KFK025790
KFK025790
    GLAMOX
    LAMP MAG 5 DIOPT 120V FLSNT 22W
KFK025790 数据手册
KFM KFK025790 *KFM-2/FE 5D 3C Lg KFM has a sturdy all-metal construction with a sleek design, flexible arm and excellent light output suitable for a variety of industrial, laboratory, cosmetology and low-vision applications. The flexibility of the neck assembly and patented internal spring 30" K-arm makes exact Old item no.: 17255LG positioning easy. 5-diopter (2.25X) lens. Weighted base. Color: Light grey. Optic Color of reflector Material of diffuser Primary Lens (D) Working distance (mm) Material of reflector Magnification (X) Lightsource White Polycarbonate 5 200 PC 2.25 Maximum frequency (Hz) 60 Minimum frequency (Hz) 50 Maximum voltage (V) 120 Voltage from (V) 100 Grey Aluminum CRI and/or Color Temperature Lightsource 22 G10Q 4100K T9 Net weight (kg) 0 Arm length (in.) 30 Gross weight (lb.) 50 Termination Cord length (ft) 20 Table/desk base 6 Ballast Type of Ballast Technical data IP classification Lamp base Mounting Body Body material Lamp power (W) 1 Dimensions Electrical data Body color Number of lamps High frequency
KFK025790 价格&库存
很抱歉,暂时无法提供与“KFK025790”相匹配的价格&库存,您可以联系我们找货
