WAL026780
WAL026780
    GLAMOX
    LAMPMAGNIFIER1.75XLED12W
WAL026780 数据手册
WAVE LED UV WAL026780 Old item no.: WaveLED-UV T105Bl3,5DCLA ESDNA Wave LED UV-ESD is an illuminated magnifier designed for the inspection of conformal coatings in static-sensitive environments where electrostatic discharges can prove fatal for electronic components. The shade and arm are powder-coated with a metal-laced paint that measures 10^4Ω/sq. (conductive). The remaining components are molded in a material that measures 10^5 ­ 10^6Ω/sq. (static dissipative). Since the surfaces are no longer insulative, triboelectric charging results in drastically lower voltages, especially since any charge (under 50 volts) is uniformly distributed throughout the entire surface of the head assembly. No knobs to tighten, nothing to adjust a flexible, self-balancing shade and hands-free neck assembly combined with 45" heavy-duty internal-spring parallel, three-pivot K-arm, allows the lamp head to be secured in any position. The fully-enclosed neck design is ideal for environments where FOD is a concern. An automatic Lightsource shut-off feature and step dimming further ensures energy savings. Number of lamps 2 Lightsource LED CRI and/or Color Temperature 80 CRI, 4000K Lamp power (W) Lumen/Watt Lumen Out Electrical data Voltage from (V) 230 Maximum voltage (V) 240 Maximum frequency (Hz) 60 12 Minimum frequency (Hz) 50 46 Total consumption (W) 13 600 LLMF LED 50000h Ta25 0.80 Optic Primary Lens (D) Technical data Working distance (mm) Maximum ambient temperature (°C) 25 IP classification 20 ESD-Safe Yes Termination Plug type NA Cord length (ft) 1.7 Mounting glamox.com/luxous Edge clamp Magnification (X) 3.5 285.7 1.88 Dimensions Net weight (kg) 3,5 Arm length (in.) 45 Body Body color The Company reserves the right to change any product specifications without prior notification. Black 11/11/2016 WAVE LED UV WAL026780 WaveLED-UV T105Bl3,5DCLA ESDNA Wave LED UV-ESD is an illuminated magnifier designed for the inspection of conformal coatings in static-sensitive environments where electrostatic discharges can prove fatal for electronic components. The Photos glamox.com/luxous The Company reserves the right to change any product specifications without prior notification. 11/11/2016 WAVE LED UV WAL026780 WaveLED-UV T105Bl3,5DCLA ESDNA Wave LED UV-ESD is an illuminated magnifier designed for the inspection of conformal coatings in static-sensitive environments where electrostatic discharges can prove fatal for electronic components. The shade and arm are powder-coated with a metal-laced paint that measures 10^4Ω/sq. (conductive). The remaining components are molded in a material that measures 10^5 ­ 10^6Ω/sq. (static Drawings glamox.com/luxous The Company reserves the right to change any product specifications without prior notification. 11/11/2016
WAL026780 价格&库存
很抱歉,暂时无法提供与“WAL026780”相匹配的价格&库存,您可以联系我们找货
