5350T5
5350T5
    VCC
    LED GREEN T-3/4 RT ANG PCB
5350T5 数据手册
5350 Series (2.0 mm) LED Circuit Board Indicator LED Holder, Right Angle, Sub-miniature 2.0 mm LED accelerates time to market and improves assembly efficiency Applications • • panel indication electrical panels • • entertainment industrial • • appliances displays Key features • through hole mounting method • • can be stacked side by side on 0.130” high center line • labor-saving single-block installation • available in 3 colors: red, green and yellow (2V)/amber (5V) • compact, only 6.6 mm high • soldering • • low current (2mA) available • built-in resistor chip • Dimensions .210 (5.3) .09 (2.3) .04 (1.0) Ø.080 (2.0) .260 (6.6) LE D .13 (3.3) MIN ANODE .020 (0.5) S T AND OF F F OR F LUX WAS H .027 (0.7) MAX. .040 (1.0) .100 (2.5) .010 (0.3) MAX. engineered to light up your design Dimensions in inches (mm). www.vcclite.com 1.800.522.5546 06/15 Rev 1 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. Product specifications and ordering data Materials Zytel Black Nylon UL94-V0 housing Electro-Optical Characteristics and Ratings 5350T1 5350T5 5350T7 5350T1LC 5350T5LC 5350T7LC 5352T1-5V 5352T3-5V 5352T5-5V 5352T1-5VLC 5352T3-5VLC 5352T5-5VLC E mitted C olor T ypical Intensity (mcd) R ated C urrent (mA) Red Green Yellow Red Green Yellow Red Amber Green Red Amber Green 5. 0 4. 0 3. 8 .5 1. 2 .5 5. 0 5. 0 5. 0 2. 0 4. 0 2. 0 10 10 10 2. 0 2. 0 2. 0 9. 6 10 10 3. 5 3. 5 3. 5 C ontinuous F orward C urrent Max. (mA) 30 30 20 7 7 7 13 13 13 5 5 5 P eak F orward C urrent At 1ms-300 P P S (A) . 06 . 06 . 06 . 007 . 007 . 007 - F orward V oltage T yp. (V ) Max. (V ) 2. 2 2. 3 2. 2 1. 8 1. 8 1. 9 5. 0 5. 0 5. 0 5. 0 5. 0 5. 0 3. 0 3. 0 3. 0 2. 2 2. 2 2. 7 6. 0 6. 0 6. 0 6. 0 6. 0 6. 0 R everse B reakdown V oltage Min. (V ) 5 5 5 5 5 5 5 5 5 5 5 5 P eak Wavelength (nm) 635 565 583 635 565 583 635 583 565 635 583 565 Compliance & approvals engineered to light up your design www.vcclite.com 1.800.522.5546 06/15 Rev 1 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
5350T5 价格&库存
很抱歉,暂时无法提供与“5350T5”相匹配的价格&库存,您可以联系我们找货
