REV.
C
PART NO.
H
T100 Series ( T= 0.040" )
.060 (1.5)
T-100-060
.070 (1.8)
T-100-070
.080 (2.0)
T-100-080
T-100-090
.090 (2.3
T-100-100
.100 (2.5)
T-100-110
.110 (2.8)
T-100-120
.120 (3.0)
T-100-130
.130 (3.3)
T-100-140
.140 (3.6)
T-100-150
.150 (3.8)
T-100-160
.160 (4.1)
T-100-170
.170 (4.3)
T-100-180
.180 (4.6)
T-100-190
.190 (4.8)
T-100-200
.200 (5.1)
T-100-210
.210 (5.3)
T
.040 (1.0)
.040 (1.0)
.040 (1.0)
.040 (1.0)
.040 (1.0)
.040 (1.0)
.040 (1.0)
.040 (1.0)
.040 (1.0)
.040 (1.0)
.040 (1.0)
.040 (1.0)
.040 (1.0)
.040 (1.0)
.040 (1.0)
.040 (1.0)
DESCRIPTION
DATE
03/01/04
Engineering Update w/o Changes
APPROVED
M. C.
F
.010 (.25)
.015 (.38)
.020 (.51)
.025 (.64)
.030 (.76)
.035 (.89)
.040 (1.0)
.045 (1.1)
.050 (1.3)
.055 (1.4)
.060 (1.5)
.065 (1.7)
.070 (1.8)
.075 (1.9)
.080 (2.0)
.085 (2.2)
0.200 [5.1mm]
0.110 [2.8mm]
0.100 [2.5mm]
0.180 [4.6mm]
0.020 [0.5mm]
0.010 [0.3mm]
TYP.
Ø.06 [Ø1.5mm]
0.030 [0.8mm] TYP.
TYP.
0.125 [3.2mm]
0.100 [2.5mm]
0.195 [5.0mm]
POLARITY KEY
PART NO.
H
T101 Series ( T= 0.150" )
T-101-200
.200 (5.1)
T-101-210
.210 (5.3)
T-101-220
.220 (5.6)
T-101-230
.230 (5.8)
.240 (6.1)
T-101-240
.250 (6.4)
T-101-250
.260 (6.6)
T-101-260
.270 (6.9)
T-101-270
.280 (7.1)
T-101-280
.290 (7.4)
T-101-290
.300 (7.6)
T-101-300
.310 (7.9)
T-101-310
.320 (8.1)
T-101-320
T-101-330
.330 (8.4)
T-101-340
.340 (8.6)
T-101-350
.350 (8.9)
T
F
0.030 [0.8mm]
F
.150 (3.8)
.150 (3.8)
.150 (3.8)
.150 (3.8)
.150 (3.8)
.150 (3.8)
.150 (3.8)
.150 (3.8)
.150 (3.8)
.150 (3.8)
.150 (3.8)
.150 (3.8)
.150 (3.8)
.150 (3.8)
.150 (3.8)
.150 (3.8)
.025 (.64)
.030 (.76)
.035 (.76)
.040 (1.0)
.045 (1.1)
.050 (1.3)
.055 (1.4)
.060 (1.5)
.065 (1.7)
.070 (1.8)
.075 (1.9)
.080 (2.0)
.085 (2.2)
.090 (2.3)
.095 (2.4)
.100 (2.5)
H REF. T
F
0.050 [1.3mm]
0.200 [5.1mm]
TYP.
TYP.
0.050 [1.3mm]
0.100 [2.5mm]
TYP.
TYP.
Ø.032+.003
-.002 TYP.
Recommended Mounting Holes
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
2. MATERIAL: NYLON 6/6, 94V-2, NATURAL. BIVAR MATERIAL CODE 03-NL.
BASF ULTRAMID NYLON 6/6 A3K NATURAL.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
David Green
CHECKED:
M. Chen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
15-STATION LED STRIP-MOUNT
DATE:
10/18/02
DATE:
10/22/02
PART NO:
REVISION:
T-10X-XXX
CAGE CODE : 32559
C
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“T-100-140”相匹配的价格&库存,您可以联系我们找货
