AIL024542
AIL024542
    GLAMOX
    LAMP ARTICULATING 240V LED 6W
AIL024542 数据手册
Air LED T60 Ag 106 932 CLA Air LED AIL024542 Old item no.: 16717AG Air LED T60 Ag 106 932 CLA NA Air LED is a self-balancing task light with a spring-balanced arm for maximum reach and flexibility. It has perfect balance and smooth movement that make it feel feather light – in spite of its steel construction. Edge clamp mount. Color: aluminum grey. Lightsource Electrical data Number of lamps 1 Maximum voltage (V) Lamp power (W) 6 Maximum frequency (Hz) Lightsource LED CRI and/or Color Temperature CRI 90, 3200K Lumen/Watt 38 Lumen Out Minimum frequency (Hz) Voltage from (V) Total consumption (W) 240 60 50 100 8 300 LLMF LED 50000h Ta25 0.70 MacAdam step Average useful life (IEC 62717) Ta25 Dimensions 3,5 Net weight (kg) 0,9 50000h L70B50 Arm length (in.) 24 Termination Technical data Optic Maximum ambient temperature (°C) 25 IP classification 20 ASY Optic Light distribution Up/Down 0/100 Body Body material Body color Steel Silver grey Ballast Type of Ballast glamox.com/luxous AC/DC = alternating current/ direct current The Company reserves the right to change any product specifications without prior notification. 6/27/2016 Air LED T60 Ag 106 932 CLA Air LED AIL024542 Air LED T60 Ag 106 932 CLA NA Air LED is a self-balancing task light with a spring-balanced arm for maximum reach and flexibility. It has perfect balance and smooth movement that make it feel feather light – in spite of its steel construction. Edge clamp mount. Color: aluminum grey. Drawings glamox.com/luxous The Company reserves the right to change any product specifications without prior notification. 6/27/2016
AIL024542 价格&库存
很抱歉,暂时无法提供与“AIL024542”相匹配的价格&库存,您可以联系我们找货
