16013WT
16013WT
    GLAMOX
    LAMP ARTICULATING 120V LED 11W
16013WT 数据手册
SPLIT LED SENSOR W/BASE WHITE Split 16013WT Old item no.: 16013WT SPLIT LED SENSOR W/BASE WHITE Split is a powerful task light for large, demanding work places. It has twice the light output of our traditional task lights. Split is dimmable, and equipped with automatic shut-off and integrated PIR sensor in order to save energy. Table/desk base. Color: white. Lightsource Electrical data Number of lamps 1 Lamp power (W) 11 Lightsource LED CRI and/or Color Temperature Lumen/Watt Lumen Out MacAdam step CRI 90, 3200K 55 3,5 NA Mounting Table/desk base 6 50 Maximum voltage (V) 120 Voltage from (V) 100 Total consumption (W) 11 Dimensions Net weight (kg) 0 Arm length (in.) 31.5 Body Body color White Optic Light distribution Up/Down Technical data IP classification Minimum frequency (Hz) ASY Plug type Cord length (ft) 60 600 Termination Optic Maximum frequency (Hz) 0/100 20 Ballast Type of Ballast glamox.com/luxous AC/DC = alternating current/ direct current The Company reserves the right to change any product specifications without prior notification. 6/27/2016
16013WT 价格&库存
很抱歉,暂时无法提供与“16013WT”相匹配的价格&库存,您可以联系我们找货
