LFL026465
LFL026465
    GLAMOX
    LAMPMAGNIFIER2.25XLED7W
LFL026465 数据手册
LFM LED LFL026465 Old item no.: 18346WT LFM LED T100 Wh107 840 5DCLANA LFM LED is Luxo's most cost-effective LED Magnifier. A die-cast aluminum housing and flexible, 45" spring-balanced L-arm ensure the magnifier can be placed in any position. Auto shut-off an dimming features ensure energy savings. LFM LED is suitable for a variety of Industrial applications. 5-diopter (2.25X) lens. Edge clamp mount. Color: white. Lightsource Number of lamps Lamp power (W) Lightsource CRI and/or Color Temperature Lumen Out Electrical data 1 10 LED 80 CRI, 4000K Maximum frequency (Hz) 60 Minimum frequency (Hz) 50 Maximum voltage (V) 120 Voltage from (V) 100 505 Dimensions Optic Primary Lens (D) Working distance (mm) Magnification (X) 5 Net weight (kg) 2,5 Arm length (in.) 45 200 2.25 Termination Mounting Edge clamp Technical data IP classification glamox.com/luxous 20 The Company reserves the right to change any product specifications without prior notification. 11/11/2016 LFM LED LFL026465 LFM LED T100 Wh107 840 5DCLANA LFM LED is Luxo's most cost-effective LED Magnifier. A die-cast aluminum housing and flexible, 45" spring-balanced L-arm ensure the magnifier can be placed in any position. Auto shut-off an dimming features ensure energy savings. LFM LED is suitable for a variety of Industrial applications. 5-diopter (2.25X) lens. Edge clamp mount. Color: white. Drawings glamox.com/luxous The Company reserves the right to change any product specifications without prior notification. 11/11/2016
LFL026465 价格&库存
很抱歉,暂时无法提供与“LFL026465”相匹配的价格&库存,您可以联系我们找货
