SPL026327
SPL026327
    GLAMOX
    LAMP ARTICULATING 240V LED 11W
SPL026327 数据手册
Split LED T31 Bl 206 SEN Split SPL026327 Old item no.: Split LED T31 Bl 206 SEN 930 CLA NA Split is a powerful task light for large, demanding work places. It has twice the light output of our traditional task lights. Split is dimmable, and equipped with automatic shut-off and integrated PIR sensor in order to save energy. Edge clamp mount. Color: Black. Lightsource Electrical data Number of lamps 1 Lamp power (W) 11 Lightsource LED CRI and/or Color Temperature CRI 90, 3200K Lumen/Watt 55 Lumen Out Maximum voltage (V) Maximum frequency (Hz) Minimum frequency (Hz) Voltage from (V) Total consumption (W) 240 60 50 100 11 600 LLMF LED 50000h Ta25 0.70 MacAdam step Average useful life (IEC 62717) Ta25 Dimensions 3,5 Net weight (kg) 1,1 50000h L70B50 Arm length (in.) 31.5 Technical data Termination Optic Plug type Cord length (ft) Mounting IP classification 20 ASY NA 6 Optic Light distribution Up/Down 0/100 Edge clamp Ballast Wiring Accessories Integrated PIR sensor Type of Ballast AC/DC = alternating current/ direct current Body Body color glamox.com/luxous Black The Company reserves the right to change any product specifications without prior notification. 6/27/2016
SPL026327
- 物料型号: Split LED T31 Bl 206 SEN 930 CLA NA - 器件简介: Split是一款为大型、要求严格的工作场所设计的强效台灯,其亮度是传统台灯的两倍。它具有可调光功能,配备自动关闭和集成PIR传感器以节省能源。边缘夹持安装。颜色:黑色。 - 引脚分配: 未提供具体引脚分配信息。 - 参数特性: - 光源类型: LED - 灯的数量: 1 - 灯功率(W): 11 - 色温和CRI: CRI 90, 3200K - 流明/瓦: 5 - 流明输出: 600 - 平均使用寿命: 50000h Ta25 - MacAdam步: 3.5 - 电压: 50-60V - 总功耗(W): 11 - IP分类: 未提供具体信息 - 功能详解: 灯具具有集成PIR传感器,自动关闭功能,以及可调光性。 - 应用信息: 适用于大型、要求严格的工作场所。 - 封装信息: 边缘夹持安装,颜色为黑色。灯具的臂长为31.5英寸,净重为1.1公斤。
SPL026327 价格&库存
很抱歉,暂时无法提供与“SPL026327”相匹配的价格&库存,您可以联系我们找货
