld USB Digital Microscope Product Highlights 1x to 200x Adjustable Magnification Resolution 1600 x 1200 in True Color Display Images on your Computer Screen thru USB Port Features - Display circuit images captured on your computer screen, store, print and attach to email - Magnify circuit probe points for accurate measurement - Enlarge and photograph probe points for easy identification - Inspect your electronic circuit boards for hard to see defects - Includes adjustable microscope workstation - LED adjustable light source Technical Specifications - DSP: High power digital image Monarch Processor - Sensor: High quality CMOS sensor, 2.0M pixel - Resolution: 1600 x 1200 - Colors: True color 24 bit (RGB) - Interface: USB 1.1 / USB 2.0 - Frame Rate: 30 frames/second (CIF and VGA) - Focal Distance: 6mm - infinity - Magnification: 1x-200x (at 10mm on 17" screen by 1600 x 1200 resolution) Technical Specifications - IBM PC compatible computer - Intel Pentium III processor or newer - 128M Ram or higher - At least two USB ports (For best effect, USB 2.0 port is recommended) - Windows XP, Vista, Windows 7 or MAC 10.4.2 - 10.5.2 Notice This product is to be used to test, repair and rework circuit boards in a commercial or industrial setting and therefore is exempt from FCC testing under section 15.103c. Use in a residential setting is not authorized. 1 © 1994-2015 Chip Quik® Inc.
SMDPMUSB413 价格&库存
很抱歉,暂时无法提供与“SMDPMUSB413”相匹配的价格&库存,您可以联系我们找货
SMDPMUSB413
库存:12
