KFL026274
KFL026274
    GLAMOX
    LAMP
KFL026274 数据手册
KFM LED KFL026274 Old item no.: 18113WT KFM LED T45 Wh 111 840 3D CLA NA KFM LED produces nearly 75% greater light output than traditional KFM models. A heavy-duty, all-metal construction with sleek design, adjustable arm and excellent light output makes the KFM suitable for a variety of industrial applications. No knobs to tighten, nothing to adjust. A flexible, self-balancing shade and fully-enclosed, hands-free neck design combined with 45" heavy-duty internal-spring parallel, three-pivot K-arm, allows the lamp head to be secured in any position and are ideal for environments where FOD is a concern. The quality and positioning of the LEDs across two semi-circular modules allows for virtually shadow-free 3-diopter (1.75X) magnification and excellent color rendition. Edge clamp mount. Color: white. Lightsource Number of lamps Lamp power (W) Lightsource CRI and/or Color Temperature Lumen/Watt Lumen Out Electrical data 1 11 LED 80 CRI, 4000K 82 Maximum voltage (V) Maximum frequency (Hz) Minimum frequency (Hz) Voltage from (V) Total consumption (W) 240 60 50 100 11 900 Technical data Optic Primary Lens (D) 3 Magnification (X) 1.75 Working distance (mm) 330 Maximum ambient temperature (°C) 25 IP classification 20 Body Body color White Dimensions Net weight (kg) 3 Arm length (in.) 45 glamox.com/luxous Termination Mounting The Company reserves the right to change any product specifications without prior notification. Edge clamp 11/11/2016
KFL026274 价格&库存
很抱歉,暂时无法提供与“KFL026274”相匹配的价格&库存,您可以联系我们找货
