REV.
0.320 [8.1mm]
0.100 [2.5mm]
TYP.
0.170 [4.3mm]
0.075 [1.9mm]
0.030 [0.8mm] SQ.
TYP.
DESCRIPTION
D
DATE
02/27/04
Engineering Update w/o Changes
APPROVED
M. C.
DIA
TYP.
L
C/L 2
Cathode I.D.
Mark
1 (H-30XC-1-XXX)
2 (H-30XC-2-XXX)
C/L 1
0.130 [3.3mm]
0.175 [4.4mm]
0.275 [7.0mm]
Holder Faces
Ø.032+.003
-.002
TYP.
0.185 [4.7mm]
0.100 [2.5mm]
TYP.
ROW NEEDED WHEN
USING H-300-X-XXX
0.172 [4.4mm] Holder Pitch
0.100 [2.5mm] LED Lead
H-300C
H-301C
H-302C
H-303C
Recommended Mounting Holes
PART NO.
H-300C SERIES
H-301C SERIES
H-302C SERIES
ID
H-303C SERIES MARK
H-300C-1-100
H-301C-1-100
H-302C-1-100
H-303C-1-100
1
.128 [3.3mm]
.150 [3.8mm]
DIA
H-300C-2-100
H-301C-2-100
H-302C-2-100
H-303C-2-100
2
H-300C-1-120
H-301C-1-120
H-302C-1-120
H-303C-1-120
1
.128 [3.3mm]
.150 [3.8mm]
H-300C-2-120
H-301C-2-120
H-302C-2-120
H-303C-2-120
2
H-300C-1-140
H-301C-1-140
H-302C-1-140
H-303C-1-140
1
.128 [3.3mm]
.150 [3.8mm]
H-300C-2-140
H-301C-2-140
H-302C-2-140
H-303C-2-140
2
H-300C-1-160
H-301C-1-160
H-302C-1-160
H-303C-1-160
1
.128 [3.3mm]
.150 [3.8mm]
H-300C-2-160
H-301C-2-160
H-302C-2-160
H-303C-2-160
2
H-300C-1-180
H-301C-1-180
H-302C-1-180
H-303C-1-180
1
.128 [3.3mm]
H-303C-2-180
2
.150 [3.8mm]
H-300C-2-180
H-301C-2-180
H-302C-2-180
C/L 1
C/L 2
L
.100 [2.5mm]
.300 [7.6mm]
.415 [10.6mm]
.120 [3.0mm]
.320 [8.1mm]
.435 [11.0mm]
.140 [3.6mm]
.340 [8.6mm]
.455 [11.6mm]
.160 [4.1mm]
.360 [9.1mm]
.475 [12.1mm]
.180 [4.6mm]
.380 [9.7mm]
.495 [12.6mm]
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
2. MATERIAL: NYLON 6/6, 94V-0, BLACK. BIVAR MATERIAL CODE 22-BK.
RTP POLYAMIDE NYLON 6/6, 0200 FR, BLACK OR MODIFIED PLASTICS MN6/6-SE BK.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
David Green
CHECKED:
M. Chen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
12/20/02
DATE:
01/22/03
FAX: (949) 951-3974
BI-LEVEL T-1 (3mm) LED HOLDER
INTERLOCKING, VARIABLE CENTERLINE
REVISION:
PART NO:
H-30XC-X-XXX
CAGE CODE : 32559
D
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“H-300C-2-140”相匹配的价格&库存,您可以联系我们找货
