23725RB-USBSRTRT-ESD
    GLAMOX
    MICROSTEREOZM7X-45XW/LIGHT
23725RB-USBSRTRT-ESD 数据手册
Microscope Product Lines For assembly and inspection in electronic applications Luxo: The market leader in magnification A solution for every application Luxo’s microscope product line is designed with today’s high-tech manufacturing environments in mind. The breadth of the product line meets numerous application requirements from inspection to assembly to rework. Inspection operators will appreciate the magnification range and ergonomic features of the microscope systems, while assembly and rework technicians will enjoy the greater working distances and versatility of the digital imaging systems. All Luxo microscope models feature high-quality achromatic lenses with anti-reflective coatings for superior visual clarity. Optional eyepieces and accessory objective lenses can be added to provide a wider range of magnification powers. A choice of lightsources and mounting options enable the product set-up best-suited for each individual application. Digital imaging systems are configurable to allow capturing of images to catalog or share inspection results and observations, for archiving or communicating electronically. The end result is increased productivity with an easy-to-use product line. First generation Luxo microscope, MicroLux. This microscope was first manufactured over 30 years ago and is still in use today. 2 Product guide System 250 Binocular Microscopes Lighter-duty binocular microscope system System 250 Binocular Stereo-Zoom Microscopes are ideal microscopes for the economical user. With a 20mm optics system and single boom stand, these microscopes are best-suited for lighterduty use in inspection applications. Models are available through Luxo’s 72-hour Quick Ship Program. Technical details Magnification: Eyepieces: Ergonomics: Zoom: Construction: Mounting: Standard 6.5X – 45X magnification range. Standard with 10X high-quality widefield achromatic lenses with anti-reflective coatings. Alter angles up to 45°. 360° head rotation in its focus mount. .65 - 4.5 zoom range controlled by dual graduated knobs located on both sides of the head. Heavy-duty cast aluminum housing. Single boom stand with 17.5” vertical and 26” horizontal reach. 10” x 10” base. Binocular Microscope Optics Data (System 250) Eyepieces 10X Objective 1.0X (included) 0.5X Total Magnification (Range) 6.5 - 45X 3.3 - 22.5X Field of View Diameter (mm) 31 - 4.5 61.5 - 8.9 95 150 Working Distance (mm) Product table: Part number Microscope Description 18712 System 250-FL S-Z Binocular, Single Boom Stand, Fluorescent Ring Light 18714 System 250 S-Z Binocular, Single Boom Stand 18750 - 0.5X Lens 3 Product guide System 273 Binocular Microscopes Luxo’s best-selling microscope product family System 273 Binocular Stereo-Zoom Microscopes are perfect for assembly and rework applications due to their industry-leading 23mm optics system and nearly 8” working distance (when used with a 0.5X reducing lens). As with Luxo’s family of magnifiers, the System 273 is truly a family of microscopes with a number of optional eyepieces, objective lenses, mounting options and lightsources that allow an operator to increase magnification, working distance and flexibility to suit their individual needs. Several best-selling models are available through Luxo’s 72-hour Quick Ship Program. Several System 273 systems and lightsources are available in ESD-Safe versions which are specifically designed for use in staticsensitive environments where electrostatic discharges can prove fatal for electronic components. Models include 10mm static grounding cables, metal boom stand bushings and metal pads on the microscope base. The body and stand are powder-coated with a metal-laced paint that measures 105 Ω/sq. (static dissipative). Since the surfaces are no longer insulative, triboelectric charging results in drastically lower voltages, especially since any charge (under 50 volts) is uniformly distributed throughout the entire surface of the microscope. Technical details Optics: Magnification: Lenses: Zoom: Construction: Mounting: 23mm, 10X super widefield eyepieces and eyeshields. Nearly 8” working distance when used with a 0.5X reducing lens. Standard 7X – 45X magnification range. High-quality achromatic lenses with anti-reflective coatings. .7 - 4.5 zoom range controlled by dual graduated knobs on both sides of the head. Heavy-duty cast aluminum