CM00624455
CM00624455
    VCC
    LED ACCY MOUNTING SPACER 0.455"
CM00624455 数据手册
SpaceSetter LED Spacer for T1 (3 mm) and T1¾ (5mm) TM TM SpaceSetter is a unique round spacer to position LEDs vertically from the surface of the PCB Applications • • consumer electronics electrical panels • • instrument panels PCBs in general • • • • minimize shifting and height variation ensure product uniformity and production ease Key features • • • height requirement: .200” to 1.000” no special tools required space the LED from the surface of the PCB color: natural Dimensions TOP VIEW OUTLINE 3 MM LED Ø .225 Ø [5.715] OUTLINE 5 MM LED .150 [3.810] .225 [5.715] Ø .204 Ø [5.182] Ø .166 Ø [4.216] Dim. “A” +.020 BOTTOM VIEW .133 [3.378] .140 [3.556] .100 [2.540] .204 [5.182] .200 [5.080] Ordering Data Dim. “A” Dim. “A” All dimensions in inches [mm] Dim. “A” Dim. “A” CM00624200 0.200” CM00624400 0.400” CM00624595 0.595” CM00624750 0.750” CM00624250 0.250” CM00624450 0.450” CM00624606 0.606” CM00624850 0.850” CM00624300 0.300” CM00624455 0.455” CM00624624 0.624” CM00624900 0.900” CM00624375 0.375” CM00624500 0.500” CM00624625 0.625” CM00624001 1.000” engineered to light up your design www.vcclite.com CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. 1.800.522.5546 08/15 Rev 1 Product specifications Material Nylon Zytel 101L NXC10-Natural UL94 V-2 Installation specifications height requirement: .200" to 1.000" + .020" Compliance & approvals engineered to light up your design www.vcclite.com CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. 1.800.522.5546 08/15 Rev 1
CM00624455
1. 物料型号:提供了不同高度要求的型号,如CM00624200(0.200英寸)、CM00624250(0.250英寸)等,直到CM00624001(1.000英寸)。
2. 器件简介:SpaceSetter™是为设计提供照明而特别设计的,适用于消费电子、电气面板、仪表盘和一般PCB。
3. 引脚分配:文档中没有提供具体的引脚分配信息,因为它是一个LED间隔器,而不是一个有引脚的电子元件。
4. 参数特性: - 材质:Nylon Zytel 101L NXC10-Natural,UL94 V-2等级。 - 安装规格:适用于0.200英寸至1.000英寸的高度要求,公差为+0.020英寸。
5. 功能详解:SpaceSetter™可以最小化LED的移位和高度变化,确保产品的一致性和生产便利性。
6. 应用信息:适用于需要LED照明的各种应用,如消费电子产品、电气面板、仪表盘等。
7. 封装信息:提供了3mm和5mm LED的外形尺寸,包括顶部视图和底部视图。
CM00624455 价格&库存
很抱歉,暂时无法提供与“CM00624455”相匹配的价格&库存,您可以联系我们找货
