SPL026286
SPL026286
    GLAMOX
    LAMP ARTICULATING 240V LED 11W
SPL026286 数据手册
Split LED T31 Wh 206 930 Split SPL026286 Old item no.: 16010WT Split LED T31 Wh 206 930 CLA NA Split is a powerful task light for large, demanding work places. It has twice the light output of our traditional task lights. Split is dimmable, and equipped with automatic shut-off in order to save energy. Edge clamp mount. Color: white. Lightsource Electrical data Number of lamps 1 Lamp power (W) 11 Lightsource LED CRI and/or Color Temperature CRI 90, 3200K Lumen/Watt 55 Lumen Out Maximum voltage (V) Maximum frequency (Hz) Minimum frequency (Hz) Voltage from (V) Total consumption (W) 240 60 50 100 11 600 LLMF LED 50000h Ta25 0.70 MacAdam step Average useful life (IEC 62717) Ta25 Dimensions 3,5 Net weight (kg) 1 50000h L70B50 Arm length (in.) 31.5 Technical data Termination Optic Plug type Cord length (ft) Mounting IP classification 20 ASY NA 6 Optic Light distribution Up/Down 0/100 Edge clamp Ballast Wiring Accessories Integrated PIR sensor Type of Ballast AC/DC = alternating current/ direct current Body Body color glamox.com/luxous White The Company reserves the right to change any product specifications without prior notification. 6/27/2016
SPL026286 价格&库存
很抱歉,暂时无法提供与“SPL026286”相匹配的价格&库存,您可以联系我们找货
