50202
50202
    GLAMOX
    LENS 3 1/8" FOR KFM SERIES 8D
50202 数据手册
Luxo Magnification Product Lines THE MARKET LEADER IN MAGNIFICATION FOR OVER 70 YEARS WAVE+PLUS MAGNIFIERS For more than 70 years, Luxo has been the worldwide leader in magnification and lighting products. From inspection to assembly to rework applications, Luxo’s illuminated magnifiers are designed for today’s rigorous manufacturing environments and with the individual user in mind. Operators truly appreciate the diverse range and unique ergonomic features. Choices of magnification levels, light sources, arm lengths and mounting options combine to offer the best product for all forms of working conditions and applications. The end result is increased user productivity and comfort which ensures that Luxo illuminated magnifiers will continue to be an essential element in any manufacturing facility. Today, Luxo’s illuminated magnifiers are recognized as “best in class” in such countries as the U.S., Canada, Great Britain, Norway, Sweden, Denmark, Germany, Portugal and Italy. The WAVE+Plus Magnifier was introduced as the industry’s first rectangular-lensed illuminated magnifier. Now, over twenty years since its introduction, the WAVE+Plus Magnifier remains the top choice of technicians, assembly operators and quality control inspectors due to its wide-view, rectangular-shaped lens, excellent lighting and time-tested, heavy-duty K-arm. • 6.75” x 4.5” precision-ground white crown optical-quality glass lens. • Adjustable neck for positioning the magnifier head at the proper viewing angle so as to ensure the operator maintains correct posture. • Top-mounted accessory lenses, including a 10-diopter swing away lens. • Lighting: two 13-watt quad compact fluorescent tubes. • Dual switches for independent lighting controls. With one light on, shadowing is possible; with both on, full illumination results. • Magnification: 3.5 diopter lens (1.85X). • Total magnification possible 4.35X. • A blue indicator for each lamp (indicating on/off fluorescent tube). 17845LG • Heavy duty K-arm. 5” square steel tubing – 20 gauge CRS. • ABS plastic construction with polycarbonate lamp (bulb) covers. • UL/CUL listed. • 5 year warranty. 17917BK 2 WAVE+PLUS MAGNIFIERS WAVE+Plus Magnifiers, each with a stadium-shaped lens, offer the largest distortion-free viewing area in the industry. In addition to standard lens models, ESD-Safe, Anti-Reflective and UV magnifiers are available. WAVE+Plus ESD-Safe Magnifiers are designed for use in static sensitive environments as they guard against uncontrolled static dissipation. The outer surfaces of the components in the head assembly are protected with a special coating that alters the electrical characteristics at the surface of the materials. This specially-treated material results in a surface resistivity of 106 - 107 Ω/sq. (static dissipative). Since the surfaces are no longer insulative, triboelectric charging results in drastically lower voltages, especially since any charge (under 50 volts) is uniformly distributed throughout the entire surface of the unit’s head assembly. The magnifier arms are powder-coated with a metal-laced paint that measures 1010 Ω/sq. (static dissipative). An Anti-Reflective lens dissipates glare from overhead lighting so it is not necessary to bend over the lens to block out light reflections. This combination of protection makes the WAVE+Plus ESD-Safe Magnifier the foremost ESD-Safe magnifier in the industry. 17900BK WAVE+Plus A/R Magnifiers feature an Anti-Reflective (A/R) coating on the lens, which virtually eliminates glare from overhead lighting allowing an operator/ technician to see clearly without bending over the lens. This reduces both mental and physical fatigue as there is less stress on the shoulder, back and neck muscles, as well as less strain on the eyes. The resulting comfort and improved concentration and productivity make WAVE+Plus A/R Magnifiers an integral part of any complete ergonomics program. WAVE+Plus UV Magnifiers are multi-tasking products primarily designed for inspection of conformal coatings. The UV lightsource is also ideal for detailed inspection of welds, solder joints and other areas of stress concentration. Additional applications include inspection of surfaces and finishes in fields such as criminology, museum and artwork restorations, document authenticity, leak detection, currency verification and gemstone and mineral inspection. 