5680F5_5
5680F5_5
    VCC
    插件
    发光二极管/LED 翠绿色 插件 16mcd
5680F5_5 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5680F Series T-1 2 High Right Angle Assembly Description and Features Features • 2 T-1 LEDs mounted in single block. • Less PC board space needed, height and spacing alignment saves as sembly cost. • High Brite and Super Brite LEDs, diffused lens . • Standoffs prevent flux entrapment. • Black Nylon plastic block, UL94V-O • RoHS Compliant All dimensions in inches. .200 MAX .390 .360 LE D P OS IT ION 1 LE D P OS IT ION 2 .200 .100 Ø.120 .175±.015 Alternate LEDs are also available in this package as a standard variation. .100 MAX C AT HODE .200 .100 .020 S Q TYP. .100 Refer to “Mounting Hole Pattern 4.pdf” Electro-Optical Characteristics and Ratings P art Number 5680F 1_1 5680F 3_3 5680F 5_5 5680F 7_7 E mitted C olor R ed/R ed Amber/Amber G reen/G reen Y ellow/Y ellow T ypical Intensity (mcd) R ated C urrent (mA) 10 10 10 10 10.0 7 16 6.3 C ontinuous F orward C urrent Max. (mA) T yp. (V ) Max. (V ) R everse B reakdown V oltage Min.(V ) P eak Wavelength (nm) 30 30 30 30 2.0 2.0 2.2 2.1 3.0 3.0 3.0 3.0 5.0 5.0 5.0 5.0 650 603 562 585 F orward V oltage T he model numbers listed above are standard off the shelf parts, for the user who may have a requirement calling for various color/electrical specifications, a part number can be determined by referring to the chart shown below. Model No. is as follows: 5680F LE D C olor R ed G reen Y ellow R ed Amber G reen R ed Amber G reen Y ellow LE D C ode 1LC 5LC 7LC 1-5V 3-5V 5-5V 1 3 5 7 LE D 1 _ LE D 2 T ypical Intensity (mcd) R ated C urrent (mA) 2.5 2.1 1.8 8.0 8.0 8.0 10 7 16 6.3 2.0 2.0 2.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 F orward C urrent Max. (mA) F orward V oltage T yp. (V ) Max. (V ) 7 7 7 20 15 15 30 30 1.8 1.8 1.9 5.0 5.0 5.0 2.0 2.0 2.2 2.2 2.7 7.5 7.5 7.5 3.0 3.0 30 30 2.2 2.1 3.0 3.0 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. R everse B reakdown V oltage Min. (V ) 5 5 5 5 5 5 5 5 5 5 P eak Wavelength (nm) 650 565 583 655 583 565 635 603 562 583
5680F5_5 价格&库存
很抱歉,暂时无法提供与“5680F5_5”相匹配的价格&库存,您可以联系我们找货
5680F5_5
    5680F5_5
      • 1+14.33160
      • 200+5.72400
      • 500+5.52960
      • 1000+5.44320
      5680F5_5
        5680F5_5
        • 1+25.631311+3.30219
        • 10+18.6238510+2.39939
        • 100+14.44214100+1.86065
        • 500+12.60413500+1.62385
        • 1000+12.005201000+1.54668
        • 2000+11.498112000+1.48135
        • 5000+10.945605000+1.41017
        库存:6141
        5680F5_5
          库存:1400
