16351LG
16351LG
    GLAMOX
    LAMPMAGNIFIER1.75XFLUOR22W
16351LG 数据手册
IFM Magnifiers 16351LG Old item no.: 16351LG IFM2K 3D 3C LIGHT GRAY/GRIS IFM is an ideal lighter-duty magnifier for low-power inspection. A 22W circline fluorescent lamp provides 360◦ shadow­free illumination and a lamp diffuser cover protects the bulb from damage. 3-diopter (1.75X) lens. 30" external spring-balanced arm. Weighted base. Color: light grey. Lightsource Number of lamps Lamp power (W) Lamp base CRI and/or Color Temperature Lightsource Electrical data 1 22 G10Q 4100K Maximum frequency (Hz) 60 Minimum frequency (Hz) 50 Maximum voltage (V) 120 Voltage from (V) 100 T9 Dimensions Optic Color of reflector Material of reflector Working distance (mm) Magnification (X) Net weight (kg) White PC 30 Arm length (in.) 30 333 1.75 Termination Cord length (ft) Body Mounting Body material Steel Body color Grey 6 Weighted base Ballast Type of Ballast glamox.com/luxous 0 Gross weight (lb.) The Company reserves the right to change any product specifications without prior notification. Electromagnetic 11/10/2016
16351LG 价格&库存
很抱歉,暂时无法提供与“16351LG”相匹配的价格&库存,您可以联系我们找货