17843LG WAVE+Plus Magnifiers Part No. Description Color Arm Length Mounting Bracket 17841 WAVE+ A/R K1AH LG, BK 45" Edge Mount 17842 WAVE+ A/R K2AH LG, BK 30" Edge Mount 17843 WAVE+A/R K2FE LG, BK 30" Base Mount 17845 WAVE+ K1AH LG, BK, WT 45" Edge Mount 17846 WAVE+ K2AH LG, BK 30" Edge Mount 17847 WAVE+ K2FE LG, BK 30" Base Mount 17900 WAVE+ ESD K1A BK 45" Edge Mount 17902 WAVE+ ESD K2A BK 30" Edge Mount 17904 WAVE+ ESD K2FE BK 30" Base Mount 17915 WAVE+ UV K1AH BK 45" Edge Mount 17916 WAVE+ UV K2AH BK 30" Edge Mount 17917 WAVE+ UV K2FE BK 30" Base Mount NOTE: Black (BK), White, (WT), Light Gray (LG) 3 KFM MAGNIFIERS KFM Magnifier is recognized as the world’s number one magnification system. As the most widely used magnification system, it offers the greatest selection of primary and secondary lenses and is backed by more options and quality features than any other illuminated magnifier. The KFM Magnifier is well equipped to handle any magnifying challenge. • Instant-On Switch: Just a touch of a switch ignites the fluorescent tube instantly and creates a “flicker-free” light that eliminates the stroboscopic effect on machinery such as a lathe or drill press. • Adjustable Neck moves the magnifier head vertically and horizontally to provide total flexibility. • Minimum Clearance Bracket allows for almost zero clearance (approximately ¼” clearance) between adjacent benches. It also provides more freedom of movement by raising the swivel point of the magnifier 2” higher above the bench surface. Its increased “jaw” size permits it to be clamped to surfaces up to 2.75” thick. • 5” diameter, 3-diopter (1.75X), 5-diopter (2.25X) or 10 diopter (3.50X) optical- quality lenses are mounted in a die-cast aluminum housing that is non-corrosive and durable. The inside is finished in white to optimize and evenly distribute light. 17113LG • Multi-Lens Capability: The KFM Series offers a wider range of distortion-free primary and secondary magnification lenses than any other magnifier. • 30” or 45” Patented Internal Spring K-Arm offers an infinite number of adjustable positions. Once adjusted, perfect balance is maintained by tempered steel springs. • 22-Watt Energy-Efficient Tube is protected by a heavy-duty clear diffuser which provides cool, shadow-free light on any worksurface. • Electronic Ballast System with RFI filter eliminates noise. • Electronic ballast produces 15% greater light output. • UL/CUL listed. • 5 year warranty. 17255BK 4 KFM MAGNIFIERS KFM-ESD Magnifier is designed for use in static sensitive environments as its ESD-Safe lens is protected with a special coating that guards against uncontrolled static dissipation by altering the electrical characteristics at the surface of the material. The shade and arm are powder-coated with a metal-laced paint that measures 1010 Ω/sq. (static dissipative) making the surfaces no longer insulative. Triboelectric charging results in drastically lower voltages, especially since any charge (under 50 volts) is uniformly distributed throughout the entire surface of the unit’s head assembly. KFM Magnifiers 16910BK Part No. Description Lens Type Color Arm Length Mounting Bracket 17110 KFM-1/AH 10D 10-Diopter LG 45" Edge Mount 17113 KFM-1/AH 3D 3-Diopter LG, BK, WT 45" Edge Mount 17115 KFM-1/AH 5D 5-Diopter LG, BK, WT 45" Edge Mount 17210 KFM-2/AH 10D 10-Diopter LG 30" Edge Mount 17213 KFM-2/AH 3D 3-Diopter LG, BK, WT 30" Edge Mount 17215 KFM-2/AH 5D 5-Diopter LG, BK, WT 30" Edge Mount 17250 KFM-2/FE 10D 10-Diopter LG 30" Base Mount 17253 KFM-2/FE 3D 3-Diopter LG, BK, WT 30" Base Mount 17255 KFM.