WAL026409
WAL026409
    GLAMOX
    Conformal
    LAMPMAGNIFIER2.25XLED12W
WAL026409 数据手册
WAVE LED UV WAL026409 Old item no.: Wave LED-UV T45 Lg 5D CLA NA Wave LED UV is an illuminated magnifier designed for the inspection of conformal coatings as well as fro the detailed inspection of welds, solder joints and other areas of stress concentration. No knobs to tighten, nothing to adjust - a flexible, self-balancing shade and hands-free neck assembly combined with 45" heavy-duty internal-spring parallel, three-pivot K-arm, allows the lamp head to be secured in any position. The fully-enclosed neck design is ideal for environments where FOD is a concern. An automatic shut-off feature and step dimming further ensures energy savings. WAVE LED offers shadow-free 5-diopter (2.25X) magnification with light coming from both sides, as well as three-dimensional magnification lighting from the left or right. The 3D-feature is especially welcome when working with circuit board and similar delicate objects. Edge clamp mount. Color: light grey. Lightsource Electrical data Number of lamps 2 Lightsource LED CRI and/or Color Temperature 80 CRI, 4000K Lamp power (W) Lumen/Watt Lumen Out Voltage from (V) 230 Maximum voltage (V) 240 Maximum frequency (Hz) 60 12 Minimum frequency (Hz) 50 46 Total consumption (W) 13 600 LLMF LED 50000h Ta25 0.80 Termination Plug type Optic Cord length (ft) Primary Lens (D) 5 Working distance (mm) Mounting 5 Edge clamp 200 Magnification (X) 2.25 Technical data Maximum ambient temperature (°C) 25 IP classification 20 Dimensions Net weight (kg) 3,6 Arm length (in.) 45 Body Body color glamox.com/luxous NA The Company reserves the right to change any product specifications without prior notification. Grey 11/11/2016 WAVE LED UV WAL026409 Wave LED-UV T45 Lg 5D CLA NA Wave LED UV is an illuminated magnifier designed for the inspection of conformal coatings as well as fro the detailed inspection of welds, solder joints and other areas of stress concentration. No knobs to Photos glamox.com/luxous The Company reserves the right to change any product specifications without prior notification. 11/11/2016 WAVE LED UV WAL026409 Wave LED-UV T45 Lg 5D CLA NA Wave LED UV is an illuminated magnifier designed for the inspection of conformal coatings as well as fro the detailed inspection of welds, solder joints and other areas of stress concentration. No knobs to tighten, nothing to adjust - a flexible, self-balancing shade and hands-free neck assembly combined with 45" heavy-duty internal-spring parallel, three-pivot K-arm, allows the lamp head to be secured in any Drawings glamox.com/luxous The Company reserves the right to change any product specifications without prior notification. 11/11/2016
WAL026409 价格&库存
很抱歉,暂时无法提供与“WAL026409”相匹配的价格&库存,您可以联系我们找货