housing. Dual boom roller-bearing stand with 17.5” vertical and 26” horizontal reach (10” x 10” base), NonIlluminated Stand with 11” vertical post or 34” Articulating Arm with Vertical Extension. Product table: For System 273 Optics Data, please refer to the chart on page 11. Part number Microscope Description ESD-Safe 23711RB System 273RB-RLI S-Z 23mm Binocular, RB Stand, Fiber Optic Illuminator with Ring Light 23712RB System 273RB-FL S-Z 23mm Binocular, RB Stand, Fluorescent Ring Light 23712RB-ESD System 273-FL-ESD ESD-Safe, S-Z 23mm Binocular, RB Stand, FL Ring Light 23714AC System 273AC S-Z 23mm Binocular, Articulating Arm with Clamp 23714RB System 273 S-Z 23mm Binocular, RB Stand 23714RB-ESD System 273-ESD ESD-Safe S-Z 23mm Binocular, RB Stand 23714VE System 273VE S-Z 23mm Binocular, Articulating Arm with Vertical Extension X X X 23726RB-ESD System 273RB-LED-ESD ESD Safe S-Z 23mm Binocular, RB Stand, LED-3000 Ring Light 23727RB System 273RB-DMLED S-Z 23mm Binocular, RB Stand, Dimmable LED Ring Light 23728RB System 273RB-DMLED-HO S-Z 23mm Binocular, RB Stand, Dimmable LED-High Output Ring Light 23780RB System 273-LED3000 S-Z 23mm Binocular, RB Stand, LED-3000 Ring Light 23780VE System 273VE-LED3000 S-Z 23mm Binocular, Articulating Arm with Vertical Extension, LED-3000 Ring Light 23783 System 273LS-LED3000 S-Z 23mm Binocular, Non-Illuminated Stand, LED-3000 Ring Light 23784 System 273LS S-Z 23mm Binocular, Non-Illuminated Lab Stand 23736 - 0.7X Reducing Lens, 23mm 23750* - 0.5X Reducing Lens, 23mm *23750 can be used with all models except 23783. 4 Product guide ESD-Safe System 373 Trinocular Microscopes For training and documentation purposes with optional digital accessories for image capture. ESD-Safe System 373 Trinocular and System 373 TRU Trinocular Stereo-Zoom Microscopes are specifically designed for training or documentation purposes. With a 23mm optics system and nearly 8” working distance (when used with a 0.5X reducing lens) these microscopes have an expansive magnification range with optional eyepieces and objective lenses permitting magnification up to nearly 300X. TRU Trinocular models allow the user to simultaneously view images on screen and through the eyepieces. ESD-Safe models are ideal for use in static-sensitive environments where electrostatic discharges can prove fatal for electronic components. Models include 10mm static grounding cables, metal boom stand bushings and metal pads on the microscope base. The body and stand are powder-coated with a metal-laced paint that measures 105 Ω/sq. (static dissipative). Since the surfaces are no longer insulative, triboelectric charging results in drastically lower voltages, especially since any charge (under 50 volts) is uniformly distributed throughout the entire surface of the microscope. Technical details Optics: 23mm, 10X super widefield eyepieces and eyeshields. Nearly 8” working distance when used with a 0.5X reducing lens. Magnification: Standard 7X – 45X magnification range. Lenses: High-quality achromatic lenses with anti-reflective coatings. Ergonomics: Alter angles up to 45°. 360° head rotation in its focus mount. Zoom: .7 - 4.5 zoom range controlled by dual graduated knobs located on both sides of the head. TRU Trinocular models feature a click-stop detent at each marking on the zoom knobs which helps to hold the magnification. Construction Heavy-duty cast aluminum housing. Body and stand and finish: are powder-coated with a metal-laced paint that measures 105 Ω/sq. (static dissipative). Mounting: Dual boom roller-bearing stand with 17.5” vertical and 24” horizontal reach. 10” x 10” base. Product table: For System 373 Optics Data, please refer to the chart on page 11. Part number Microscope Description ESD-Safe 23720RB-ESD System 373RB-ESD ESD-Safe S-Z 23mm Trinocular, RB Stand X 23720RB-TRT-ESD System 373RB-TRT-ESD ESD-Safe S-Z 23mm TRU Trinocular, RB Stand X 23725RB-USBSR-ESD System 373RB-DMLED-HOUSBSR-ESD ESD-Safe S-Z 23mm Trinocular, RB Stand, ESD-Safe X Dimmable LED-High Output Ring Light, USB 2.0 Camera 23725RB-USBSRTRT-ESD System 373RB-DMLED-HOUSBST-ESD ESD-Safe S-Z 23mm TRU Trinocular, RB Stand, ESD-Safe X Dimmable LED-High Output Ring Light, USB 2.0 Camera 23760 - Eyepieces/15X Pair, 23mm 23736 - 0.7X Reducing Lens, 23mm 23750 - 0.5X Reducing Lens, 23mm 5 Product guide VIP Microscopes Ergonomically-designed microscope with individual eyepiece adjustment. The Variable Inclination Position