18712
18712
    GLAMOX
    Microscope, Stereo Zoom (Binocular) 6.5x ~ 45x Fluorescent, 17W
18712 数据手册
System 250 18712 Old item no.: 18712 SYSTEM 250-FL Binocular Stereo-Zoom microscope with sturdy, heavy-duty, cast aluminum housing and single boomstand. Standard with 6.5X - 45X magnification range and .65X - 4.5X zoom range. 17W Fluorescent Ring Light included. Lightsource Number of lamps Lightsource Lamp power (W) CRI and/or Color Temperature Electrical data 1 Maximum frequency (Hz) 60 T5 Minimum frequency (Hz) 50 17 Maximum voltage (V) 120 Voltage from (V) 100 5600K Dimensions Net weight (kg) Body 0 Gross weight (lb.) 58 Arm length (in.) 26 Body color Body material Grey Aluminum Technical data Termination Cord length (ft) Mounting IP classification 20 5 Boomstand Optic Working distance (mm) 95 Ballast Type of Ballast glamox.com/luxous Multi watt HF The Company reserves the right to change any product specifications without prior notification. 11/10/2016
18712 价格&库存
很抱歉,暂时无法提供与“18712”相匹配的价格&库存,您可以联系我们找货
