H-300CR-2-100
H-300CR-2-100
    BIVAR
    LED HOLDER RA 3MM 2LD NYL BK
H-300CR-2-100 数据手册
REV. 0.375 [9.5mm] 0.100 [2.5mm] TYP. DATE 02/27/04 APPROVED M. C. 0.170 [4.3mm] 0.152 [3.9mm] 0.030 [0.8mm] SQ. TYP. DESCRIPTION A Engineering Update w/o Changes DIA TYP. L C/L 2 Cathode I.D. Mark 1 (H-30XCR-1-XXX) 2 (H-30XCR-2-XXX) C/L 1 0.230 [5.8mm] 0.130 [3.3mm] 0.330 [8.4mm] Holder Faces 0.240 [6.1mm] Ø.032+.003 -.002 TYP. 0.100 [2.5mm] 0.172 [4.4mm] Holder Pitch 0.100 [2.5mm] LED Lead H-300CR H-301CR H-302CR H-303CR Recommended Mounting Holes PART NO. ID H-300CR SERIES H-301CR SERIES H-302CR SERIES H-303CR SERIES MARK DIA H-300CR-1-100 H-301CR-1-100 H-302CR-1-100 H-303CR-1-100 1 .128 [3.3mm] H-300CR-2-100 H-301CR-2-100 H-302CR-2-100 H-303CR-2-100 2 .150 [3.8mm] H-300CR-1-120 H-301CR-1-120 H-302CR-1-120 H-303CR-1-120 1 .128 [3.3mm] H-300CR-2-120 H-301CR-2-120 H-302CR-2-120 H-303CR-2-120 2 .150 [3.8mm] H-300CR-1-140 H-301CR-1-140 H-302CR-1-140 H-303CR-1-140 1 .128 [3.3mm] .150 [3.8mm] H-300CR-2-140 H-301CR-2-140 H-302CR-2-140 H-303CR-2-140 2 H-300CR-1-160 H-301CR-1-160 H-302CR-1-160 H-303CR-1-160 1 .128 [3.3mm] H-300CR-2-160 H-301CR-2-160 H-302CR-2-160 H-303CR-2-160 2 .150 [3.8mm] H-300CR-1-180 H-301CR-1-180 H-302CR-1-180 H-303CR-1-180 1 .128 [3.3mm] H-303CR-2-180 2 .150 [3.8mm] H-300CR-2-180 H-301CR-2-180 H-302CR-2-180 C/L 1 C/L 2 L .100 [2.5mm] .300 [7.6mm] .415 [10.6mm] .120 [3.0mm] .320 [8.1mm] .435 [11.0mm] .140 [3.6mm] .340 [8.6mm] .455 [11.6mm] .160 [4.1mm] .360 [9.1mm] .475 [12.1mm] .180 [4.6mm] .380 [9.7mm] .495 [12.6mm] STANDARD TOLERANCE  ( UNLESS OTHERWISE SPECIFIED ) DECIMALS 2. MATERIAL: NYLON 6/6, 94V-0, BLACK. BIVAR MATERIAL CODE 22-BK. RTP POLYAMIDE NYLON 6/6, 0200 FR, BLACK OR MODIFIED PLASTICS MN6/6-SE BK. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: Ty Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 02/27/04 DATE: 02/27/04 FAX: (949) 951-3974 BI-LEVEL T-1 (3mm) LED HOLDER INTERLOCKING, VARIABLE CENTERLINE RECESSED CAVITY REVISION: PART NO: H-300XCR-X-XXX CAGE CODE : 32559 A SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H-300CR-2-100 价格&库存
很抱歉,暂时无法提供与“H-300CR-2-100”相匹配的价格&库存,您可以联系我们找货