Microscope (VIP) features an extended magnification range and ergonomically--designed eyepiece adjustment intended to eliminate neck or muscle fatigue. Variable inclination allows for individualized adjustability so each technician can maintain a correct posture during use – neck straight, eyes forward. The magnification range and variable inclination eyepieces combined with dual boom ball-bearing stand, make it ideal for a diverse range of inspection applications and result in a microscope suited for the individual user. Technical details Optics: 23mm, 10X super widefield eyepieces and eyeshields. Nearly 8” working distance when used with 0.5X reducing lens. Magnification: Standard 8X – 50X magnification range. 4X – 25X magnification and 186mm working distance when used with a 0.5X reducing lens, included. Ergonomics: Variable inclination eyepieces allow 0° - 30° individualized adjustability. 360° head rotation in its focus mount. Zoom control: .8 - 5.0 zoom range controlled by dual graduated knobs located on both sides of the head. A click stop detent at each whole marking on the zoom knobs helps to hold the magnification. Construction Heavy-duty cast aluminum housing. Body and stand and finish: are powder-coated with an ESD-Safe metal-laced paint that measures 105 Ω/sq. (static dissipative). Mounting: Dual boom roller-bearing stand with 17.5” vertical and 22” horizontal reach. 10” x 10” base. Binocular, Microscope Optics Data (VIP) Objective zoom setting 0.8X - 5.0X Eyepieces 10X 15X 1.0X 0.5X (included) Total Magnification (Range) Objective 8X - 50X 4X - 25X Field of View Diameter (mm) 28.8 - 4.6 57.5 - 5.8 Total Magnification (Range) 12X - 75X 6X - 37.5X Field of View Diameter (mm) 21.3 - 3.4 42.5 - 6.8 91 186 Working Distance (mm) Product table: Part number Microscope Description 23880RB-ESD System 273RB-LEDVIP-ESD ESD-Safe VIP Microscope, RB Stand, LED-3000 Ring Light 23760 - Eyepieces/15X Pair 23mm/VIP 6 ESD-Safe X Microscope Mounting Options The Dual Boom Ball-Bearing Stand features a 26’ stainless steel horizontal boom extension (limited to 24” when used with a System 373 model) and a 17.5” vertical boom mounted to a 10” x 10” die-cast base. Ball-bearing design allows fluid horizontal extension of the boom stand. The focus mount angles to 45° to permit additional viewing and inspection perspectives. For use with all Luxo System 273, 373 and VIP microscopes. 23730RB Dual Boom Ball-Bearing Stand The Single Boom Stand features a 10” x 10” base weighing 22.5lbs. with built-in contoured grips to make moving it easier. Its vertical column is 17.5” and the horizontal arm extends a total of 26”. The final 2.5” of horizontal extension is accomplished via control knobs at the end nearest the focus mount. The knobs move a metal bar on a rack-and-pinion track connected to the drop post/focus mount to provide this extension. A setscrew extends through the bottom of the block into a groove on the horizontal arm to keep the microscope from accidentally rolling over, even when the retaining knob remains loose. The focus mount angles to 45° to permit additional viewing and inspection perspectives. For use with all Luxo System 250 microscopes. 18730 Single Boom Stand The Articulating Arm with Vertical Extension is 34” in length, has a 12” vertical range of motion and a maximum clearance of 16” above the benchtop surface. Includes a heavy-duty clamp that opens 4” wide in order to accommodate workstations or bench edges. For use with all Luxo System 273 and 373 microscopes. 23793 Articulating Arm with Vertical Extension The Articulating Arm Stand has a heavy-duty mount that opens up to 4” wide to mount to workstations or bench edges. The horizontal reach is over 36” when fully extended (measured from the vertical post to the middle of the microscope body) and its maximum clearance is 14” above the worksurface. This is one stand that truly frees valuable bench space and still gets the microscope out where it’s needed for assembly and rework. For use with all Luxo System 273 and 373 microscopes. 23732 Articulating Arm Stand The Non-Illuminated Stand is used for viewing small objects when an independent lightsource (not included) is used. The base of the stand is 11.25” wide by 11.5” deep. The overall height is 11” measured to the top of the vertical post. For use with all Luxo System 273 and 373 microscopes. 