OVE025305
OVE025305
    GLAMOX
    LAMPARTICULATING100-240VLED
OVE025305 数据手册
Ovelo OVE025305 Old item no.: 16766WT Ovelo T30 Wh 106 932 LED BAS NA Ovelo is a modern LED task light with a unique design and all metal construction making it stand out in any office environment. A covered spring-balanced arm design provides complete flexibility of the pivoting arm and lamp head, yet its overall size is modest. Ovelo uses dimmable LEDs to illuminate an entire worksurface and incorporates automatic shut-off to further enhance energy savings. Table/desk base mount. Color: white. Lightsource Electrical data Number of lamps 1 Maximum voltage (V) Lamp power (W) 6 Maximum frequency (Hz) Lightsource LED CRI and/or Color Temperature CRI 90, 3250K Lumen Out 350 Lumen/Watt 240 Minimum frequency (Hz) Voltage from (V) 60 50 100 Total consumption (W) 8 44 LLMF LED 50000h Ta25 0.70 MacAdam step 3,5 Average useful life (IEC 62717) Ta25 50000h L70B50 Optic Color of reflector White Material of diffuser Polycarbonate Material of reflector PC Light distribution Up/Down Termination Optic ASY 0/100 Dimensions Plug type NA Net weight (kg) 3 Mounting Table/desk base Arm length (in.) 29 Cord length (ft) 5 Ballast Technical data Maximum ambient temperature (°C) 25 IP classification 20 Type of Ballast AC/DC = alternating current/ direct current Body Body color White Body material Steel glamox.com/luxous The Company reserves the right to change any product specifications without prior notification. 8/25/2016 Ovelo OVE025305 Ovelo T30 Wh 106 932 LED BAS NA Ovelo is a modern LED task light with a unique design and all metal construction making it stand out in any office environment. A covered spring-balanced arm design provides complete flexibility of the pivoting Photos glamox.com/luxous The Company reserves the right to change any product specifications without prior notification. 8/25/2016 Ovelo OVE025305 Ovelo T30 Wh 106 932 LED BAS NA Ovelo is a modern LED task light with a unique design and all metal construction making it stand out in any office environment. A covered spring-balanced arm design provides complete flexibility of the pivoting arm and lamp head, yet its overall size is modest. Ovelo uses dimmable LEDs to illuminate an entire worksurface and incorporates automatic shut-off to further enhance energy savings. Table/desk base mount. Drawings glamox.com/luxous The Company reserves the right to change any product specifications without prior notification. 8/25/2016
OVE025305 价格&库存
很抱歉,暂时无法提供与“OVE025305”相匹配的价格&库存,您可以联系我们找货
