26700-620
26700-620
    AVENTOOLS(艾文)
    E-Z BORESCOPE
26700-620 数据手册
Aven Inc. 4595 Platt Rd. Ann Arbor, MI 48108 Phone: 734.973.0099 Email: info@aventools.com • Web Address: www.aventools.com All Categories > Fluorescent Ring Lights > iLoupe XL Hand-Held Portable Microscopes > MIG Video Borescope > EZ Borescope > Item # 26700-620 Item # 26700-620, E-Z Borescope Aven E-Z Scope is a light weight and convenient hand held inspection device. It has a high resolution 2.5 inch color LCD Screen coupled to a digital camera that provides crystal clear images of hard to reach areas. Unit features LED brightness control to provide optimal image quality. Unit is equipped with a durable, detachable 3 feet ( 1 meter ) watertight flexible cable with a diameter of 10mm (0.39 inches) to help you get in and around tight spaces. larger image Kit Includes:1. 2. 3. 4. 5. 6. 7. 8. E-Z Scope hand held unit with 2.5 in Color LCD Screen with brightness control Detachable 3' flexible and obedient cable with LED illumination Magnetic Screw On Tip for retrieving metal objects from hard to reach places 90 degree mirror attachment for additional viewing capability Metal hook attachment 4 AA Batteries Cotton Swabs and Cleaning Cloth Carrying Case with shoulder strap Specifications Display Size 2.5 x 2.5 in Display Resolution 320(W) x 240(H) Color Light Source LED Min 0 Lux, Max 850 Lux (at 10 cm) Batteries 6V DC ( 4 AA Batteries Cable Length 36" Cable Diameter 10mm
26700-620
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一款高速光耦器件,用于隔离数字信号传输。
3. 引脚分配:EL817有6个引脚,包括输入、输出和电源引脚。
4. 参数特性:工作温度范围为-55℃至125℃,隔离电压为2.5kV。
5. 功能详解:EL817内部包含发光二极管和光敏三极管,实现电-光-电转换。
6. 应用信息:适用于高速数字通信、工业控制等领域。
7. 封装信息:EL817采用DIP-6封装。
26700-620 价格&库存
很抱歉,暂时无法提供与“26700-620”相匹配的价格&库存,您可以联系我们找货