23734 Non-illuminated Stand 7 Lighting and Digital Options LED-3000 Fluorescent Ring Light LED-3000 Ring Light maximizes light output and distribution while preventing harmful glare and reflections. The brilliant 40 LED display, with 50,000 hour lamp life and 6000°K color temperature, makes this ring light ideal for the inspection of surface cracks and defects as well as for lead-free inspection. Self-contained on/off and dimming controls allow for dimming up to 15% output. LED-3000 consumes 9-watts of power and produces up to 3600 footcandles at 4.5” working distance. LED-3000 is ESD-Safe and suitable for static-sensitive environments. Static grounding cables ensure static dissipation. Fluorescent Ring Light provides full illumination with a powerful 17-watt, 5600°K lamp. A durable powder-coated metal housing protects the fluorescent lamp which has a rated lamp-life of 4,500 hours and produces 2,000 footcandles at 4.5” working distance.. Plug-in ballast with polarized plug is included. Part number Description LED3000 LED-3000 Ring Light ESD-Safe X Part number Description 18742 Fluorescent Ring Light Dimmable LED-High Output Ring Light Dimmable LED Ring Light Dimmable LED-High Output Ring Light maximizes light output at a greater working distance. Its 80 high-output LEDs draw only 18-watts of energy while producing up to 5800 footcandles at 4.5” working distance. The LEDs are distributed among 2 concentric rings of lights (each containing 40 LEDs) and are controlled via 8 quadrant switches. A 50,000 hour lumen maintenance (lamp life) and 6000°K color temperature make this an ideal lightsource for the inspection of surface cracks and defects, welds, lead-free solder joints, flux residues and hairline stress cracks as well as a suitable replacement for traditional 150W Fiber Optic Illuminators. Dimmable LED Ring Light maximizes light output and distribution while preventing harmful glare and reflections. Its modular construction, paired with a brilliant 40 LED display and 6000°K color temperature, make this ring light ideal for the inspection of surface cracks and defects as well as lead-free inspection. 9-watts of pure-while LED light produce up to 3600 footcandles at 4.5” working distance and ease the examination of welds, solder joints, flux residues and hairline stress cracks. Removeable/replaceable diffuser allows for easy cleaning. Dimmable to 15% output. Features a 50,000 hour lumen maintenance (lamp life). Part number Description Part number Description 18743 Dimmable LED High-Output Ring Light 18746 Dimmable LED Ring Light 8 Lighting and Digital Options Fiber Optic Illuminators Fiber Optic Ring Light ESD-Safe LED Fiber Optic Illuminator features a 40W energy-efficient LED lightsource with a 5000°K color temperature and 80 CRI and produces up to 3250 footcandles at 12” working distance. Fiber Optic Illuminator features a 150W halogen lightsource which produces 6450 footcandles at 4.5” working distance. Both Illuminators include a dimmer switch which enables an operator to select the exact amount of light desired. They can both be placed on the worksurface in a conventional position, facing the opterator, or, since there have ‘rubber feet’ on their backs, placed in a vertical position to occupy an even small footprint. Fiber Optic Ring Light, with its continuous ring, is the most popular light transmitter. The ring light housing encases high-quality glass fibers to provide 360° shadow-free uniform illumination that makes viewing of inspection and assembly applications a snap. Its 36” cable, made with interlocking stainless steel sheathing, enables the illuminator to be positioned outside the immediate work area to provide more space for inspection and assembly operations. Part number Description LFOD150 Fiber Optic Illuminator Part number Description LFOLED40 LED Fiber Optic Illuminator LFORL-CR Fiber Optic Ring Light USB 2.0 High Resolution Camera USB 2.0 STD Resolution Camera USB 2.0 High Resolution Camera is a compact high resolution camera for industrial use. Over 15 frames/s in full frame mode, 30 frames/s in ½ partial scan model and 61 frames/s in ¼ partial scan mode. ½” Interline UXGA Progressive CCD color image sensors with 1600 x 1200 pixels at full size are standard. Software permits digital image capture and measurement. Equipped with CS-Mount and high speed USB. With its USB 2.0 architecture, this camera is ideally suited for use with PC, Notebook and Embedded Systems in image processing. Includes camera, 6’ USB cable and