-2/FE 5D 5-Diopter LG, BK, WT 30" Base Mount 16910 KFM-1/AH 3D ESD 3-Diopter BK 45" Edge Mount 16913 KFM-1/AH 5D ESD 5-Diopter BK 45" Edge Mount NOTE: Black (BK), White, (WT), Light Gray (LG) 17253LG 5 KFM-HIGH OUTPUT MAGNIFIERS KFM-High Output Magnifier features 2.5X greater light output than any other roundlensed industrial magnifier available today. Such complementary balance between light output and magnification makes the KFM-HO Magnifier ideal for use in Industrial, Manufacturing, Health and Beauty Spas, Cosmetology, Electrology, and Low Vision environments. As part of the most widely used magnification series in the world, KFM-HO Magnifier offers the largest selection of primary and secondary lenses making it the industrystandard for round-lensed illuminated magnifiers. • 22-Watt T-5C high output fluorescent light source protected by a heavy-duty clear diffuser, the tube provides cool, shadow-free light on any worksurface. • 2.5X greater light output than any other round-lensed Industrial magnifier. • 3500 lux at focal length. • Instant-On Switch. Just the touch of a switch ignites the fluorescent tube instantly and creates a “flicker-free” light that eliminates the stroboscopic effect on machinery such as a lathe or drill press. KH115 • Adjustable Neck moves the magnifier head vertically and horizontally to provide total flexibility. • 5” diameter, 3-diopter (1.75X), 5-diopter (2.25X) or 10 diopter (3.50X) optical-quality lenses are mounted in a die-cast aluminum housing that is non-corrosive and durable. The inside is finished in a high-polished aluminum reflector which helps to evenly distribute light. • Minimum Clearance Bracket. The AH bracket allows for almost zero clearance (approximately ¼” clearance) between adjacent benches. It also provides more freedom of movement by raising the swivel point of the magnifier 2” higher above the bench surface. Its increased “jaw” size permits it to be clamped to surfaces up to 2.75” thick. • Multi-Lens Capability: The KFM-HO Series offers a wider range of distortion-free primary and secondary magnification lenses than any other magnifier. • 30” or 45” Patented Internal Spring K-Arm offers an infinite number of adjustable positions. Once adjusted, perfect balance is maintained by tempered steel springs. • Electronic Ballast System with RFI filter eliminates noise. • UL/CUL listed. • 5 year warranty. KH253 6 KFM High-Output Magnifiers Lens Type Color Arm Length Mounting Bracket KFM-HO - 1/AH 10D 10-Diopter LG 45" Edge Mount KH113 KFM-HO - 1/AH 3D 3-Diopter LG, BK, WT 45" Edge Mount KH115 KFM-HO - 1/AH 5D 5-Diopter LG, BK, WT 45" Edge Mount KH210 KFM-HO - 2/AH 10D 10-Diopter LG 30" Edge Mount KH213 KFM-HO - 2/AH 3D 3-Diopter LG, BK 30" Edge Mount KH215 KFM-HO - 2/AH 5D 5-Diopter LG, BK 30" Edge Mount KH250 KFM-HO - 2/FE 10D 10-Diopter LG 30" Base Mount KH253 KFM-HO - 2/FE 3D 3-Diopter LG, BK 30" Base Mount KH255 KFM-HO - 2/FE 5D 5-Diopter LG, BK 30" Base Mount Part No. Description KH110 NOTE: Black (BK), White, (WT), Light Gray (LG) JFM MAGNIFIERS JFM Magnifier is Luxo’s newest high-quality illuminated magnifier. Like the WAVE+Plus Magnifier, manufactured in Europe, the JFM Magnifier is an ideal medium-duty magnifier for inspection, assembly and rework applications. • Instant-On Switch: Just a touch of a switch ignites the fluorescent tube instantly and creates a “flicker-free” light that eliminates the stroboscopic effect on machinery such as a lathe or drill press. • Adjustable Neck moves the magnifier head vertically and horizontally to provide total flexibility. • Minimum Clearance Bracket allows for almost zero clearance (approximately ¼” clearance) between adjacent benches. It also provides more freedom of movement by raising the swivel point of the magnifier 2” higher above the bench surface. Its increased “jaw” size permits it to be clamped to surfaces up to 2.75” thick. • 5” diameter lenses are mounted in a die-cast aluminum housing that is non-corrosive and durable. The inside is finished in white to optimize and evenly distribute light. 