H-300-1-500
H-300-1-500
    BIVAR
    LED HOLDER RA 3MM 2LD NYL BK
H-300-1-500 数据手册
REV. E DESCRIPTION DATE 02/27/04 Engineering Update w/o Changes APPROVED M. C. 0.425 [10.8mm] 0.075 [1.9mm] 0.170 [4.3mm] 0.100 [2.5mm] TYP. 0.030 [0.8mm] SQ. TYP. DIA TYP. Cathode I.D. Mark 1 (H-30XC-1-XXX) 2 (H-30XC-2-XXX) H C/L 0.375 [9.5mm] PART NO. C/L ID MARK DIA H H-300-1-500 .500[12.7] 1 .128[3.3] .600[15.2] H-300-2-500 .500[12.7] 2 .150[3.8] .600[15.2] H-300-1-520 .520[13.2] 1 .128[3.3] .620[15.7] H-300-2-520 .520[13.2] 2 .150[3.8] .620[15.7] H-300-1-540 .540[13.7] 1 .128[3.3] .640[16.3] H-300-2-540 .540[13.7] 2 .150[3.8] .640[16.3] H-300-1-560 .560[14.2] 1 .128[3.3] .660[16.8] H-300-2-560 .560[14.2] 2 .150[3.8] .660[16.8] H-300-1-580 .580[14.7] 1 .128[3.3] .680[17.3] .580[14.7] 2 .150[3.8] .680[17.3] H-300-2-580 0.130 [3.3mm] STANDARD TOLERANCE  ( UNLESS OTHERWISE SPECIFIED ) DECIMALS 2. MATERIAL: NYLON 6/6, 94V-0, BLACK. BIVAR MATERIAL CODE 22-BK. RTP POLYAMIDE NYLON 6/6, 0200 FR, BLACK OR MODIFIED PLASTICS MN6/6-SE BK. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: David Green CHECKED: M. Chen ANGULAR X° ± 1° DATE: 12/17/02 DATE: 12/17/02 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: STACKING TRIPLE T-1 (3mm) LED HOLDER VARIABLE DIAMETER REVISION: PART NO: H-300-X-XXX CAGE CODE : 32559 E SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H-300-1-500 价格&库存
很抱歉,暂时无法提供与“H-300-1-500”相匹配的价格&库存,您可以联系我们找货