software. USB 2.0 STD Resolution Camera is an ultra-compact, progressivescan camera with 1/3’ color CCD, digital zoom. Equipped with high-quality sensors, industrial design, C-Mount and high speed USB 2.0 output. Up to 22 frames/s in full frame mode, over 11 frames/s in ½ partial scan mode and 6 frames/s in ¼ partial scan mode. 1/3” Interline SXVGA Progressive CCD color image sensors with 1280 x 960 pixels at full size are standard. Software permits digital image capture and measurement. With its USB 2.0 architecture, this camera is ideally suited for use with PC, Notebook and Embedded Systems in image processing and factory automation. Includes camera, 6’ USB cable and software. Part number Description Part number Description 18791 USB 2.0 High Resolution Camera 18792 USB 2.0 STD Resolution Camera 9 Product guide MIDAS® Handheld digital inspection system with trigger image capture. MIDAS® is a horizontally-positionable digital handheld inspection system which provides a versatile way of capturing and documenting images using a polarizing filter and 5MP Camera. Ideal for inspection, document authenticity, criminology, museum and artwork restoration, currency verification and gemstone and mineral examination. Technical details Image sensor: ¼” color CMOS. Magnification: 10X – 200X. Lightsource: 6 white-light LEDs consuming 110mA (AVG). Pixels: 2592 x 1944 (HxV) Signal input: USB 2.0 Control: Auto gain control and white balance. Trigger: Handheld trigger image capture. Filter: Polarizing filter prevents glare and reflections by reducing the wavelengths of light through the optics of the camera. Operating system: Windows™ XP SP2, Vista, Windows™ 7 and Windows™ 8. Mounting: Gooseneck arm (12.2”V x 8.3”H x 13.8”L) with 5.1” x 5.5” base or boom stand (2.9”H x 6.2”V) with 7.9” square base. MIDAS® Optics Data Magnification Working distance 10X 20X 50X 200X 150mm 95mm 13mm 2mm Product table: 10 Part number Description MIDAS-GS MIDAS® Camera with Polarizing Filter and Gooseneck Stand MIDAS-ST MIDAS® Camera with Polarizing Filter and Boom Stand Now w ith 5MP Ca mera Microscope Optics Data Binocular and Trinocular Microscope Optics Data (Systems 273 and 373) Objective zoom setting 0.7X - 4.5X Eyepieces 10X 15X Objective 1.0X (included) 0.5X 0.7X 2.0X Total Magnification (Range) 7X - 45X 3.5X - 22.5X 4.9X - 31.5X 14X - 90X Field of View Diameter (mm) 32.8 - 5.1 65.7 - 10.2 46.9- 7.3 16.4 - 2.6 Total Magnification (Range) 10.5X - 67.5X 5.3X - 33.8X 7.4X - 47.2X 21X - 135X Field of View Diameter (mm) 24.3 - 3.8 48.6 - 7.6 34.7 - 5.4 12.1 - 1.9 Working Distance (mm) 118 195 145 35 Trinocular Microscope Optics Data (System 373) 1/3” CCD Camera with 22” Monitor and 0.5X Video Adapter Magnification with zoom FOV (mm) with zoom Magnification with zoom FOV (mm) with zoom Working Distance Accessory Lens setting @ 0.7 @ 0.7 setting @ 4.5 @ 4.5 (mm) None 23.1X 24.2 148.4X 3.8 118 0.5 11.5X 48.3 74.2X 7.5 195 0.7 16.2X 34.5 103.9X 5.4 145 2 46.2X 12.1 296.9X 1.9 35 Binocular Microscope Optics Data (VIP) Objective zoom setting 0.8X - 5.0X Eyepieces 10X 15X Objective 1.0X 0.5X (included) Total Magnification (Range) 8X - 50X 4X - 25X Field of View Diameter (mm) 28.8 - 4.6 57.5 - 5.8 Total Magnification (Range) 12X - 75X 6X - 37.5X Field of View Diameter (mm) 21.3 - 3.4 42.5 - 6.8 91 186 Working Distance (mm) Binocular Microscope Optics Data (System 250) Eyepieces 10X 1.0X (included) 0.5X Total Magnification (Range) Objective 6.5 - 45X 3.3 - 22.5X Field of View Diameter (mm) 31 - 4.5 61.5 - 8.9 95 150 Working Distance (mm) MIDAS® Optics Data Magnification Working distance 10X 20X 50X 200X 150mm 95mm 13mm 2mm 11 © Luxo February 2016 Luxo Corporation For more than 75 years Luxo has designed arm-based innovative, ergonomic lighting and magnification products. Luxo products improve work efficiency, taking particular care of individual needs. Luxo products and solutions are developed and tested by our engineers at our own research and testing facilities, and manufactured and certified in accordance with all relevant quality and environmental standards. They are based on the latest technology and expertise – and generations of experience. Luxo Five Westchester Plaza Elmsford, New York 10523 Tel: 800-222-5896 Fx: 800-648-2978 Email: office@luxous.com www.luxous.com Please refer to our website for information about our 5-year warranty.
23725RB-USBSRTRT-ESD 价格&库存
很抱歉,暂时无法提供与“23725RB-USBSRTRT-ESD”相匹配的价格&库存,您可以联系我们找货
