16353LG
16353LG
    GLAMOX
    LAMPMAGNIFIER2.25XFLUOR22W
16353LG 数据手册
IFM Magnifiers 16353LG Old item no.: 16353LG IFM2K 5D 3C LIGHT GRAY/GRIS IFM is an ideal lighter-duty magnifier for low-power inspection. A 22W circline fluorescent lamp provides 360◦ shadow­free illumination and a lamp diffuser cover protects the bulb from damage. 5-diopter (2.25X) lens. 30" external spring-balanced arm. Weighted base. Color: light grey. Lightsource Number of lamps Lamp power (W) Lamp base CRI and/or Color Temperature Lightsource Electrical data 1 22 G10Q 4100K Maximum frequency (Hz) 60 Minimum frequency (Hz) 50 Maximum voltage (V) 120 Voltage from (V) 100 T9 Dimensions Optic Color of reflector Working distance (mm) Material of reflector Magnification (X) Net weight (kg) White 200 31 Arm length (in.) 30 PC 2.25 Termination Cord length (ft) Body Mounting Body material Steel Body color Grey 6 Weighted base Ballast Type of Ballast glamox.com/luxous 0 Gross weight (lb.) The Company reserves the right to change any product specifications without prior notification. Electromagnetic 11/10/2016
16353LG 价格&库存
很抱歉,暂时无法提供与“16353LG”相匹配的价格&库存,您可以联系我们找货
