23728RB
23728RB
    GLAMOX
    Microscope, Stereo Zoom (Binocular) 7x ~ 45x LED, White (80), 18W
23728RB 数据手册
System 273 23728RB Old item no.: 23728RB SYSTEM 273RB-DMLED-HO 23mm Binocular Stereo-Zoom Microscope with sturdy, heavy-duty, cast aluminum housing and dual boom ball-bearing boomstand. Nearly 8in. working distance (when used with a 0.5X reducing lens), 7X-45X magnification range and 0.7X-4.5X zoom range. 18W Dimmable LED-High Output Ring Light included. Electrical data Dimensions Maximum frequency (Hz) 60 Net weight (kg) 0 Minimum frequency (Hz) 50 Arm length (in.) 26 Gross weight (lb.) 63 Maximum voltage (V) 120 Voltage from (V) 100 Total consumption (W) 18 Body Body color Lightsource Lightsource Number of lamps CRI and/or Color Temperature Body material Grey Aluminum LED 80 6000K Termination Cord length (ft) Mounting 5 Boomstand Optic Material of diffuser Working distance (mm) glamox.com/luxous Polycarbonate 118 Technical data IP classification The Company reserves the right to change any product specifications without prior notification. 20 11/11/2016
23728RB 价格&库存
很抱歉,暂时无法提供与“23728RB”相匹配的价格&库存,您可以联系我们找货