16115LG • Optical-quality, white crown, 3-diopter (1.75X) or 5-diopter (2.25X) glass lens. • 22-Watt Energy-Efficient Tube is protected by a heavy-duty clear diffuser which provides cool, shadow-free light on any worksurface. • Lamp diffuser cover. • 30” or 45” reach external spring arm. • Electronic ballast produces 15% greater light output. • Operates on 115VAC. • UL/CUL listed. • 5 year warranty. JFM Magnifiers 16213LG Part No. Description Lens Type Color Arm Length Mounting Bracket 16113 JFM1A 3D 3-Diopter LG 45" Edge Mount 16115 JFM1A 5D 5-Diopter LG 45" Edge Mount 16213 JFM2A 3D 3-Diopter LG 30" Edge Mount 16215 JFM2A 5D 5-Diopter LG 30" Edge Mount NOTE: Light Gray (LG) 7 IFM MAGNIFIER IFM Magnifier is the ideal light-duty magnifier for low-power inspection. With a sturdy, stamped steel shade, it features a 5” diameter, 3-diopter (1.75X) or 5-dioper (2.25X) lens and choice of 45” or 30” arm lengths. The IFM Magnifier is a smart, economical choice for tight budgets. • 30” or 45” external spring arm. • Clamp or base mount. • 5” diameter, 3-diopter (1.75X) or 5-diopter (2.25X) lens. • Expanded model range. • Lamp diffuser cover. • 22-Watt circline fluorescent lamp provides 360˚ shadow-free illumination. • Built-in starter switch. • 3-wire cord. • Operates on 115VAC. • 30” arm models are available with a weighted base. 16346LG • 3-wire single outlet receptacle is provided at the base of the arm for models 16345WT, 16346WT, 16345BK and 16346BK. • UL/CUL listed. • 5 year warranty. IFM Magnifiers 16351LG 8 Part No. Description Lens Type Color Arm Length Mounting Bracket 16345 IFM1A 3D 3-Diopter BK, WT, LG 45" Edge Mount 16346 IFM1A 5D 5-Diopter BK, WT, LG 45" Edge Mount 16350 IFM2A 3D 3-Diopter LG 30" Edge Mount 16351 IFM2K 3D 3-Diopter LG 30" Base Mount 16352 IFM2A 5D 5-Diopter LG 30" Edge Mount 16353 IFM2K 5D 5-Diopter LG 30" Base Mount NOTE: Black (BK), White, (WT), Light Gray (LG) MOUNTING BRACKETS, BASES AND ACCESSORY LENSES 60001, A Edge Mount Bracket for mounting products to horizontal surfaces (2.25” opening). Colors: Black, White, Light Gray 50020, AH Edge Mount Bracket for mounting products to horizontal surfaces (2.75” opening). Colors: Black, White, Light Gray 50003, B Wall Mount for permanent mounting to walls or other vertical surfaces. Colors: Black, White, Light Gray 50005, C Surface Mount for direct, permanent mounting to horizontal surfaces. Colors: Black, White, Light Gray 50010, FE Base for use with 30” arm Wave+Plus, KFM, KFM-HO and JFM Magnifiers only. Colors: Black, White, Light Gray 50074, 4-Diopter Lens adds 1X to magnification of primary lens. Colors: Black and Light Gray *for use with all WAVE+Plus Magnifiers 50078, 8-Diopter Lens adds 2X to magnification of primary lens. Colors: Black and Light Gray *for use with all WAVE+Plus Magnifiers 50206, 10-Dioper Swing Away Lens adds 2.5X magnification of primary lens *for use with all WAVE+Plus Magnifiers, KFM Magnifiers, KFM-HO Magnifiers and JFM Magnifiers 50201, 4-Dioper Lens adds 1X to magnification of primary lens *for use with all KFM Magnifiers 50202, 8-Diopter Lens adds 2X to magnification of primary lens *for use with KFM Magnifiers 60008, K Weighted Base for use with IFM Magnifier models 16351 and 16353 only. Color: Matte Black. 31639, Flush/Surface Mount Bushing for flush mount surface installation (19.3mm O.D.). Aluminum finish. 50036, 34” Floor Stand. Painted steel pole and cast iron base includes both casters and glides. Colors: Black, White, Light Gray 50204, 4-Diopter Lens adds 1X to magnification of primary lens *for use with KFM-HO Magnifiers 50205, 8-Diopter Lens adds 2X to magnification of primary lens *for use with KFM-HO Magnifiers 9 HANDHELD MAGNIFIERS Handheld UV Magnifier and UV Portable Magnifier are both perfect for the inspection of conformal coatings. Coatings glow brilliantly under UV black illumination, especially when magnified through a five-diopter (2.25X) optical-quality glass lens. Perfect for inspection of welds, solder joints, flux residues and hairline stress cracks. Additional applications include inspection of surfaces and finishes in fields such as criminology, museum and artwork restorations, document authenticity, leak detection, currency verification and gemstone and mineral inspection. 16401GY, Handheld UV Magnifier with combination 2-4W UV black bulbs and 2-4W fluorescent white bulbs. Wide rectangular 2.5” x 4” viewing area. 16405BK, UV Portable Magnifier with 13W UV black light illumination. 