23780RB
23780RB
    GLAMOX
    MICROSTEREOZM7X-45XW/LIGHT
23780RB 数据手册
System 273 23780RB Old item no.: 23780RB SYSTEM 273RB-LED3000 23mm Binocular Stereo-Zoom Microscope with sturdy, heavy-duty, cast aluminum housing and dual boom ball-bearing boomstand. Nearly 8in. working distance (when used with a 0.5X reducing lens), 7X-45X magnification range and 0.7X-4.5X zoom range. 9W LED-3000 Ring Light included. This is a sample image. The actual item may be different in color or otherwise from the image displayed. Electrical data Dimensions Maximum frequency (Hz) 60 Net weight (kg) 0 Minimum frequency (Hz) 50 Arm length (in.) 26 Gross weight (lb.) 63 Maximum voltage (V) 120 Voltage from (V) 100 Total consumption (W) 9 Body Body color Lightsource Lightsource Number of lamps CRI and/or Color Temperature Body material Grey Aluminum LED 40 6000K Termination Cord length (ft) Mounting 5 Boomstand Optic Material of diffuser Working distance (mm) glamox.com/luxous Polycarbonate 118 Technical data IP classification The Company reserves the right to change any product specifications without prior notification. 20 11/11/2016
23780RB 价格&库存
很抱歉,暂时无法提供与“23780RB”相匹配的价格&库存,您可以联系我们找货
