26100-254
26100-254
    AVENTOOLS(艾文)
    CAMERA VGA HD COLOR IND MEASURE
26100-254 数据手册
Aven Inc. 4595 Platt Rd. Ann Arbor, MI 48108 Phone: 734.973.0099 Email: info@aventools.com • Web Address:www.aventools.com Item # 26100-254, VGA HD Color Industrial Measurement Camera VGA HD Color Industrial Measurement Camera This all in one HD camera allows you to connect it directly to a PC and view images in high resolution in real time. Built in measurement software allows you to perform accurate measurements of your parts with ease. PS2 mouse input provided. Taking measurements is as easy as point and click. Built in SD card allows you to save your data. · FEATURES · SPECIFICATIONS FEATURES Edge detection Live/freeze image Measure line, circle, radius, angle and parallel lines etc Measurement data and image can be saved on SD Card Measurement unit can be set in millimeters or inches Mouse control provides ease of use Mouse pointer color can be changed Mouse Pointer: Full screen cross hair or small center cross hair Multiple group of data can be saved on built in SD card for easy access Real time image resolution 1440 x 900 @30fps RGB values individuallly adjustable Unique built in measurement system in real HD camera VGA output, No PC needed, compact design directly connects to PC monitor SPECIFICATIONS Megapixel 1.3M at 24Bit 10/5/2011 | Page 1 of 2 FPS 30 FPS at 1440 x 900 Sensor CMOS 1/2.5 Mount C Mount White Balance Exposure Power Source Output Memory Card Dimensions Picture Format Weight Accessories Included Automatic/Manual Automatic 5V 1A (included) VGA SD 61 x 61 x 74 mm Bitmap 1.0 lb Calibration gauge included 10/5/2011 | Page 2 of 2
26100-254 价格&库存
很抱歉,暂时无法提供与“26100-254”相匹配的价格&库存,您可以联系我们找货
