23880RB-ESD
23880RB-ESD
    GLAMOX
    Microscope, Digital 8x ~ 50x LED, White (40), 9W
23880RB-ESD 数据手册
VIP Microscopes 23880RB­ESD Old item no.: 23880RB­ES SYSTEM 273RB-LED VIP-ESD VIP (Variable Inclination Position) Microscopes with 23mm optics system and 8X - 50X extended magnification range. (4X - 25X magnification and 186mm working distance when used with a 0.5X reducing lens, included.) Ergonomically designed variable inclination eyepieces allow 0º - 30º individualized adjustability permitting technicians to maintain a correct posture during use. Can be used with 15X and 200X 23mm eyepieces. This is a sample image. The actual item may be different in color or otherwise from the image displayed. Electrical data Dimensions Maximum frequency (Hz) 60 Net weight (kg) Minimum frequency (Hz) 50 Gross weight (lb.) 63 Arm length (in.) 22 Maximum voltage (V) 120 Voltage from (V) 100 Total consumption (W) 9 Technical data IP classification Lightsource Lightsource Number of lamps CRI and/or Color Temperature 0 ESD-Safe 20 Yes LED 40 6000K Optic Material of diffuser Working distance (mm) Polycarbonate 91 Body Body color Body material Black Aluminum Termination Cord length (ft) Mounting glamox.com/luxous The Company reserves the right to change any product specifications without prior notification. 5 Boomstand 11/11/2016
23880RB-ESD 价格&库存
很抱歉,暂时无法提供与“23880RB-ESD”相匹配的价格&库存,您可以联系我们找货
