26507-SBK
26507-SBK
    AVENTOOLS(艾文)
    LAMP MAG 5 DIOPT 115V 24 LEDS
26507-SBK 数据手册
Magnifying Lamps Mighty Vue Lamps & Accessories Mighty Vue Magnifying Lamp-LED Mighty Vue Magnifying Lamp 26505-LED uu Durable safe mar-resistant plastic housing uu Large 7” x 6” 1.75x (3 diopter) lens uu 36 high-powered energy efficient SMD LEDs provide shadow-free illumination uu 32” spring balanced arm stays put in any position uu Heavy-duty metal mounting clamp with 63.5mm (2.5") opening uu LED lights are rated for over 20,000 hours of use uu Unit operates at 115 VAC Product ID Description 26505-LED Mighty Vue Magnifying Lamp-LED 26505-SIV uu Durable mar-resistant plastic housing uu Large 7” x 6” 1.75x (3 diopter) lens uu Two 9W Fluorescent bulbs operating a 6400K uu 32” spring balanced arm stays put in any position uu Heavy-duty metal mounting clamp with 63.5mm (2.5") opening uu Unit operates at 115 VAC Product ID Description 26505-SIV Mighty Vue Magnifying Lamp 9 Watt Replacement Bulb Mighty Vue Magnifying Lamp LED with Rolling Stand uu 9 Watt Replacement bulb designed for Mighty Vue Magnifiers uu Color temperature 6400K uu Energy efficient universal standard fluorescent light uu Same features as our 26505-LED except mounted on our heavy duty floor stand with casters 26505-LED-STN Product ID Description 26505-B09 9 Watt Replacement Bulb 26505-B09 Replacement Clamp - 26505-SIV uu Replacement Heavy-duty metal mounting clamp with 63.5mm (2.5") opening uu Mounts easily to desk or table top uu Fits Mighty Vue 26505-SIV and 26505-LED magnifying lamps Product ID Description Product ID Description 26505-LED-STN Mighty Vue Magnifying Lamp LED with Rolling Stand 26505-RC Replacement Clamp - 26505-SIV 26505-RC Replacement Clamp - 26505-ESD Mighty Vue Magnifying Lamp ESD Safe uu Available in three configurations with different lighting and magnifications uu Large 7" x 6" lens uu Durable ESD safe mar-resistant plastic housing uu 32” spring balanced arm stays put 26505-ESL-5D in any position uu Heavy-duty ESD safe metal mounting clamp with 63.5mm (2.5") opening uu Fluorescent model features two 9 Watt bulbs operating at 6400k uu LED models feature 36 high powered energy efficient SMD LEDs lights (18 per side) that provide shadow free illumination uu LED lights are rated for over 20,000 hours of use uu Unit operates at 115 VAC Product ID Description Lighting Magnification 26505-ESD Mighty Vue Magnifying Lamp ESD Safe 9w fluorescent 1.75x (3 diopter) 26505-ESL Mighty Vue Magnifying Lamp ESD Safe 36 SMD LED 1.75x (3 diopter) 26505-ESL-5D Mighty Vue Magnifying Lamp ESD Safe 36 SMD LED 2.25x (5 diopter) uu Replacement Heavy-duty metal mounting clamp with 63.5mm (2.5") opening uu Mounts easily to desk or table top uu Fits Mighty Vue 26505-ESD and 25505-ESD-5D magnifying lamps 26505-RC-ESD Product ID Description 26505-RC-ESD Replacement Clamp - 26505-ESD OptiVue LED Magnifying Desk Lamp uu Combines function and form in one small package uu Powerful energy efficient 24 SMD LEDs provide shadow-free illumination uu 3.5”– 2.25x (5 Diopter) lens uu Lens cover helps protect lens when not in use uu Flexible gooseneck arm Product ID Description 26507-SBK OptiVue LED Magnifying Desk Lamp 26507-SBK AVEN, INC. | 4330 VARSITY DRIVE | ANN ARBOR, MI 48108 33 Tel: 734.973.0099 | Fax: 734.973.0097 | www.aveninc.com
26507-SBK 价格&库存
很抱歉,暂时无法提供与“26507-SBK”相匹配的价格&库存,您可以联系我们找货
