CIR025725
CIR025725
    GLAMOX
    LAMP MAG 5 DIOPT 120V FLSNT 22W
CIR025725 数据手册
Circus CIR025725 CIR T100WH 122 840 5D CLA NA Circus is specially designed to withstand the rigors of everyday use in industrial and manufacturing environments as well as cosmetology, health spas, beauty salons and clean room applications where FOD is a concern. No knobs to tighten, nothing to adjust. A 5-diopter white Old item no.: 17981WT crown optical-quality glass lens provides distortion-free viewing. The highly- flexible, self-balancing shade and 45" internal spring arm allows Electrical data Lightsource Maximum frequency (Hz) 60 Number of lamps Minimum frequency (Hz) 50 Lamp power (W) Maximum voltage (V) 120 Lamp base Voltage from (V) 100 Lightsource Total consumption (W) 23 Primary Lens (D) Working distance (mm) Magnification (X) 5 200 2.25 temperature (°C) IP classification Net weight (kg) 5,69 Arm length (in.) 39 2GX13 Fluorescent circular T5-C 25 20 Termination Plug type Dimensions 22 Technical data Maximum ambient Optic 1 Cord length (ft) NA 6 Body Body color Grey Circus CIR025725 CIR T100WH 122 840 5D CLA NA Circus is specially designed to withstand the rigors of everyday use in industrial and manufacturing environments as well as cosmetology, health spas, beauty salons and clean room applications where FOD is a Photos Circus CIR025725 CIR T100WH 122 840 5D CLA NA Circus is specially designed to withstand the rigors of everyday use in industrial and manufacturing environments as well as cosmetology, health spas, beauty salons and clean room applications where FOD is a concern. No knobs to tighten, nothing to adjust. A 5-diopter white crown optical-quality glass lens provides distortion-free viewing. The highly- flexible, self-balancing shade and 45" internal spring arm allows Drawings
CIR025725 价格&库存
很抱歉,暂时无法提供与“CIR025725”相匹配的价格&库存,您可以联系我们找货
