OVE025026
OVE025026
    GLAMOX
    LAMP ARTICULATING 100-240V LED
OVE025026 数据手册
Ovelo OVE025026 Old item no.: 16765WT Ovelo T30 Wh 106 932 LED CLA NA Ovelo is a modern LED task light with a unique design and all metal construction making it stand out in any office environment. A covered spring-balanced arm design provides complete flexibility of the pivoting arm and lamp head, yet its overall size is modest. Ovelo uses dimmable LEDs to illuminate an entire worksurface and incorporates automatic shut-off to further enhance energy savings. Edge clamp mount. Color: white. Lightsource Electrical data Number of lamps 1 Maximum voltage (V) Lamp power (W) 6 Maximum frequency (Hz) Lightsource LED CRI and/or Color Temperature CRI 90, 3250K Lumen Out 350 Lumen/Watt 240 Minimum frequency (Hz) Voltage from (V) 60 50 100 Total consumption (W) 8 44 LLMF LED 50000h Ta25 0.70 MacAdam step 3,5 Average useful life (IEC 62717) Ta25 50000h L70B50 Optic Color of reflector White Material of diffuser Polycarbonate Material of reflector PC Light distribution Up/Down Termination Optic ASY Plug type Cord length (ft) Mounting 0/100 Dimensions NA Net weight (kg) 1,2 5 Arm length (in.) 29 Edge clamp Ballast Technical data Maximum ambient temperature (°C) 25 IP classification 20 Type of Ballast AC/DC = alternating current/ direct current Body Body color White Body material Steel glamox.com/luxous The Company reserves the right to change any product specifications without prior notification. 8/25/2016 Ovelo OVE025026 Ovelo T30 Wh 106 932 LED CLA NA Ovelo is a modern LED task light with a unique design and all metal construction making it stand out in any office environment. A covered spring-balanced arm design provides complete flexibility of the pivoting arm and lamp head, yet its overall size is modest. Ovelo uses dimmable LEDs to illuminate an entire worksurface and incorporates automatic shut-off to further enhance energy savings. Edge clamp mount. Color: Drawings glamox.com/luxous The Company reserves the right to change any product specifications without prior notification. 8/25/2016
OVE025026 价格&库存
很抱歉,暂时无法提供与“OVE025026”相匹配的价格&库存,您可以联系我们找货
