LFL026109
LFL026109
    GLAMOX
    LAMP MAG 5 DIOPTER 120V LED 10W
LFL026109 数据手册
LFM LED LFL026109 LFM LED T70 Lg107 840 5DCLANA LFM LED is Luxo's most cost-effective LED Magnifier. A die-cast aluminum housing and flexible, 30" spring-balanced L-arm ensure the magnifier can be placed in any position. Auto shut-off an dimming features ensure energy savings. LFM LED is suitable for a variety of Old item no.: 18352LG Industrial applications. 5-diopter (2.25X) lens. Edge clamp mount. Color: light grey. Lightsource Number of lamps Lamp power (W) Lightsource CRI and/or Color Temperature Lumen/Watt Lumen Out Electrical data 1 10 LED 80 CRI, 4000K Maximum frequency (Hz) 60 Minimum frequency (Hz) 50 Maximum voltage (V) 120 Voltage from (V) 100 Total consumption (W) 505 Technical data Maximum ambient temperature (°C) Optic Primary Lens (D) Working distance (mm) Magnification (X) 10 51 5 200 2.25 Dimensions IP classification 25 20 Body Body color Grey Termination Net weight (kg) 2,5 Arm length (in.) 30 Mounting Edge clamp LFM LED LFL026109 LFM LED T70 Lg107 840 5DCLANA LFM LED is Luxo's most cost-effective LED Magnifier. A die-cast aluminum housing and flexible, 30" spring-balanced L-arm ensure the magnifier can be placed in any position. Auto shut-off an dimming Photos
LFL026109
1. 物料型号:LFL026109 2. 器件简介:LFM LED是Luxo最经济的LED放大镜。采用压铸铝外壳和灵活的30英寸弹簧平衡L型臂,确保放大镜可以放置在任何位置。自动关闭和调光功能确保节能。适用于多种工业应用。5屈光度(2.25倍)透镜。边缘夹紧安装。旧型号:18352LG。 3. 引脚分配:文档中未提供引脚分配信息。 4. 参数特性: - 光源数量:1 - 灯功率(W):10 - 光源类型:LED - 显色指数/或颜色温度:80 CRI, 4000K - 流明/瓦特:51 - 流明输出:505 - 光学: - 主要透镜(D):5 - 工作距离(mm):200 - 放大倍数(X):2.25 - 尺寸: - 净重(kg):2.5 - 臂长(英寸):30 - 电气数据: - 最大频率(Hz):60 - 最小频率(Hz):50 - 最大电压(V):120 - 电压范围(V):100 - 总消耗(W):10 5. 功能详解:文档中未提供详细的功能解释。 6. 应用信息:适用于多种工业应用。 7. 封装信息: - 机身颜色:灰色 - 端子:LUXO - 安装:边缘夹紧 - LED:LUXO
LFL026109 价格&库存
很抱歉,暂时无法提供与“LFL026109”相匹配的价格&库存,您可以联系我们找货
