5305H1/5
5305H1/5
    VCC
    LED RED/GRN T1-3/4 BI-CLR PCB
5305H1/5 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5305 Series T-1 3/4 Tricolor Right Angle LED Assembly Description and Features .260 .300 .380 .130 MIN. .300 .200 .150 ANODE (+) RED/AMBER ANODE (+) GREEN . .020 S Q .300 C AT HODE C OMMON .100 All dimens ions in inches . .100 Features • Block mounting, height and spacing alignment saves assembly cost and time. • Super Brite LEDs-high intensity light output • Press-in pin secures block to board for solder • Press-in pin secures block to board for soldering. • Standoffs prevent flux entrapment. • RoHS Compliant Housing: Black Nylon, UL94V-O Electro-Optical Characteristics and Ratings Part Number Color Typ. Intensity (mcd) Rated Current (mA) 5305H1/5 Red/Green 6.3/10 10 5305H3/5 Amber/Green 5.0/5.0 10 Continuous Forward Forward Forward Voltage Max. Voltage Typ. Current Max. (V) (V) (mA) 60 2.1 2.8 20 2.1 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. 2.8 Reverse Break-down Voltage Min. (V) 4 650(R)/565(G) 4 610(A)/565(G) Peak Wavelength (nm)
5305H1/5 价格&库存
很抱歉,暂时无法提供与“5305H1/5”相匹配的价格&库存,您可以联系我们找货
