23712RB
23712RB
    GLAMOX
    MICROSTEREOZM7X-45XW/LIGHT
23712RB 数据手册
System 273 23712RB Old item no.: 23712RB SYSTEM 273RB-FL 23mm Binocular Stereo-Zoom Microscope with sturdy, heavy-duty, cast aluminum housing and dual boom ball-bearing boomstand. Nearly 8in. working distance (when used with a 0.5X reducing lens), 7X-45X magnification range and 0.7X-4.5X zoom range. 17W fluorescent ring light included. Electrical data Dimensions Maximum frequency (Hz) 60 Net weight (kg) 0 Minimum frequency (Hz) 50 Arm length (in.) 26 Gross weight (lb.) 63 Maximum voltage (V) 120 Voltage from (V) 100 Total consumption (W) 17 Body Body color Lightsource Number of lamps Lightsource CRI and/or Color Temperature Body material Mounting Aluminum 1 T5 5600K Technical data IP classification 20 Optic Termination Cord length (ft) Grey 5 Working distance (mm) 118 Boomstand Ballast Type of Ballast glamox.com/luxous Multi watt HF The Company reserves the right to change any product specifications without prior notification. 11/11/2016
23712RB 价格&库存
很抱歉,暂时无法提供与“23712RB”相匹配的价格&库存,您可以联系我们找货
