K110620002
K110620002
    GLAMOX
    LAMP ARTICULATING 120V 60W, 22W
K110620002 数据手册
LC K110620002 LC1AWT LC LIGHT, 45" ARM WITH EDGE CLAMP WHITE One of the most widely used task lights in the world. With a combined 22W circline fluorescent and 14W compact fluorescent lightsource, LC provides the perfect balance of high light output with good color rendition. Edge clamp mount. Old item no.: LC1AWT Color: white. Lightsource Number of lamps Lamp power (W) Number of lamps 2 Lamp base Lamp power 2 (W) Lamp base 2 Electrical data 1 22 1 G10Q 14 E26 Lightsource T9 Lightsource 2 T4 Body Body color Body material Color of reflector Aluminum Mounting Maximum frequency (Hz) 60 Voltage from (V) 115 Maximum voltage (V) 120 Total consumption (W) 36 Ballast Number of ballast Type of Ballast 2 Multi watt HF Gross weight (lb.) Arm length (in.) 8 45 Technical data Aluminum White Termination Cord length (ft) 60 Dimensions White Optic Material of reflector Minimum frequency (Hz) 6 Edge clamp IP classification 20
K110620002 价格&库存
很抱歉,暂时无法提供与“K110620002”相匹配的价格&库存,您可以联系我们找货
