CMW01G
CMW01G
    VCC
    LED GREEN T1 MODULAR DIFFUSED
CMW01G 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 T-1 StatusPak™ Circuit Board Indicators Description and Features .095±.020 .182/.192 .192 .218 .040 Ø.125 .286 MAX. .200 .135 MIN. C AT HODE C AT HODE TYP. .100 .020 T Y P . .020 S Q. TYP. .190±.020 .100 All dimensions in inches. P rinted C ircuit B oard as s embly has been made fas ter and eas ier than ever before. Now you can mount from one to ten circuit board indicators , as a s ingle unit, in one eas y s tep. T -1 S tatus P ak™ is cus tomized to your s pecification. Y ou choos e the number of LE Ds , color s equence and pos ition. S tatusP ak™ is shipped to you as a complete unit, ready for one-step P C board mounting. Unique snap-together feature allows you to add or take away S tatusP ak™ modules as needed without any special tooling. •RoHS Compliant Refer to Mounting Hole Pattern 1.pdf ELECTRO-OPTICAL CHARACTERISTICS AND RATINGS P art Number E mitted C olor Lens C olor C MC 01R C MC 01Y C MC 01G C MW01R C MW01Y C MW01G H.E .R ed Y ellow H.E .G reen H.E .R ed Y ellow H.E .G reen C lear C lear C lear R ed Y ellow G reen P ackage T ype Non-Diffused Non-Diffused Non-Diffused Diffused Diffused Diffused Luminous Intensity Min. (mcd) 24.0 24.0 24.0 3.2 3.2 3.2 F orward V oltage T yp. (mcd) T yp. (V ) Max. (V ) 60.0 60.0 60.0 20.0 12.5 2.0 2.1 2.2 2.0 2.1 2.5 2.5 2.5 2.5 2.5 12.5 2.2 2.5 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. V iewing Angle (degrees) P eak Wavelength (nm) 30 30 30 130 120 120 625 590 565 625 590 565 engineered to light up your design www.vcclite.com 1.800.522.5546 T-1 StatusPak™ Circuit Board Indicators Description and Features How to order a Multi Position Assembly 1. Determine the lens type you require: -diffused or non-diffused 2. Determine the number of positions you require including any open spaces. (CML does not recommend assemblies of greater than ten positions.) 3. Determine the specific LED required in each position from the table below. CMC (Non-Diffused) CMW (Diffused) R = Ultra Brite Red Y = Ultra Brite Yellow G = Ultra Brite Green X = Open Space R = Hi-Brite Red Y = Hi-Brite Yellow G = Hi-Brite Green X = Open Space Example: C M W - 05 - R Y G G R Lens Type # of Positions LED Sequence CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
CMW01G 价格&库存
很抱歉,暂时无法提供与“CMW01G”相匹配的价格&库存,您可以联系我们找货
