23711RB
23711RB
    GLAMOX
    MICROSTEREOZM7X-45XW/LIGHT
23711RB 数据手册
System 273 23711RB Old item no.: 23711RB SYSTEM 273RB-RLI 23mm Binocular Stereo-Zoom Microscope with sturdy, heavy-duty, cast aluminum housing and dual boom ball-bearing boomstand. Nearly 8in. working distance (when used with a 0.5X reducing lens), 7X-45X magnification range and 0.7X-4.5X zoom range. 150W Fiber Optic Illuminator with continuous annular ring light included. Electrical data Lightsource Maximum frequency (Hz) 60 Number of lamps Minimum frequency (Hz) 50 Lamp base Maximum voltage (V) 120 Lightsource Voltage from (V) 100 CRI and/or Color Temperature Total consumption (W) 150 1 GX5.3 MR16 3000K Optic Dimensions Material of diffuser Net weight (kg) 0 Arm length (in.) 26 Gross weight (lb.) 65 Working distance (mm) Body color Body material Mounting 5 Boomstand Grey Aluminum Technical data IP classification glamox.com/luxous 118 Termination Cord length (ft) Body Glass The Company reserves the right to change any product specifications without prior notification. 20 11/10/2016
23711RB 价格&库存
很抱歉,暂时无法提供与“23711RB”相匹配的价格&库存,您可以联系我们找货
