CIR025720
CIR025720
    GLAMOX
    LAMP MAGN3.5 DIOPTER 120V 22W
CIR025720 数据手册
Circus CIR025720 17980WT CIRCUS/AH 3.5D WHITE Circus is specially designed to withstand the rigors of everyday use in industrial and manufacturing environments as well as cosmetology, health spas, beauty salons and clean room applications where FOD is a concern. No knobs to tighten, nothing to adjust. A 3.5-diopter white Old item no.: 17980WT crown optical-quality glass lens provides distortion-free viewing. The highly- flexible, self-balancing shade and 45" internal spring arm allows Electrical data Lightsource Maximum frequency (Hz) 60 Number of lamps Minimum frequency (Hz) 50 Lamp power (W) Maximum voltage (V) 120 Lamp base Voltage from (V) 100 Lightsource Total consumption (W) 23 Primary Lens (D) Working distance (mm) Magnification (X) 3.5 285.7 1.88 Plug type Cord length (ft) temperature (°C) IP classification NA 6 2GX13 Fluorescent circular T5-C 25 20 Body Body color Termination 22 Technical data Maximum ambient Optic 1 Grey Dimensions Arm length (in.) 39 Circus CIR025720 17980WT CIRCUS/AH 3.5D WHITE Circus is specially designed to withstand the rigors of everyday use in industrial and manufacturing environments as well as cosmetology, health spas, beauty salons and clean room applications where FOD is a Photos Circus CIR025720 17980WT CIRCUS/AH 3.5D WHITE Circus is specially designed to withstand the rigors of everyday use in industrial and manufacturing environments as well as cosmetology, health spas, beauty salons and clean room applications where FOD is a concern. No knobs to tighten, nothing to adjust. A 3.5-diopter white crown optical-quality glass lens provides distortion-free viewing. The highly- flexible, self-balancing shade and 45" internal spring arm allows Drawings
CIR025720 价格&库存
很抱歉,暂时无法提供与“CIR025720”相匹配的价格&库存,您可以联系我们找货
