WAL025973
WAL025973
    GLAMOX
    LAMP MAG 5 DIOPT 120V 2 LEDS 12W
WAL025973 数据手册
WAL025973 18910BK - WAVE LED-ESD MAGNIFIER, 45" ARM, 5D LENS AND EDGE Wave LED-ESD is an illuminated magnifier designed for use in staticsensitive environments where electrostatic discharges can prove fatal for electronic components. The shade and arm are powder-coated with a metal­laced paint that measures 10^4Ω/sq. (conductive). The remaining Old item no.: 18910BK components are molded in a material that measures 10^5 ­ 10^6Ω/sq. Lightsource Number of lamps Lightsource CRI and/or Color Temperature Electrical data 2 LED 80 CRI, 4000K Lamp power (W) 12 Lumen/Watt 46 Lumen Out 600 Maximum frequency (Hz) 60 Minimum frequency (Hz) 50 Maximum voltage (V) 120 Voltage from (V) 100 Total consumption (W) Optic Primary Lens (D) Technical data Maximum ambient temperature (°C) IP classification ESD-Safe Working distance (mm) 25 Magnification (X) 20 Body Yes 13 Body color 5 200 2.25 Black Termination Dimensions Net weight (kg) 0 Arm length (in.) 45 Mounting Edge clamp
WAL025973 价格&库存
很抱歉,暂时无法提供与“WAL025973”相匹配的价格&库存,您可以联系我们找货
