T-100-170
T-100-170
    BIVAR
    Molded
    LED STRIP MNT 2 LEAD NYLON
T-100-170 数据手册
REV. C PART NO. H T100 Series ( T= 0.040" ) .060 (1.5) T-100-060 .070 (1.8) T-100-070 .080 (2.0) T-100-080 T-100-090 .090 (2.3 T-100-100 .100 (2.5) T-100-110 .110 (2.8) T-100-120 .120 (3.0) T-100-130 .130 (3.3) T-100-140 .140 (3.6) T-100-150 .150 (3.8) T-100-160 .160 (4.1) T-100-170 .170 (4.3) T-100-180 .180 (4.6) T-100-190 .190 (4.8) T-100-200 .200 (5.1) T-100-210 .210 (5.3) T .040 (1.0) .040 (1.0) .040 (1.0) .040 (1.0) .040 (1.0) .040 (1.0) .040 (1.0) .040 (1.0) .040 (1.0) .040 (1.0) .040 (1.0) .040 (1.0) .040 (1.0) .040 (1.0) .040 (1.0) .040 (1.0) DESCRIPTION DATE 03/01/04 Engineering Update w/o Changes APPROVED M. C. F .010 (.25) .015 (.38) .020 (.51) .025 (.64) .030 (.76) .035 (.89) .040 (1.0) .045 (1.1) .050 (1.3) .055 (1.4) .060 (1.5) .065 (1.7) .070 (1.8) .075 (1.9) .080 (2.0) .085 (2.2) 0.200 [5.1mm] 0.110 [2.8mm] 0.100 [2.5mm] 0.180 [4.6mm] 0.020 [0.5mm] 0.010 [0.3mm] TYP. Ø.06 [Ø1.5mm] 0.030 [0.8mm] TYP. TYP. 0.125 [3.2mm] 0.100 [2.5mm] 0.195 [5.0mm] POLARITY KEY PART NO. H T101 Series ( T= 0.150" ) T-101-200 .200 (5.1) T-101-210 .210 (5.3) T-101-220 .220 (5.6) T-101-230 .230 (5.8) .240 (6.1) T-101-240 .250 (6.4) T-101-250 .260 (6.6) T-101-260 .270 (6.9) T-101-270 .280 (7.1) T-101-280 .290 (7.4) T-101-290 .300 (7.6) T-101-300 .310 (7.9) T-101-310 .320 (8.1) T-101-320 T-101-330 .330 (8.4) T-101-340 .340 (8.6) T-101-350 .350 (8.9) T F 0.030 [0.8mm] F .150 (3.8) .150 (3.8) .150 (3.8) .150 (3.8) .150 (3.8) .150 (3.8) .150 (3.8) .150 (3.8) .150 (3.8) .150 (3.8) .150 (3.8) .150 (3.8) .150 (3.8) .150 (3.8) .150 (3.8) .150 (3.8) .025 (.64) .030 (.76) .035 (.76) .040 (1.0) .045 (1.1) .050 (1.3) .055 (1.4) .060 (1.5) .065 (1.7) .070 (1.8) .075 (1.9) .080 (2.0) .085 (2.2) .090 (2.3) .095 (2.4) .100 (2.5) H REF. T F 0.050 [1.3mm] 0.200 [5.1mm] TYP. TYP. 0.050 [1.3mm] 0.100 [2.5mm] TYP. TYP. Ø.032+.003 -.002 TYP. Recommended Mounting Holes STANDARD TOLERANCE  ( UNLESS OTHERWISE SPECIFIED ) DECIMALS 2. MATERIAL: NYLON 6/6, 94V-2, NATURAL. BIVAR MATERIAL CODE 03-NL. BASF ULTRAMID NYLON 6/6 A3K NATURAL. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: David Green CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: 15-STATION LED STRIP-MOUNT DATE: 10/18/02 DATE: 10/22/02 PART NO: REVISION: T-10X-XXX CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
T-100-170 价格&库存
很抱歉,暂时无法提供与“T-100-170”相匹配的价格&库存,您可以联系我们找货