10’ cord with plug-in ballast and protective lens cover included. Rectangular 2” x 4” viewing area. KFM Magnifiers 16401GY Part No. Description 16405BK UV Portable Magnifier with 13W UV black light BK 16401GY Handheld UV Magnifier with combination 2-4W UV black light bulbs and 2-4W fluorescent white bulbs GY NOTE: Black (BK), Gray (GY) 16405BK 10 Color BASICS OF MAGNIFICATION Basic Terms Focal Length: Focal length is the distance from the center of the lens (or lens system) to the viewed object when in focus. Working distance: Working distance is measured from the lowest protruding portion of the magnifier below the lens, usually the bottom of the shade or shade housing, to the object when it appears in focus. Diopter (D): A term used to identify the refractive (light bending) capacity of a lens. It also relates magnification to focal length. Each diopter increases magnification by 25%, e.g. 4 diopter equals a 100% increase above original size. Field of View (FOV): Field of view is the area which is visible as seen through a lens. Wide-view rectangular lenses allow a greater viewing area than round lenses which force the user to rely solely on the center, undistorted section of the lens for optimal magnification clarity. Magnification: The degree to which the viewed object is enlarged. Magnification is usually expressed by a number followed by the symbol ‘X’ as in 1X, 2.25X, etc. To determine the level of magnification based on diopters used, divide the total diopters by 4 and add 1. E.g. 20D/4+1=5X. Examples of Magnification With no magnification 1.75X or 175% of its size as seen through a 3D lens. 3.50X or 350% of its size as seen through a 10D lens. 4.75X or 475% of its size as seen through a combination of a 5D primary lens and a 10D secondary lens. 6.00X or 600% of its size as seen through a combination of a 10D primary lens and a 10D secondary lens. Selecting the Right Luxo Magnifier To select the Luxo Illuminated Magnifier that best suits your needs, follow these steps: 1. Determine the desired magnification for your needs. Remember, as you increase magnification, you decrease both the focal length and the viewing area. 2. Check the chart on the back page of this brochure to find the right diopter to achieve that magnification. (The vast majority start with the standard 3-diopter factory installed lens and add secondary lenses or change primary lenses as needs dictate.) 3. Note the focal length and lens diameter that correspond to the magnification and lens diopter you have chosen, and make sure they are suitable for your task. 4. Select the primary and secondary lens combination required to achieve your desired magnification. 5. As a general rule, lenses or lens combinations above 5-diopter are recommended for inspection purposes only due to shorter working distances. A magnification requirement in excess of 4X normally requires a microscope. Using a Luxo Magnifier 1. Use both eyes. Luxo lenses are designed as ‘working tools’. They should be used as comfortably as a pair of glasses. 2. Position the lens so that it is a proper distance from the work-area, yet close enough to your eyes (about 8” to 10”) so that you have the maximum magnification without distortion. Don’t lean back away from the lens to increase magnification. 3. Chair height and worksurface should be set so that you can enjoy good posture. 11 Diopter-Magnification Diopter Magnification Working Distance Primary Lens Auxiliary Lens 3 1.75X 13" 3.0D - 3.5 1.85X 12" 3.5D - 5 2.25X 8" 5.0D - 7 2.75X 5.5" 3.0D 4D 7.5 2.85X 5" 3.5D 4D 9 3.25X 4.5" 5.0D 4D 10 3.50X 4" 10.0D - 11 3.75X 3.8" 3.0D 8D 11.5 3.85X 3.5" 3.5D 8D 13 4.25X 3" 5.0D 8D 13.5 4.35X 2.9" 3.5D 10D 14 4.50X 2.8" 10.0D 4D 15 4.75X 2.6" 5.0D 10D 18 5.50X 2.3" 10.0D 8D 20 6.00X 2" 10.0D 10D Copyright 2008, Luxo Corporation Luxo Corporation Five Westchester Plaza Elmsford, New York 10523 Phone: 800-222-5896 Fax: 800-648-2978 www.luxous.com Luxo Lamp Ltd. Montreal, Québec Phone: 800-361-3993 Fax: 800-567-9215 office@luxo.ca www.luxo.ca Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Luxo Corporation: 31639 50005BK 50201 50206 50005LG 50202
50202 价格&库存
很抱歉,暂时无法提供与“50202”相匹配的价格&库存,您可以联系我们找货
