H-132C-2-160
H-132C-2-160
    BIVAR
    LED HOLDER RA 3MM 2LD NYL BK
H-132C-2-160 数据手册
REV. B DESCRIPTION DATE 02/26/04 Engineering Update w/o Changes APPROVED M. C. 0.240 [6.1mm] DIA 0.200 [5.1mm] 0.170 [4.3mm] 0.085 [2.2mm] 0.100 [2.5mm] 0.025 [0.6mm] SQ. TYP. Cathode I.D. Mark 1 (H-13XC-1-XXX) 2 (H-13XC-2-XXX) C/L L 0.130 [3.3mm] Holder Faces 0.210 [5.3mm] Ø.032+.003 -.002 TYP. 0.172 [4.4mm] Holder Pitch 0.100 [2.5mm] LED Lead H-130C H-131C H-132C H-133C Recommended Mounting Holes PART NO. H-130C SERIES H-131C SERIES H-132C SERIES H-133C SERIES ID MARK DIA H-130C-1-120 H-131C-1-120 H-132C-1-120 H-133C-1-120 1 .128 [3.3mm] H-130C-2-120 H-131C-2-120 H-132C-2-120 H-133C-2-120 2 .150 [3.8mm] H-130C-1-140 H-131C-1-140 H-132C-1-140 H-133C-1-140 1 .128 [3.3mm] .150 [3.8mm] H-130C-2-140 H-131C-2-140 H-132C-2-140 H-133C-2-140 2 H-130C-1-160 H-131C-1-160 H-132C-1-160 H-133C-1-160 1 .128 [3.3mm] H-130C-2-160 H-131C-2-160 H-132C-2-160 H-133C-2-160 2 .150 [3.8mm] H-130C-1-180 H-131C-1-180 H-132C-1-180 H-133C-1-180 1 .128 [3.3mm] H-130C-2-180 H-131C-2-180 H-132C-2-180 H-133C-2-180 2 .150 [3.8mm] C/L L .120 [3.0mm] .250 [6.4mm] .140 [3.6mm] .270 [6.9mm] .160 [4.1mm] .290 [7.4mm] .180 [4.6mm] .310 [7.9mm] STANDARD TOLERANCE  ( UNLESS OTHERWISE SPECIFIED ) DECIMALS 2. MATERIAL: NYLON 6/6, 94V-0, BLACK. BIVAR MATERIAL CODE 22-BK. RTP POLYAMIDE NYLON 6/6, 0200 FR, BLACK OR MODIFIED PLASTICS MN6/6-SE BK. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: Michael Chen CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 01/21/03 DATE: 01/21/03 FAX: (949) 951-3974 T-1 (3mm) LED HOLDER INTERLOCKING VARIABLE CENTERLINE PART NO: REVISION: H-13XC-X-XXX CAGE CODE : 32559 B SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H-132C-2-160 价格&库存
很抱歉,暂时无法提供与“H-132C-2-160”相匹配的价格&库存,您可以联系我们找货
