REV.
E
DESCRIPTION
DATE
02/27/04
Engineering Update w/o Changes
APPROVED
M. C.
0.425 [10.8mm]
0.075 [1.9mm]
0.170 [4.3mm]
0.100 [2.5mm]
TYP.
0.030 [0.8mm] SQ.
TYP.
DIA
TYP.
Cathode I.D. Mark
1 (H-30XC-1-XXX)
2 (H-30XC-2-XXX)
H
C/L
0.375 [9.5mm]
PART NO.
C/L
ID
MARK
DIA
H
H-300-1-500
.500[12.7]
1
.128[3.3]
.600[15.2]
H-300-2-500
.500[12.7]
2
.150[3.8]
.600[15.2]
H-300-1-520
.520[13.2]
1
.128[3.3]
.620[15.7]
H-300-2-520
.520[13.2]
2
.150[3.8]
.620[15.7]
H-300-1-540
.540[13.7]
1
.128[3.3]
.640[16.3]
H-300-2-540
.540[13.7]
2
.150[3.8]
.640[16.3]
H-300-1-560
.560[14.2]
1
.128[3.3]
.660[16.8]
H-300-2-560
.560[14.2]
2
.150[3.8]
.660[16.8]
H-300-1-580
.580[14.7]
1
.128[3.3]
.680[17.3]
.580[14.7]
2
.150[3.8]
.680[17.3]
H-300-2-580
0.130 [3.3mm]
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
2. MATERIAL: NYLON 6/6, 94V-0, BLACK. BIVAR MATERIAL CODE 22-BK.
RTP POLYAMIDE NYLON 6/6, 0200 FR, BLACK OR MODIFIED PLASTICS MN6/6-SE BK.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
David Green
CHECKED:
M. Chen
ANGULAR
X°
± 1°
DATE:
12/17/02
DATE:
12/17/02
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
STACKING TRIPLE T-1 (3mm)
LED HOLDER VARIABLE DIAMETER
REVISION:
PART NO:
H-300-X-XXX
CAGE CODE : 32559
E
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“H-300-1-580”相匹配的价格&库存,您可以联系我们找货
