26700-209-PLR
26700-209-PLR
    AVENTOOLS(艾文)
    MIGHTY SCOPE 5M 10X-200X POLAR
26700-209-PLR 数据手册
Aven Inc. 4595 Platt Rd. Ann Arbor, MI 48108 Phone: 734.973.0099 Email: info@aventools.com • Web Address:www.aventools.com Item # 26700-209-PLR, Mighty Scope Digital 5M - 10-200x Mighty Scope Digital 5M - 10-200x   Designed for use with shiny surfaces, such as solder joints, reflective metal parts, etc. The Mighty Scope is great for science and engineering work, dermatology, detailed repair, assembly and quality control (i.e. electronics, mechanical, etc), hobbies &collecting (coin, stamp, watch, jewelry, etc.), law enforcement (counterfeit ID, crime lab, etc), entertainment and much more.   Features     •  Easy to use, 6-LED brightness controllable hand-held USB digital microscope.   •  Adjustable magnification from 10x–200x, all in one compact lens.   •  Adjustable magnification from 10x–200x, all in one compact lens.   •  Active Pixel Technology produces sharp images and accurate color reproduction.   •  Professional measurement software to capture pictures, record video, freeze images and compare live and existing pictures.   •  Software compare mode supports dual microscope image comparison mode.   •  Microtouch Shutter trigger allows for convenient image capture when in hand held mode or mounted on a stand.   •  Includes an adjustable metal stand.    Add to Cart and then select optional accessories  ·  SPECIFICATIONS ·  OPTIONS SPECIFICATIONS Image Sensor Effective Pixels (HxV)  1/4" Color CMOS  5.0M Signal Output  USB 2.0 Magnification  10x to 200x Gain Control  Auto Gain Control Snap Shot Mode  Hardware &Software Controllable White Balance  Automatic Power Source  5 VDC through USB port 10/25/2012 | Page 1 of 2 O/S  Windows XP, SP2 &Vista &7 Power Consumption  110 mA (AVG) LED Light Type  6 White LEDs Frame Rate Working Distance Weight  15 fps (2048 x 1536) 30 fps (1024x768) 30 fps (640x480)  At 10x, 112 mm At 20x, 42 mm At 30x, 19 mm At 40x, 8.5 mm  1.55 lb OPTIONS Stands  26700-210, Mighty Scope Boom Stand ($168.42) 26700-213, Cradle Stand ($26.32) 26700-212, Mighty Scope Flex Stand ($52.58) 10/25/2012 | Page 2 of 2
26700-209-PLR 价格&库存
很抱歉,暂时无法提供与“26700-209-PLR”相匹配的价格&库存,您可以联系我们找货
